STM32 CanBus cannot get out of interrupt handler
Gast #4918516
hello dear forum,
I try to make CANBUS of STM32F103RC work
I managed to make CANBUS send message in loopback mode
however when I turn on receive interrupt
the processor hangs at first message and watchdog resets the micro
 CAN_ITConfig(CAN1, CAN_IT_FMP0, ENABLE);
I suspect the code enters the interrupt handler and cannot leave it
I want to ask how do I fill following lines to reset interupt flag and
pending bit
void USB_LP_CAN1_RX0_IRQHandler(void)
CAN_ClearFlag(CAN1, ??????????);
CAN_ClearITPendingBit(CAN1,??????????);
  CanRxMsg RxMessage;
  CAN_Receive(CAN1, CAN_FIFO0, &RxMessage);
thank you
#4919285
Hey mehmet,
You use neither CAN_ClearFlag nor CAN_ClearITPendingBit. According to
the reference manual (p. 683) CAN_IT_FMP0 is set and reset by hardware.
As soon as you call CAN_Receive one message from the RX FIFO is read.
The interrupt won't be called again, as soon as the FIFO message count
has reached 0.
Greetings
