openocd + ice
Gast #6653354
ich wollte einen SAMD21J17D mittels openocd flashen aber bekomme
komische fehlermeldungen. Mit microchip studio funktioniert es:
openocd.ocd
# Atmel-ICE JTAG/SWD in-circuit debugger.
# get serial: lsusb -vd 03eb:2111 | grep iSerial
interface cmsis-dap
#cmsis_dap_vid_pid 0x03eb 0x2111
#cmsis_dap_serial ATML2130021800030238
# Chip info
set CHIPNAME at91samd21j17d
source [find target/at91samdXX.cfg]
Ausgabe openocd:
Open On-Chip Debugger 0.9.0 (2018-01-24-01:05)
Licensed under GNU GPL v2
For bug reports, read
  http://openocd.org/doc/doxygen/bugs.html
Info : only one transport option; autoselect 'swd'
adapter speed: 500 kHz
adapter_nsrst_delay: 100
cortex_m reset_config sysresetreq
Info : CMSIS-DAP: SWD  Supported
Info : CMSIS-DAP: JTAG Supported
Info : CMSIS-DAP: Interface Initialised (SWD)
Info : CMSIS-DAP: FW Version = 1.0
Info : SWCLK/TCK = 1 SWDIO/TMS = 1 TDI = 1 TDO = 1 nTRST = 0 nRESET = 1
Info : CMSIS-DAP: Interface ready
Info : clock speed 500 kHz
Info : SWD IDCODE 0x0bc11477
Info : at91samd21j17d.cpu: hardware has 4 breakpoints, 2 watchpoints
Info : accepting 'gdb' connection on tcp/3333
Error: Couldn't find part correspoding to DID 10012692
Error: auto_probe failed
Error: Connect failed. Consider setting up a gdb-attach event for the target to prepare target for GDB connect, or use 'gdb_memory_map disable'.
Error: attempted 'gdb' connection rejected
gdb:
arm-none-eabi-gdb -iex "target extended-remote localhost:3333" xxxxxx.elf
GNU gdb (GNU Tools for Arm Embedded Processors 9-2019-q4-major) 8.3.0.20190709-git
Copyright (C) 2019 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Type "show copying" and "show warranty" for details.
This GDB was configured as "--host=x86_64-linux-gnu --target=arm-none-eabi".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
    <http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Remote debugging using localhost:3333
Remote communication error.  Target disconnected.: Connection reset by peer.
Gast #6653402
Sieht schon ziemlich gut aus und hätte fast funktioniert.
Die entscheidenden Hinweise solltest Du finden, wenn Du die Zeile
einer Suchmaschine vorwirfst.
Evtl. ist Deine OOCD Version zu alt.
Am besten aus dem OOCD Git repo holen und übersetzen (wenn Du Linux
benutzt)
git repo root dir: /home/xxx/xxxx/openocd:
  url = git://repo.or.cz/openocd.git
  url = http://repo.or.cz/r/jimtcl.git
  url = http://repo.or.cz/r/libjaylink.git
  url = http://repo.or.cz/r/git2cl.git
Sonst evtl. nach einen Binary aus vertrauenswürdiggen Quellen suchen.
Die GDB Meldungen sind Folgefehler.
Gast #6654087
Danke sehr,
Ja die openocd version war einfach zu alt für den ICE mit neuerer
Firmware. Ich hatte noch "Open On-Chip Debugger 0.9.0
(2018-01-24-01:05)" installiert. Nun habe ich den neuesten installiert.
vielen dank :D
