How to configure NAND-Flash/SDRAM Memory. Basics
Gast #6616788
I'm looking for basic tutorial how to connect NAND-Flash /SDRAMs to uC
STM32 and how to set the parameter for this type of memory. The
reference manual of STM32 assumes that you know how the memory works and
assumes which signal what is it intended for... Where to learn that?
Thank you very much for your help.
Gast #6616847
first step look at the BSPs of a ST Eval Board with the memory type you
want to use. Try to calculate the timings shown in the BSPs by your own
with the memory datasheet and clock settings of the STM32.
Gast #6617330
@drm Thank yout
But, I need the basics. E.g. NAND Flash: what is the difference between
8 and 16 bit, how are the cells addressed by an 8-bit bus even though it
contains 1GBit? what RAS, CASL, CASH? how is that timming? etc. the same
goes for SDRAM. Maybe someone has a book recommendation or application
notes?
Gast #6617352
@stefan
Realy!
That's all what I need to connect my NAND-Flash and SDRAM and configure
them?
That sounds if somebody never heard about microcontrollers "courses at
the uni" and he should just read the reference manual of this uC. After
that he will be able to program all the peripheral UART, SPI, Ethernet,
CAN uso...
I assume nobody is born with those knowledge.
Either he has a course at the university, or read books about it, or or
or
Gast #6617370
May that all this is and was an historical way
by time and steps: is in use, by get-able and how to use.
Sorry, may all this is in Arduino references foundable, it seems so.
Dirk St
(Firma: matzetronics) #6617413
Have a look at the 'system_stm32xxxx'.c file. ST provides examples for
configuring SDRAM or SRAM on the FMC during startup - at least, if you
are using the SPL. I've no idea if Cube does this, too.
Of course the FMC is necessary for this.
External Flash Memory doesn't differ very much from SRAM when it comes
to reading but writing routines will probably be a task for you to
create.
Gast #6617423
Programming a microcontroller is a different topic than connecting a
memory IC. You asked for the memory IC.
For programming a microcontroller you may buy a book or work through
tutorials. Learning that takes usually several years.
Doing both together would be a very bad idea.
Start with a blinking LED - as everybody does.
Gast #6617468
@stefan
you does not understand my irony. Of course I can already program uc. I
mean: Imagine someone who has never programmed uc and asks you how can
he do that. You tell him just read the reference manual instead of a
book about uc. Got it now?.
OK. I formulate my question like this:
anyone know a book or scripts or good site about NAND flash and SDRAM
memories?
Thanks.
Gast #6617662
You do not understand what I meant in my first answer. There is no
general instruction how to access NAND flash and SDRAM memories. Each IC
has its own interface with its own description.
You need to access the chip as specified in its specfic interface
description. Regardless if the internal cells are in NAND or whatever
else technology.
#6617881
Moin,
There was a Book >40 years ago:
Rodnay Zaks, Austin Lesea : Microprocessor interfacing techniques.
That's from where i got my initial knowledge about DRAM (SDRAM, NAND
Flash, and other fancy stuff was not invented yet) and other basic
things needed for microprocessors.
Rest of knowledge indeed came from datasheets or schematics.
Gruss
WK
Gast #6618343
in essence on how to use external memory with an uC:
configure the memory controller of your uC to generate the waveforms
expected by the external memory to read or write data.
Thats it, not less or more. You just have to look up the different
waveforms which are unique to each memory device, not only for a class
of memory type.
Gast #6618490
Hi Guys,
thank you very much for your plenty replys and discutions. Especialy to
@DerguteWeka for recommending a concret book "Microprocessor interfacing
techniques". That's what I have expected from this topic.unfortunately
the libraries are closed/limited because of this corona plandemic. If
someone gives me the title of a new book about the topic that I can buy
online, I will be very happy.
Thanks.
