PDF
93LC66.pdf
Section 3.4. DS21795A-page 2 2003 Microchip Technology Inc. 93AA66A/B/C, 93LC66A/B/C, 93C66A/B/C AC CHARACTERISTICS All parameters apply over the specified VCC = range by device (see Table on Page 1) Industrial (I):TAMB= -40°C to +85°C ranges unless otherwise noted. Automotive (E): TMB= -40°C to +125
PDF
T6963C.pdf
MD2 = H, MD3 = H, FS0 = L, FS1 = SDSEL = L, DUAL = H, D7 to D0 = LHLHLHLH 2001-02-28 28/46 T6963C Ac Characteristics ● Switching Characteristics (1) Test Conditions (Unless Otherwise Noted, V DD = 5.0 V ± 10%, V SS = 0 V, Ta = −20 to 70°C) Item Symbol Test Conditions Min Max Unit Operating Frequency
in „[V] Grafikdisplay 240x128“ · Markt ·
Datei
ch552.pas
var PSW : sfr absolute $D0; volatile; // program status word CY : sbit absolute PSW.7; // carry flag AC : sbit absolute PSW.6; // auxiliary carry flag F0 : sbit absolute PSW.5; // bit addressable general purpose flag 0 RS1 : sbit absolute PSW.4; // register R0-R7 bank selection high bit RS0 : sbit absolute
in „Turbo51 und CH55x“ · Mikrocontroller und Digitale Elektronik ·
PDF
AD8610_8620.pdf
thefrequencyresponseofthefilter.The V+ useofhighperformanceamplifiers,suchastheAD8610/AD8620, minimizesboth dc and ac errors in all active filter applications. 8 +INA 3 Second-Order,Low-PassFilter 1/2 AD8620 1 U1 Figure 69 shows the AD8610 configured as a second-order, 2 4 Butterworth, low-pass filter. With the values
in „Regelbare Stromqulle verstehen“ · Analoge Elektronik und Schaltungstechnik ·
PDF
ad9833.pdf
resolution. 10-leadMSOP package The AD9833 is written to via a 3-wire serial interface. This serial AEC-Q100 qualified forautomotiveapplications interface operates at clock rates up to 40 MHz and is APPLICATIONS compatible with DSP and microcontroller standards. The Frequency stimulus/waveformgeneration
in „Aus ca. 0,3V Wechselspannung (Sinus) 15 V Wechselspannung machen“ · Analoge Elektronik und Schaltungstechnik ·
PDF
T6963C.pdf
L, MD2 = H, MD3 = H, FS0 = L, FS1 = SDSEL = L, DUAL = H, D7 to D0 = LHLHLHLH 29 2002-01-07 T6963C Ac Characteristics ● Switching Characteristics (1) Test Conditions (Unless Otherwise Noted, V DD = 5.0 V ± 10%, V SS = 0 V, Ta = −20 to 70°C) Item Symbol Test Conditions Min Max Unit Operating Frequency
in „altes Phytec MCB-51 Monitor/Basic Befehle?“ · Mikrocontroller und Digitale Elektronik ·
PDF
SSD1306-Revision_1.1__Charge_Pump__1_.pdf
.............................................................................................48 13 AC CHARACTERISTICS.....................................................................................................49 14 APPLICATION EXAMPLE..........................................................
in „5V an den Datenleitungen?“ · Mikrocontroller und Digitale Elektronik ·
PDF
LTC2418.pdf
parallel terminated near the process.Undershootandovershootcanoccurbecauseof converter, substantial AC current is flowing in the loop formedbytheF cOnnectiontrace,theterminationandthe the impedance mismatch at the converter pin when the ground return path. Thus, perturbation signals may be transition
in „4-kanal PT100 Multiplexer 24bit Schaltung, Messbrücke, ratiometrisch, c't lab“ · Analoge Elektronik und Schaltungstechnik ·
PDF
SSD1306.pdf
in „OLED Grafik Anzeige“ · Mikrocontroller und Digitale Elektronik ·
PDF
LED_Display_driver_chip_SSD1306_DataSheet.pdf
.............................................................................................52 13 AC CHARACTERISTICS.....................................................................................................53 14 APPLICATION EXAMPLE..........................................................
