Arduino Sketch kompiliert nicht
Gast #6246926
ich will den Sketch für folgende Wordclock
(https://www.panbachi.de/eigene-word-clock-bauen/) kompilieren.
Jedoch bekomme ich folgende Fehler:
In file included from C:\Users\myUser\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.6.3/tools/sdk/libc/xtensa-lx106-elf/include/sys/stdio.h:6:0,
                 from C:\Users\myUser\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.6.3/tools/sdk/libc/xtensa-lx106-elf/include/stdio.h:63,
                 from C:\Users\myUser\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.6.3\cores\esp8266/Arduino.h:32,
                 from C:\Users\myUser\AppData\Local\Temp\arduino_build_204606\sketch\wordclock.ino.cpp:1:
C:\Users\myUser\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.6.3/tools/sdk/libc/xtensa-lx106-elf/include/sys/pgmspace.h:25:130: error: 'const char HTTP_HEAD []' redeclared as different kind of symbol
   #define PROGMEM __attribute__((section( "\".irom.text." __FILE__ "." __STRINGIZE(__LINE__) "."  __STRINGIZE(__COUNTER__) "\"")))
D:\Arduino\libraries\WiFiManager/WiFiManager.h:25:24: note: in expansion of macro 'PROGMEM'
 const char HTTP_HEAD[] PROGMEM            = "<!DOCTYPE html><html lang=\"en\"><head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1, user-scalable=no\"/><title>{v}</title>";
In file included from D:\wordclock\wordclock\wordclock.ino:4:0:
C:\Users\myUser\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.6.3\libraries\ESP8266WebServer\src/ESP8266WebServer.h:33:39: error: previous declaration of 'HTTPMethod HTTP_HEAD'
24
25
 enum HTTPMethod { HTTP_ANY, HTTP_GET, HTTP_HEAD, HTTP_POST, HTTP_PUT, HTTP_PATCH, HTTP_DELETE, HTTP_OPTIONS };
26
27
28
29
In file included from D:\wordclock\wordclock\wordclock.ino:6:0:
30
31
D:\Arduino\libraries\FastLED/FastLED.h:14:21: note: #pragma message: FastLED version 3.003.003
32
33
 #    pragma message "FastLED version 3.003.003"
34
35
36
37
In file included from D:\Arduino\libraries\FastLED/FastLED.h:65:0,
38
39
40
41
D:\Arduino\libraries\FastLED/fastspi.h:130:23: note: #pragma message: No hardware SPI pins defined.  All SPI access will default to bitbanged output
42
43
 #      pragma message "No hardware SPI pins defined.  All SPI access will default to bitbanged output"
44
45
46
47
Mehrere Bibliotheken wurden für "NTPClient.h" gefunden
48
 Benutzt: D:\Arduino\libraries\NTPClient
ESP8266Core@2.6.2
Arduino@1.8.12
Alle benötigten Libraries sind installiert.
Danke im Vorraus!
Gast #6247011
Du wirst was ändern müssen.
HTTP_HEAD ist doppelt definiert.
Die Orte werden dir in der Meldung gezeigt.
Eine Möglichkeit: Umbenennen
Eine andere: Andere Libraies verweden
(Firma: MiGo Innovations) #6285070
Dear! There is an error message of re-declaration of a variable you have
used in you code, HTTP_HEAD, remove that repeat declaration and then try
for compiling, I hope you issue will get resolved. Here I would like to
recommend you to get connect with the Sierra Software Ltd. platform
technical support team for getting better assistance regarding your
queries and project online support.
