PDF
s1d13700.pdf
display memory capacity. Display Display memory ABC XYZ Before scrolling ABC XYZ SAD1 123 123 AP C/R BC XYZ1 ABC XYZ After scrolling SAD1 123 23 Where: SADx = start address of screen block x AP = horizontal address range (REG[06h] bits 7-0, REG[07h] bits 7-0) C/R = character bytes per row (REG[03h] bits
in „Erste GLCD (Touch) -Schaltung“ · Mikrocontroller und Digitale Elektronik ·
PDF
s1d13700.pdf
in „[v] LCDs 320x240 s/w, 6 Zoll, Touch, inkl Controller“ · Markt ·
PDF
s1d13700_320-240_display.pdf
in „Anstuerung eines Grafik LCDs. Fragen zu Display und Controller“ · Mikrocontroller und Digitale Elektronik ·
PDF
W83627HF_datasheet.pdf
OMM V G P P P P P P V I DUI R S RSV K B P P P P PS UD C NN N NN C NN NN 2 2 2 2 2 2 S BB T N B B B BC N I A 3 3 3 3 3 I T A L CC C CC C CC CD 1 2 3 4 5 6 S # # B B # # # # C C N T 0 1 2 3 4 N # T K 1 1 1 9 9 9 9 9 9 9 9 9 9 8 8 8 8 88 8 8 8 7 7 7 7 7 7 7 7 7 7 6 6 6 6 6 0 0 0 9 8 7 6 5 4 3 2 1 0 9 8
Datei
devlist.txt
AmPAL22P10A . . .0) 106 D1,P2 AmPAL22P10AL . .0) 107 D1,P2 AmPAL22P10B . . .0) 108 D1,P2 AmPAL22V10 . . .0) 109 D1,P2 AmPAL22V10A . . .0) 110 D1,P2 AmPAL22XP10 . . .0) 111 D1,P2 AmPAL22XP10L . .0) 112 D1,P2 AmPAL23S8 . . . .0) 113 D1,P1 PAL16L8D/2 . . .0) 1084 D1,P1 PAL16L8H-10 . . .0) 122 D1,P1 PAL16L8H-15 .
in „PROM lesen /schreiben / Programmiergerät“ · Mikrocontroller und Digitale Elektronik ·
PDF
JESD84-B42.pdf
response format...........................................................................................109 Figure 29 — R1b response format.........................................................................................109 Figure 30 — R2 response format............................................
in „MMC SD library FAT16 FAT32 read write“ · Projekte & Code ·
PDF
Part_1_Physical_Layer_Specification_Ver3.01_Final_100218.pdf
Class Specification for SDSC and SDHC ..............................................................109..............109.... 108 4.13.1.3 Write Performance.............................................................................................................11009 4.13.1.6 Speed Class Definition.
in „MicroSD STM32 und Mosfet“ · Mikrocontroller und Digitale Elektronik ·
PDF
Si4330.pdf
bandwidth — 2 4 kHz RMS (500 Hz lower bound of integration) Phase Noise2 L(M ) F = 10 kHz — –80 — dBc/Hz F = 100 kHz — –90 — dBc/Hz F = 1 MHz — –115 — dBc/Hz F = 10 MHz — –130 — dBc/Hz Notes: 1. All specification guaranteed by production test unless otherwise noted. 2. Guaranteed by qualification.
