SAMD21 UART SERCOM ASF
Gast #4659310
bastle grad mit einem SAMD21 an der Ausgabe einer UART.
Verwende Atmel Studio 7.
#include <asf.h>
#include <stdio.h>
#include <string.h>
#define SENSOR_LEFT      PIN_PA14
#define SENSOR_RIGHT    PIN_PA09
#define LED_TEST      PIN_PA07
struct usart_module     usart_instance;
// Function Prototypes
void configure_port_pins(void);
void configure_usart(void);
// Functions
  struct port_config config_port_pin;
24
25
  port_get_config_defaults(&config_port_pin);
26
27
  // SENSOR LEFT
28
  config_port_pin.direction = PORT_PIN_DIR_INPUT;
29
  config_port_pin.input_pull = PORT_PIN_PULL_UP;
30
  port_pin_set_config(SENSOR_LEFT, &config_port_pin);
31
32
  // SENSOR RIGHT
33
34
35
  port_pin_set_config(SENSOR_RIGHT, &config_port_pin);
36
37
  // LED TEST
38
  config_port_pin.direction = PORT_PIN_DIR_OUTPUT;
39
  port_pin_set_config(LED_TEST, &config_port_pin);
40
  port_pin_set_output_level(LED_TEST,false);
41
42
43
44
45
46
47
  struct usart_config config_usart;
48
  usart_get_config_defaults(&config_usart);
49
50
  config_usart.baudrate    = 9600;
51
  config_usart.mux_setting = USART_RX_1_TX_0_XCK_1;
52
  config_usart.pinmux_pad0 = PINMUX_PA00D_SERCOM1_PAD0;
53
  config_usart.pinmux_pad1 = PINMUX_PA01D_SERCOM1_PAD1;
54
  config_usart.pinmux_pad2 = PINMUX_UNUSED;
55
  config_usart.pinmux_pad3 = PINMUX_UNUSED;
56
  config_usart.generator_source = GCLK_GENERATOR_0;
57
58
  while (usart_init(&usart_instance,SERCOM1, &config_usart) != STATUS_OK) {
59
60
61
  usart_enable(&usart_instance);}
62
63
// Systick
64
void SysTick_Handler (void)
65
66
  static int flag = 0;
67
68
  if (flag) {
69
    flag = 0;
70
71
  } else {
72
    flag = 1;
73
    port_pin_set_output_level(LED_TEST,true);
74
75
76
77
78
// Main
79
int main (void)
80
81
  system_init();
82
83
  configure_port_pins();
84
  configure_usart();
85
86
  SysTick_Config(SystemCoreClock/1200);
87
  system_interrupt_enable(SYSTEM_INTERRUPT_SYSTICK);
88
89
  uint8_t buf[] = "Hello World\r\n";
90
  usart_write_buffer_wait(&usart_instance, buf, sizeof(buf));
91
92
        while (true) {
93
94
95
96
97
Bis auf die UART Ausgabe funktioniert soweit alles. Denke es liegt an
der Konfiguration der UART.
TX = PA00, RX = PA01
Danke im voraus.
Gast #4659329
nach etwas Suche zum Laufen gebracht.
TX = PA10
RX = PA11
neue Config:
  config_usart.mux_setting = USART_RX_3_TX_2_XCK_3;
  config_usart.pinmux_pad2 = PINMUX_PA10C_SERCOM0_PAD2;
  config_usart.pinmux_pad3 = PINMUX_PA11C_SERCOM0_PAD3;
  config_usart.pinmux_pad0 = PINMUX_UNUSED;
  config_usart.pinmux_pad1 = PINMUX_UNUSED;
  while (usart_init(&usart_instance,SERCOM0, &config_usart) != STATUS_OK) {
