GHDL --STD=08 elaborate klappt nicht
OP #5125178
Ich will das folgende "Programm" unter GHDL laufen lassen.
library STD;                            -- you don't need STD, it is automatic
library IEEE;                           -- but may need other libraries
use IEEE.std_logic_1164.all;            -- basic logic types
use STD.textio.all;                     -- basic I/O
use IEEE.std_logic_textio.all;          -- I/O for logic types
entity hello_world is
end entity hello_world;
architecture test of hello_world is -- where declarations are placed
  subtype word_32 is std_logic_vector(31 downto 0);  -- simple name
  signal four_32 : word_32 := x"00000AB4";           -- just four in hex
  signal I : integer := 0;
begin
  my_print : process is                  -- a process is parallel
               variable my_line : line;  -- type 'line' comes from textio
             begin
             L1: for I in 2 to 5 loop
               write(my_line, string'("Hello World 1"));   -- formatting
               writeline(output, my_line);               -- write to "output"
               write(my_line, string'("four_32 = "));
24
               hwrite(my_line, four_32); -- format type std_logic_vector as hex
25
26
               write(my_line, string'("  I= ")); write(my_line, I);  -- format 'counter' as integer
27
               wait for 10 ns ;
28
               write(my_line, string'(" at time ")); write(my_line, now);                     -- format time
29
               writeline(output, my_line);              -- write to display
30
             end loop L1;
31
               wait;
32
             end process my_print;
33
end architecture test;
Da ich "hwrite" verwende muss ich zum compilieren die IEEE Version 08
verwenden. Mein Aufruf:
ghdl -a --std=08  *.vhd
Danach funktioniert "elaborate" oder "run" nicht
ghdl -e hello_world
Fehler: cannot find entity or configuration hello_world
Hat einer ne Idee was ich falsch mache? Ohne "hwrite" und "std=08"
klappt alles.
  • [vhdl]VHDL-Code[/vhdl]