PDF
AgilentImpedance_Measurment_Handbook.pdf
Parallel conductance (= 1/Rp) Xs: Series reactance (XL= wLs, XC= –1/(wCs)) Bp: Parallel susceptance (BC= wCp, B L –1/(wLp)) Ls: Series inductance (= L /w) Lp: Parallel inductance (= –1/(wBL)) Cs: Series capacitance (= –1/(wX C) Cp: Parallel capacitance (= C /w) D: Dissipation factor (= Rs/Xs = Rs/(wLs)
in „Niedrige Induktivität messen, wie?“ · HF, Funk und Felder ·
PDF
c8051f32x.pdf
Storage.............................................................................................109 11.3.Security Options............................................................................................................109 12. EXTERNAL RAM ................................................
in „Drehwinkelmessung“ · Mikrocontroller und Digitale Elektronik ·
PDF
H83003H.PDF
.................................................................................................. 109 6.3.1 Area Division.................................................................................................. 109 6.3.2 Chip Select Signals...................................................
in „H8/300 Frage (genauer H8/3003)“ · Mikrocontroller und Digitale Elektronik ·
PDF
GD32F3x0_RM_v1.0.pdf
.................................................................................................. 109 5.3.2. CTC trim counter................................................................................................................. 109 5.3.3. Frequency evaluation and automatically trim process
in „"NUCLEO"-Borads von GigaDevice“ · Mikrocontroller und Digitale Elektronik ·
PDF
PDF
S5_-_95U_Anleitung.pdf
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa 12: KC aaaaaaaBC: CAaaaaaaaaa aaaaa Z§hler A z§hlt positive Flanken aaaaaaa aaaaaaaaa aaaaa CBN ' aaaaaaa Vergleichswert 500 24: KC ='999 ; ' Z§hler B z§hlt negative Flanken Vergleichswert 999 Z§hlerstand abfragen Die
in „SPS Eingänge werden regelmäßig beschädigt“ · Mikrocontroller und Digitale Elektronik ·
PDF
lm5165.pdf
EN voltage rising 1.163 1.212 1.262 V EN-ON V EN-OFF Enable turnoff threshold EN voltage falling 1.109 1.144 1.178 V V EN-HYS Enable hysteresis 68 mV V EN-SD EN shutdown threshold EN voltage falling 0.3 0.6 V R HYS HYS on-resistance VEN = 1 V 80 200 Ω IHYS HYS off-state leakage current VEN = 1.5 V, HYS
in „Stromverbrauch Schaltregler“ · Analoge Elektronik und Schaltungstechnik ·
PDF
datasheet_1_.pdf
in „Display Ansteuerung mit Epsonlohnenswert oder zu aufwendig?“ · Mikrocontroller und Digitale Elektronik ·
PDF
s1d13700.pdf
in „Quarz für S1D13700“ · Mikrocontroller und Digitale Elektronik ·
PDF
tas5558-eight_channel_audio_processor_with_PWM_Output.pdf
.................................... 8 9.3 Programming Energy Manager............................. 109 6.10 Power-Down (PDN) Timing..................................... 8 10 Layout................................................................. 110 10.1 Layout Guidelines ............................
PDF
UM10736.pdf
output for USART1. PINASSIGN1 Table 108 U1_CTS I Clear To Send input for USART1. PINASSIGN2 Table 109 U1_SCLK I/O Serial clock input/output for USART1 in synchronous PINASSIGN2 Table 109 mode. U2_TXD O Transmitter output for USART2. PINASSIGN2 Table 109 U2_RXD I Receiver input for USART2. PINASSIGN2 Table 109 U2_SCLK I/O Serial clock input/output for USART1 in synchronous PINASSIGN3 Table 110 mode. SPI0_SCK I/O Serial clock for SPI0. PINASSIGN3 Table 110 SPI0_MOSI I/O Master Out Slave In for SPI0. PINASSIGN3
in „LPC1549 USB Virtual COM-Port“ · Mikrocontroller und Digitale Elektronik ·
PDF
BeagleBoneBlack_Rev_C.pdf