in „Spannungsversorgung Arduino läuft nicht über Vin oder 5V-Pin“ · Mikrocontroller und Digitale Elektronik ·
PDF
in „SSD1306/1309 Library zum Darstellen von Text auf OLED Displays“ · Projekte & Code ·
PDF
SSD1306.pdf
in „SH1106 Init-Sequenz“ · Mikrocontroller und Digitale Elektronik ·
PDF
Solomon_Systech_LED_Display_driver_chip_SSD1306.pdf
in „Mit Wire.h über I2C auf LCD-Display 1602 zugreifen“ · Mikrocontroller und Digitale Elektronik ·
PDF
PDF
gps-spec-IS_GPS_200J.pdf
.................................................................................................. 187 30.3.4.2 SV Time vs. GPS Time............................................................................................................. 188 30.3.4.3 Speed of Light................................
in „Magisches Auge für GPS-Empfänger“ · Mikrocontroller und Digitale Elektronik ·
PDF
TMC262_datasheet.pdf
........................18.1..16O PERATIONALR ANGE..................................51 18.2 DC AND AC SPECIFICATIONS......................51 6.1 BUS SIGNALS ...............................................16 6.2 BUS TIMING .....................................19...PACKAGE MECHANICAL DATA..............
in „Wärmeentwicklung Mosfet“ · Mikrocontroller und Digitale Elektronik ·
PDF
AD7416_7_8_f.pdf
Output Fall Time, t 250 ns C = 400 pF, I = 3 mA f L O OS Output Low Voltage, V OL 0.8 V IOUT = 4 mA 2 AC ELECTRICAL CHARACTERISTICS AD7416/AD7417/AD7418 Serial Clock Period,1t 2.5 ms See Figure 1 Data In Setup Time to SCL High, t 50 ns See Figure 1 2 Data Out Stable after SCL Low, t3 0 ns See Figure 1 SDA
in „I²C-Code - fehlt noch was?“ · Mikrocontroller und Digitale Elektronik ·
Datei
Steu4414.asm
+ ld r19, Y+ ld r18, Y+ ld r17, Y+ ld r16, Y+ ld r3, Y+ ld r2, Y+ reti ; Referenced from offset 0x4ac by rcall Function3: in r16, USR andi r16, 0x80 ; 128 ret ; Referenced from offset 0x27a by rcall ; Referenced from offset 0x4a4 by rcall ; Referenced from offset 0x4d2 by rcall ; Referenced from offset
in „Gerät mit AT90S4414 retten“ · Mikrocontroller und Digitale Elektronik ·
PDF
tpa3244.pdf
extended periods may affect device reliability. (2) These voltages represents the DC voltage + peak AC waveform measured at the terminal of the device in all conditions. 7.2 ESD Ratings VALUE UNIT Human body model (HBM), per ANSI/ESDA/JEDEC JS-001, all ±1000 V pins(1) VESD Electrostatic discharge Charged
in „Class-D Verstärker TPA3244“ · Analoge Elektronik und Schaltungstechnik ·
Datei
hardware_t.cpp
backup MenuStatus[MENU_CHANNEL2][0] = 8; // Channel 2 - Coupling AC MenuStatus[MENU_CHANNEL2][1] = 240; // Channel 2 - BW Limit off MenuStatus[MENU_CHANNEL2][2] = 240; // Channel 2 - Invert off MenuStatus[MENU_CHANNEL2][3] = 104; // Channel 2 - Probe 1.0 : 1 MenuPopupStatus
in „Wittig(welec) DSO W20xxA Open Source Firmware (Teil3)“ · Mikrocontroller und Digitale Elektronik ·
PDF
AM335x_Sitara_Prozessor.pdf
LCD_MEMORY_CLK-LCD_DATAI) LCD_DATA[15:0] invalid (write) 0 ns Delay time, LCD_MEMORY_CLK high to 6 td(LCD_MEMORY_CLK-LCD_AC_BIAS_ENLCD_AC_BIAS_EN 0 6.8 ns 7 tt(LCD_AC_BIAS_EN) Transition time, LCD_AC_BIAS_EN 1 10 ns Delay time, LCD_MEMORY_CLK high to 8 td(LCD_MEMORY_CLK-LCD_VSYNC) 0 7 ns LCD_VSYNC 9 tt(LCD_VSYNC) Transition
in „BeagleboneBlack: Sensor über I2C“ · Mikrocontroller und Digitale Elektronik ·
PDF
GC9306_DS_V1.01.pdf
