C++17: Typ-List in Matrix expanden und an template Funktion
Gast #6798148
C++17 VStudio 2017/oder gcc/clang
  template <typename First, typename Second>
  void test_combination( void* data_ )
     //test code
  void test_combinations(void* data_)
    //muss kein tuple sein - koennte auch direkt als
    //Variadic hier drin stehen
    using All_types = std::tuple<int,Test,float,Blub/*,...*/>;
    test_combination(...)
jetzt wuerde ich gerne die test_combination so instanzieren das ich alle
Typ -Kombinationen durchlaufen
also
test_combinations(...)
  expandiert zu
test_combination<int,int>(data)
test_combination<int,Test>(data)
test_combination<int,float>(data)
test_combination<int,Blub>(data)
test_combination<int,...>(data)
test_combination<Test,int>(data)
test_combination<Test,Test>(data)
test_combination<Test,float>(data)
test_combination<Test,Blub>(data)
test_combination<Test,...>(data)
Gast #6798498
habs so geloest - geht das noch kuerzer?
   //test code
template <typename First, typename... Types>
void test_combination_helper2( void* data_ )
  ( ( test_combination<First, Types>( data_ ) ), ... );
template <typename... Types>
void test_combination_helper1( void* data_ )
  ( ( test_combination_helper2<Types, Types...>(data_) ), ... );
void test_combinations( void* data_ )
  test_combination_helper1<int,Test,float,Blub/*,...*/>( data_ );
