Makefile Fehler bei Atmel Studio mit Arduino
Gast #5490474
Ich habe vor einiger Zeit ein Atmel Studio Projekt mit Arduino erstellt.
Das hat auch funktioniert. Jetzt habe ich versucht das Projekt auf einem
anderen PC zu öffnen jedoch bekomme ich einen Makefile Fehler:
make: *** No rule to make target
'C:/Users/Bfm2Fe/Desktop/Men├╝/ArduinoSketch1/ArduinoSketch1/ArduinoCore
/Debug/libArduinoCore.a',  needed by 'sketch_apr09a.elf'.  Stop.
Kann mir jemand sagen, was das zu bedeuten hat und wie ich den fehler
beheben kann?
Viele Grüße
Max
------ Build started: Project: ArduinoCore, Configuration: Debug AVR
Build started.
Project "ArduinoCore.cppproj" (default targets):
Target "PreBuildEvent" skipped, due to false condition;
('$(PreBuildEvent)'!='') was evaluated as (''!='').
Target "CoreBuild" in file "C:\Program Files
(x86)\Atmel\Studio\7.0\Vs\Compiler.targets" from project
"C:\Users\Bfm2Fe\Desktop\Menü\ArduinoSketch1\ArduinoSketch1\ArduinoCore\
ArduinoCore.cppproj"  (target "Build" depends on it):
  Using "RunCompilerTask" task from assembly "C:\Program Files
(x86)\Atmel\Studio\7.0\Extensions\Application\AvrGCC.dll".
  Task "RunCompilerTask"
    Shell Utils Path C:\Program Files (x86)\Atmel\Studio\7.0\shellUtils
    C:\Program Files (x86)\Atmel\Studio\7.0\shellUtils\make.exe all
--jobs --output-sync
    make: Nothing to be done for 'all'.
  Done executing task "RunCompilerTask".
  Using "RunOutputFileVerifyTask" task from assembly "C:\Program Files
  Task "RunOutputFileVerifyTask"
  Done executing task "RunOutputFileVerifyTask".
Done building target "CoreBuild" in project "ArduinoCore.cppproj".
Target "PostBuildEvent" skipped, due to false condition;
('$(PostBuildEvent)' != '') was evaluated as ('' != '').
Target "Build" in file "C:\Program Files
(x86)\Atmel\Studio\7.0\Vs\Avr.common.targets" from project
ArduinoCore.cppproj"  (entry point):
Done building target "Build" in project "ArduinoCore.cppproj".
Done building project "ArduinoCore.cppproj".
Build succeeded.
------ Build started: Project: sketch_apr09a, Configuration: Debug AVR
Build started.
Project "sketch_apr09a.cppproj" (default targets):
"C:\Users\Bfm2Fe\Desktop\Menü\ArduinoSketch1\ArduinoSketch1\sketch_apr09
a\sketch_apr09a.cppproj"  (target "Build" depends on it):
  Done executing task "RunCompilerTask" -- FAILED.
Done building target "CoreBuild" in project "sketch_apr09a.cppproj" --
FAILED.
Done building project "sketch_apr09a.cppproj" -- FAILED.
Build FAILED.
========== Build: 1 succeeded or up-to-date, 1 failed, 0 skipped
In Zeile 108 wird nach nach dem Target '...libArduinoCore.a' gesucht,
dass in der Variablen LIB_DEP steckt.
Das Target existiert aber in deinem Makefile nicht. Generell versuchst
du Libraries und Linker-Skript als prerequisites zu übergeben anstatt
sie als Flags dem Compiler zu übermitteln.
Du brauchst beim Linken sowas wie '-lArduinoCore' und
'-TLinkerscript.ld'. Ich würde empfehlen im Netz noch einige Makefile
Beispiele zu lesen. Zum Beispiel sowas hier:
https://spin.atomicobject.com/2016/08/26/makefile-c-projects/
Hallo nochmal.
Natürlich habe ich die Lösung direkt gefunden, nachdem ich den Beitrag
geschrieben hatte. Das Problem war, dass das Projekt im Ordner Menü war.
Das ü hat dem Compiler wohl nicht gefallen. Jetzt funktioniert alles.
Viele Grüße
Max
