Batterie Reihenschaltung
Gast #5022100
Guten Abend zusammen, ich bin neu hier und habe eine kleine Frage.
Ich möchte die Spannung von 4 in Reihe geschalteten Batterien nutzen um
mein Arduino Uno Board mit Spannung zu Versorgen. Da jede Batterie 1,5 V
besitzt macht das eine Spannung von 6 V. Dies ist die maximum Operation
Voltage, des Atmega328P der auf dem Uno verbaut ist.
Kann ich indem ich eine Z-Diode zwischen dem Board und den Batterien
baue die Spannung die an dem Board bzw an den Mikrocontroller ankommt
dadurch verringern?
https://www.arduino.cc/en/Main/arduinoBoardUno
Power
The Arduino/Genuino Uno board can be powered via the USB connection or
with an external power supply. The power source is selected
automatically.
External (non-USB) power can come either from an AC-to-DC adapter
(wall-wart) or battery. The adapter can be connected by plugging a 2.1mm
center-positive plug into the board's power jack. Leads from a battery
can be inserted in the GND and Vin pin headers of the POWER connector.
The board can operate on an external supply from 6 to 20 volts. If
supplied with less than 7V, however, the 5V pin may supply less than
five volts and the board may become unstable. If using more than 12V,
the voltage regulator may overheat and damage the board. The recommended
range is 7 to 12 volts.
The power pins are as follows:
    Vin. The input voltage to the Arduino/Genuino board when it's using
an external power source (as opposed to 5 volts from the USB connection
or other regulated power source). You can supply voltage through this
pin, or, if supplying voltage via the power jack, access it through this
pin.
    5V.This pin outputs a regulated 5V from the regulator on the board.
The board can be supplied with power either from the DC power jack (7 -
12V), the USB connector (5V), or the VIN pin of the board (7-12V).
Supplying voltage via the 5V or 3.3V pins bypasses the regulator, and
can damage your board. We don't advise it.
    3V3. A 3.3 volt supply generated by the on-board regulator. Maximum
current draw is 50 mA.
    GND. Ground pins.
    IOREF. This pin on the Arduino/Genuino board provides the voltage
reference with which the microcontroller operates. A properly configured
shield can read the IOREF pin voltage and select the appropriate power
source or enable voltage translators on the outputs to work with the 5V
or 3.3V.
Nimm den Vin Pin. Der ist für genau so etwas da. Ich hoffe, dass du den
Arduino aus China gekauft hast und nicht wirklich 20€ dafür gezahlt
hast...
KK danke für die Antworten.
Ich verstehe das so, dass ich an den Vin Eingang eine Spannung zwischen
7-12V anlegen muss, damit das Board einwandfrei laufen kann, stimmt das?
Ja, das ist richtig.
Alternatiov kannst du den Arduino direkt an 3 Zellen betreiben, wenn du
seine Taktfrequenz auf 8Mhz reduzierst. Natürlich müssen dann auch die
anderen Bauteile drumherum für die Batteriespannung (2,7 bis knapp über
5 Volt) geeignet sein.
Bei Modulen mit USB Anschluss muss man aufpassen. Die haben meist eine
Diode, welche das Modul mit 4,5V über USB Kabel versorgen, wenn die
extern angelegte Versorgungsspannung (am 5V Pin) unter 4,5V beträgt.
Es gibt auch Arduino Module, die bereits ab Werk mit 8 Mhz getaktet
sind. Sie sind für 3,3V ausgelegt.