h (13E,EE)h (13E,EF)h (13F,00)h (13F,01)h …… … (13F,ED)h (13F,EE)h (13F,EF)h 5.2. Address Counter (AC) of GRAM The GC9306 contains an address counter (AC) which assigns address for writing/reading pixel data to/from GRAM. The address pointers set the position of GRAM. Every time when a pixel data is written into the GRAM, the X address or Y address of AC will be automatically increased by 1 (or decreased by 1), which is decided by the register (MV, MX and MY bits) setting. To simplify the address control of GRAM access, the window address function allows
in „Einzelne Pixel bei TFT mit GC9306/ILI9341“ · Mikrocontroller und Digitale Elektronik ·
PDF
8020_8021_Users_Manual.pdf
instrument is not intended for operation from two thattheshipmentiscomplete. phases of a multiphase ac system or across the legs of a 2-3. PERFORMANCE CHECKS single-phase, three-wire ac power system. Crest factor (ratioofpeakvoltagetorms)shouldbetypicallywithinthe The instrument was carefully inspected
in „Handbuch für Funktionsgenerator Kontron 8021 gesucht“ · Offtopic ·
PDF
Ferroxcube_Data_Handbook.pdf
Ferrites Applications P ULSE TRANSFORMERS GENERAL PURPOSE TRANSFORMERS POWER TRANSFORMERS Pulse or AC signals are transmitted and if required Apowertransformertransmits energy,transformsvoltage transformed to a higher or lower voltage level. Also to the required level and provides galvanic separation
in „Maximale Magnetflussdichte im Ferritkern Temperaturangabe“ · Analoge Elektronik und Schaltungstechnik ·
PDF
NovaComm_Control_Interface_User_Guide_Ver.2.3.pdf
Guide Ver.2.3 OK<CR><LF> response from the module to indicate the command is adopted. 5.1.31. AC—Read voltage of AIO 5.1.31.1. Description: This command can read the voltage of a specified AIO pin. The Bluetooth module will read and report the voltage of specified AIO by the Indicator AC. 5.1.31.2
in „Mini Bluetooth Module mit SPP und AT Command set“ · Mikrocontroller und Digitale Elektronik ·
PDF
esp32-c3_technical_reference_manual_en.pdf
Architectural Overview 185 6.1.3 Features 185 6.1.4 Functional Description 186 6.2 Clock 186 6.2.1 Overview 187 6.2.2 Architectural Overview 187 6.2.3 Features 187 6.2.4 Functional Description 188 Espressif Systems 6 ESP32-C3 TRM (Version 1.1) Submit Documentation Feedback Contents GoBack 6.2.4.1 CPU Clock 188
in „Mit dem ESP32C3 laufen lernen“ · Mikrocontroller und Digitale Elektronik ·
PDF
in „ESP32C3 > PLL“ · Mikrocontroller und Digitale Elektronik ·
PDF
AVR128DA28_32_48_64.pdf
Multiplexer 16.3.10 ACn Pin Position Name: ACROUTEA Offset: 0x09 Reset: 0x00 Property: - Bit 7 6 5 4 3 2 1 0 AC2 AC1 AC0 Access R/W R/W R/W Reset 0 0 0 Bit 2 – AC2 Analog Comparator 2 Output This bit controls the pin position for AC2 output. Value Name Description 0x0 DEFAULT OUT on PA7 0x1 ALT1 OUT on PC6 Bit 1 – AC1 Analog comparator 1 Output This bit controls the pin position for AC1 output. Value Name Description 0x0 DEFAULT OUT on PA7 0x1 ALT1 OUT on PC6 Bit 0 – AC0 Analog Comparator 0 Output This bit controls
in „AVR64EA28: PIT-Interrupt“ · Mikrocontroller und Digitale Elektronik ·
PDF
siplace-s27hm.pdf
circuit-breaker 1 x 6A - AC 00362661-01 F7, F10, F11 Miniature circuit-breaker 1 x 6A - DC 00302818-01 K1 Combined protective device 3TK28050AC2 00321067-01 K2 Combined protective device 3TK28040AC2 00320030-01 64 Service Manual
in „Siplace 80 Potentialverteiler“ · Mikrocontroller und Digitale Elektronik ·
PDF
PIC12F508_Datasheet.pdf
................................................................................... 69 11.0 DC and AC Characteristics Graphs and Charts......................................................................................................................... 81 12.0 Packaging Information...............
