STM32H750 DMA und SAI2
Gast #6849166
hi
Ich habe einen STM32H750 und veruche einen Codec am SAI2 zu betreiben
Leider bekomme ich keinen Takt und er startet auch nicht.
HAL_SAI_Transmit_DMA() bleibt intern im Timeout hängen schlägt
schließlich fehl.
Taktquelle ist PLL2
  PeriphClkInitStruct.PLL2.PLL2M = 4;
  PeriphClkInitStruct.PLL2.PLL2N = 30;
  PeriphClkInitStruct.PLL2.PLL2P = 39;
  PeriphClkInitStruct.PLL2.PLL2Q = 128;
  PeriphClkInitStruct.PLL2.PLL2R = 2;
  PeriphClkInitStruct.PLL2.PLL2RGE   = RCC_PLL2VCIRANGE_3;
  PeriphClkInitStruct.PLL2.PLL2VCOSEL = RCC_PLL2VCOWIDE;
  PeriphClkInitStruct.PLL2.PLL2FRACN   = 0;
  PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_SAI2
  PeriphClkInitStruct.Sai23ClockSelection  = RCC_SAI23CLKSOURCE_PLL2;
  hsai_output.Instance         = SAI2_Block_A;
  hsai_output.Init.AudioMode       = SAI_MODEMASTER_TX;
  hsai_output.Init.Synchro      = SAI_ASYNCHRONOUS;
  hsai_output.Init.MckOutput      = SAI_MCK_OUTPUT_ENABLE;
  hsai_output.Init.OutputDrive     = SAI_OUTPUTDRIVE_DISABLE;
  hsai_output.Init.NoDivider       = SAI_MASTERDIVIDER_ENABLE;
  hsai_output.Init.FIFOThreshold     = SAI_FIFOTHRESHOLD_FULL;
  hsai_output.Init.AudioFrequency   = SAI_AUDIO_FREQUENCY_8K;
  hsai_output.Init.SynchroExt     = SAI_SYNCEXT_DISABLE;
  hsai_output.Init.MonoStereoMode   = SAI_STEREOMODE;
  hsai_output.Init.CompandingMode   = SAI_NOCOMPANDING;
  hsai_output.Init.TriState       = SAI_OUTPUT_NOTRELEASED;
  if (HAL_SAI_InitProtocol(&hsai_output, SAI_I2S_STANDARD, SAI_PROTOCOL_DATASIZE_16BIT, 2) != HAL_OK){
    Error_Handler();
  hsai_input.Instance         = SAI2_Block_B;
  hsai_input.Init.AudioMode       = SAI_MODESLAVE_RX;
  hsai_input.Init.Synchro       = SAI_SYNCHRONOUS;
  hsai_input.Init.OutputDrive     = SAI_OUTPUTDRIVE_DISABLE;
  hsai_output.Init.MckOutput      = SAI_MCK_OUTPUT_DISABLE;
23
24
25
26
27
28
  if (HAL_SAI_InitProtocol(&hsai_input, SAI_I2S_STANDARD, SAI_PROTOCOL_DATASIZE_16BIT, 2) != HAL_OK){
29
    Error_Handler();
30
31
mir fehlt irgendwie die Tabelle welcher DMA stream interrupt für SAI
zuständig ist.
Die neuen H7 haben ja den DMAMUX
Cube verwendet daher immer :
  hdma_sai2_a.Instance           = DMA1_Stream0;
  hdma_sai2_a.Init.Request         = DMA_REQUEST_SAI2_A;
  hdma_sai2_a.Init.Direction         = DMA_MEMORY_TO_PERIPH;
   hdma_sai2_b.Instance         = DMA1_Stream1;
    hdma_sai2_b.Init.Request       = DMA_REQUEST_SAI2_B;
    hdma_sai2_b.Init.Direction       = DMA_PERIPH_TO_MEMORY;
Gibt es eine tabelle welcher DMAx_Stream_xx verwendet werden soll
oder ist das wirklich egal?
Gast #6851396
der Interrupt wird genau 1x ausgeführt
aber bei dem half ISR deaktiviert:
          /* Disable the half transfer interrupt if the DMA mode is not
CIRCULAR */
          if((((DMA_Stream_TypeDef   *)hdma->Instance)->CR &
DMA_SxCR_CIRC) == 0U)
            /* Disable the half transfer interrupt */
            ((DMA_Stream_TypeDef   *)hdma->Instance)->CR  &=
~(DMA_IT_HT);
der witz daran ist das bei der ini das CIRCULAR bit gesetzt wurde !!
#6851915
Moin,
Das bewirkt, dass Du Takte erst dann hast, wenn Du das Device aktiviert
hast, sprich das EN bit im SAI_xCR1 Register gesetzt hast. Dafür sollte
es auch einen entsprechenden Aufruf in der HAL geben.
>Gibt es eine tabelle welcher DMAx_Stream_xx verwendet werden soll oder ist das
wirklich egal?
Das ist egal. Die 16 Kanäle können frei belegt werden. Das dürfte die
HAL auch entsprechend dynamisch verwalten, wenn ich mich recht erinnere.
Welchen Speicherbereich benutzt Du für die DMA? Die beiden
DMA-Controller können nur auf Speicher in der Domain 2 zugreifen
(0x24000000 - 0x24080000).
Micha
Gast #6852187
hi
danke für die Antwort
Habe es herausgefunden!!  -> eigener Bockmist !!
der DMA2 CLK wurde erst mit SAI2_B  aktiviert
damit war das Register der TX DMA quasi nicht gesetzt
bei dem STM32F7xx der vorher im einsatz war waren SAI A und B vertauscht
( B -Y TX   und A RX )
Speicherbereiche musste ich dennoch anpassen
Liegen nun in in der richtigen section
Der H7 ist da deutlich empfindlicher  gegenüber dem F7
