Benutzer Diskussion:Makerfabs
Makerfabs (www.makerfabs.com)
This is an Arduino Nano + NodeMCU IOT Kit for starters. The kit includes two main Boards: Arduino Nano and NodeMCU mini, and 18 Kinds of the most popular used sensors and actuators such as Ultrasonic Ranger, OLED, stepper driver, etc. A breadboard and some jumper wires are also included to make this kit appropriate for starters using the kit by plug-and-play. With this kit, you can easily create you own IOT project by using any programming tools such as Arduino IDE, Visuino, Lua or RAD Studio. This kit is an official kit for IOT Boot Camp 2017 that is powered by RAD Studio (Delphi or C++Builder)+ RAD Server+ Visuino.
Package List: 1 x Arduino Nano v3 1 x NodeMCU Mini 1 x HC-05 Serial Bluetooth Module 1 x IR receiver 1 x IR Transmitter 1 x Infrared Remote Controller 1 x 28BYJ-48 Stepper motor-5V 1 x ULN2003 Stepper Motor Driver 1 x Tower Pro 9g SG-90 Mini Servo 1 x MPU6050 3-Axis Acceleration Gyroscope 6DOF Module 1 x HC-SR04 Ultrasonic Range Measurement Module 1 x DHT11 Temperature& Humidity Module 1 x Light Sensor Module 1 x EC11 Encoder 1 x 1-Channel Relay Module-10A 1 x Analog 2-axis Thumb Joystick with Select Button 2 x Hat Button Module 1 x 10mm RGB LED Module 1 x Sealed Membrane 4X4 Button Pad With Sticker 1 x 0.96" I2C OLED 128x64- Blue 1 x Breadboard- 8.3x5.5cm 1 x 40 pin dual male splittable jumper wire - 20cm 1 x 40 pin dual female splittable jumper wire- 20cm 1 x 40 pin male female splittable jumper wire - 20cm 1 x Micro USB cable ====
Beschreibung2]]
Beschreibung1
Beschreibung2
</gallery>