in „Funktion Reifendruckanlerngerät EL-50448; OEC-T5; Welches Bauelement ist das?“ · Fahrzeugelektronik ·
PDF
PIC12F508.pdf
PDF
252039.pdf
......................................................................................... 256 13.5 AC C HARACTERISTICS ......................................................................................................... 257 13.5.1 Host interface ..................................................
in „LCD Display / Controller eines Schweißgerätes prüfen“ · Mikrocontroller und Digitale Elektronik ·
PDF
stc32g-en.pdf
Control Register (IAP_CONTR)........................................................................... 187 8.1.3 Reset Configuration Register (RSTCFG)................................................................. 187 8.1.4 Reset Flag Register (RSTFLAG) .................................................
in „STC32 -- 8051 auf Steroide“ · Mikrocontroller und Digitale Elektronik ·
PDF
AVR_ATmega_328PB.pdf
.168 21. Timer/Counter0 and Timer/Counter1,3,4 Prescalers.............................................187 21.1. Internal Clock Source...............................................................................................................187 21.2. Prescaler Reset........................................................................................................................187 21.3. External Clock Source..............................................................................................................187 21.4. Register Description...............................
in „ATmega328PB: UART(MC) empfängt falsche Daten“ · Mikrocontroller und Digitale Elektronik ·
Datei
ch552_keil.h
/* System Registers */ sfr PSW = 0xD0; // program status word sbit CY = PSW^7; // carry flag sbit AC = PSW^6; // auxiliary carry flag sbit F0 = PSW^5; // bit addressable general purpose flag 0 sbit RS1 = PSW^4; // register R0-R7 bank selection high bit sbit RS0 = PSW^3; // register R0-R7 bank selection
in „uC für 0,20€ CH552 / CH554 von WCH Billig Micro mit USB Funktion, Chip vorstellung“ · Mikrocontroller und Digitale Elektronik ·
Datei
ch552_keil.h
PDF
0901.3482v1.pdf
isters are mapped, and 4 KBytes of physical SRAM. is used for persistent data storage. This memory is ac- exploit buffer overflow to execute malicious code injected by cessed as an external device from a serial bus. It is not a specially-crafted packet. accessible as a regular memory and is typically used
in „Mikrocontroller Viren“ · Offtopic ·
PDF
PIC_32_MX_110_F_016_-_I-SO__11-2-3___SO_28_.pdf
interrupts on all I/O pins Advanced Analog Features • ADC Module: Qualification and Class B Support • AEC-Q100 REVG (Grade 2 -40ºC to +105ºC) planned - 10-bit 1.1 Msps rate with one S&H • Class B Safety Library, IEC 60730 - Up to 10 analog inputs on 28-pin devices and 13 analog inputs on 44-pin devices
in „pic32 flash und i/o speed“ · Mikrocontroller und Digitale Elektronik ·
PDF
PIC_32M_X_220_F_032_B-50I-SP_____DIP_28_.pdf
in „PIC32MX flash access time“ · Mikrocontroller und Digitale Elektronik ·
PDF
wr2_rcm_revb.pdf
12 6F 3A 0D 8E C9 46 FE 00 00 C7 00 00 192 171 00 00 08 00 01 32 2B CC 77 BE 6B A4 BB 51 A0 69 208 187 BB BE 6A D7 F2 A0 00 00 00 56 00 00 00 00 00 00 224 203 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 240 219 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 256 235 00 00 00 00 00 00 00 00 00 53
in „Oszi einstellen“ · Mikrocontroller und Digitale Elektronik ·
PDF
S29JL064H_00_A7_e.pdf
the first page, the ordering information page, and pages with the DC Characteristics table and the AC Erase and Program table (in the table notes). The disclaimer on the first page refers the reader to the notice on this page. Full Production (No Designation on Document) When a product has been in production
in „[Verkaufe] 5xSDRAM (4Meg x 16 x 4 Banks) und 5xFLASH (64Meg 8 o. 16 Bit)“ · Markt ·
PDF
TTester_096k.pdf
B=180, 722mV NPN, B=180, 733mV NPN, B=188, 724mV BC640 PNP, B=185, 716mV PNP, B=227, 725mV PNP, B=187, 719mV AC128 (Ge.) PNP, B=68, 270mV PNP, B=64, 269mV PNP, B=66, 271mV BC517 NPN, B=26996, 1419mV NPN, B=28220, 1413mV NPN, B=28250, 1404mV BC516 PNP, B=65535, 1430mV PNP, B=65535, 1420mV PNP, B=65535
PDF
TTester_096k.pdf
Datei
All.txt
IC4 74HC126D 74HC126D SO14 Quad bus BUFFER, 3-state 1 IC4 74HC04D 74HC04D SO14 Hex INVERTER 1 IC4 74AC573D 74AC573D SO20W 8-bit D latch BUS DRIVER 1 IC4 74AC32N 74AC32N DIL14 Quad 2-input OR gate 1 IC4 74AC14D 74AC14D SO14 Hex schmitt trigger INVERTER 1 IC4 74AC04N 74AC04N DIL14 Hex INVERTER 1 IC4 74AC04D
in „[KiCad] Bibliotheksaufbau - Konzeptideen gesucht“ · Platinen ·
PDF
teXet_TF-127_Service_manual.pdf
2mA Output Z0 = 50Ω V OL(DC) = 0.4V,OL = 2mA 870Ω 50pF 50pF (Fig. 1) DC output load circuit (Fig. 2) AC output load circuit OPERATING AC PARAMETER (AC operating conditions unless otherwise noted) Parameter Symbol Version Unit Note - 60 (x16 only) - 75 Row active to row active delay tRRD(min) 12 15 ns 1
in „Photo-Rahmen als Farbdisplay“ · Mikrocontroller und Digitale Elektronik ·
PDF
CY7C63813-SXC-Cypress-Semiconductor-datasheet-11779157.pdf
.......70 Reset ................................................................................29 AC Characteristics ........................................................71 Sleep Mode ......................................................................30 Ordering Information ...................
in „Welche Relais und Controller zum Schalten von USB?“ · Mikrocontroller und Digitale Elektronik ·
PDF
ilm1-2007000172.pdf
European Conference on Power Electro- nics and Applications EPE’05, Dresden, 2005. [19] Consoli, Alfio. AC machines sensorless control techniques based on high frequen- cy signal injection. International Conference on Power Electronics and Motion Control EPE-PEMC’00, Kosice, 2000. 132 Sensorlose Regelung
in „SVPWM Ansteuerung eines BLDC“ · Mikrocontroller und Digitale Elektronik ·
PDF
Module_SS2013_-_WS2013-14.pdf
Dimensionierungsvorschriften, nichtlineare Eigenschaften, Kernverluste, Wicklungsverlus- te Pulsumrichter AC/AC (EAM): Ubersicht, Blockschaltbild, netzseitige Stromrichter, lastseitiger Pulswechselrichter, Sinus-Dreieck- und Raumzeigermodulation, U/f-Steuerung f r einen Antrieb, Drei- punktwechselrichter IGBT
in „Spezialisierung im Studium? Oder eher generalistisch?“ · Ausbildung, Studium & Beruf ·
Datei
Report_Samsung_X20.htm
ICH6-M) [B-1] <TR><TD><TD><TD><TD>Bus 0, Gerät 30, Funktion 2 <TD>Intel 82801FBM ICH6-M - AC'97 Audio Controller [B-1] <TR><TD><TD><TD><TD>Bus 0, Gerät 30, Funktion 3 <TD>Intel 82801FBM ICH6-M - AC'97 Modem Controller [B-1] <TR><TD><TD><TD><TD>Bus 0, Gerät 31, Funktion 2
PDF
SH1106_V2.3.pdf
SEG11 1706.63 329 186 SEG79 -445.87 329 254 COM27 -2460 75 51 IM0 731.81 -299.95 119 SEG12 1675.88 329 187 SEG80 -476.62 329 255 COM29 -2460 45 52 VSS 786.81 -299.95 120 SEG13 1645.13 329 188 SEG81 -507.37 329 256 COM31 -2460 15 53 CSB 841.81 -299.95 121 SEG14 1614.38 329 189 SEG82 -538.12 329 257 COM33