also provide the op-code during a LOAD MODE command. Address inputs are referenced to VREFCA. A12/BC#: When enabled in the mode register (MR), A12 is sampled during READ and WRITE commands to determine whether burst chop (on-the-fly) will be performed (HIGH = BL8 or no burst chop, LOW = BC4 burst chop
in „BeagleboneBlack: Sensor über I2C“ · Mikrocontroller und Digitale Elektronik ·
PDF
ili9328.pdf
VCOM -840 -307.5 168 C12- 3360 -307.5 228 C22- 7560 -307.5 288 G234 7955 202.5 49 nRD -4970 -307.5 109 VCOM -770 -307.5 169 C12- 3430 -307.5 229 C22- 7630 -307.5 289 G232 7939 319.5 50 nWR/SCL -4900 -307.5 110 VCOM -700 -307.5 170 C12+ 3500 -307.5 230 C22- 7700 -307.5 290 G230 7923 202.5 51 RS -4830
in „VW-Werbebeilage mit Display (vidipri)“ · Mikrocontroller und Digitale Elektronik ·
PDF
ILI9328DS_V0.1.pdf
in „[V]erkaufe TFT 2.8" und TFT 2.4" mit adapter PCB“ · Markt ·
Datei
Laptop.txt
Spannung 1.475 - 1.55 V Typische Leistung 38.7 - 89.0 W (Abhängig von der Taktung) Maximale Leistung 49 - 109 W (Abhängig von der Taktung) CPU Hersteller: Firmenname Intel Corporation Produktinformation http://www.intel.com/products/browse/processor.htm CPU Auslastung: CPU #1 0 % --------[ CPUID ]----------
in „Woher Treiber und Manual für Comtrade PC?“ · Softwareentwicklung ·
PDF
TMC262_datasheet.pdf
60 105 147 183 212 233 245 8 13 61 107 148 184 213 234 245 9 14 62 108 150 185 214 234 246 10 16 64 109 151 186 215 235 246 11 17 65 111 152 187 215 235 246 12 19 67 112 153 188 216 236 246 13 21 68 114 154 189 217 236 246 14 22 70 115 156 190 218 237 247 15 24 71 116 157 191 218 237 247 16 25 73 118
in „Wärmeentwicklung Mosfet“ · Mikrocontroller und Digitale Elektronik ·
PDF
NEC_78F.pdf
as an 8-bit register, and two 8-bit registers can also be used in a pair as a 16-bit register (AX, BC, DE, and HL). These registers can be described in terms of function names (X, A, C, B, E, D, L, H, AX, BC, DE, and HL) and absolute names (R0 to R7 and RP0 to RP3). Register banks to be used for instruction
in „NEC bzw. Renesas Microcontroller“ · Mikrocontroller und Digitale Elektronik ·
PDF
sed1335f.pdf
Description of Circuit Blocks........................................................................109 8.1 Microprocessor Interface........................................................................................................... 111 8.1.1 System Bus Interface................................
in „SP14Q002-A1 aus eBay - Erfahrungsaustausch“ · Mikrocontroller und Digitale Elektronik ·
PDF
SED1330.pdf
in „Hilfe ! Problem mit Minigrafikdisplay und AT90S8535“ · Mikrocontroller und Digitale Elektronik ·
PDF
SED1335F.pdf
in „Hilfe beim Initialisieren des SED1335F gesucht“ · Mikrocontroller und Digitale Elektronik ·
PDF
TC1797_UM_v1.1.pdf
Contents 3.4 Power Management . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3-109 [1] 3.4.1 Power Management Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . 3-109 [1] 3.4.2 Power Management Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3-110 [1] 3.4.2.1
in „TC1797 - keine Datenblätter?“ · Mikrocontroller und Digitale Elektronik ·
PDF
ATmega1284P_128KByte.pdf
..................... 15.9 Register description....................................................109................................ 16 16-bit Timer/Counter1 and Timer/Counter3 (1) with PWM ..........................115 16.1 Features ...............................................................115
in „ATmega1284P versus ohne P“ · Mikrocontroller und Digitale Elektronik ·
PDF
doc7707.pdf
bit registers. These procedures are described in the section “Accessing 16-bit Registers” on page 109. The Timer/Counter Control Registers (TCCRnA/B/C) are 8-bit registers and have no CPU access restrictions. Interrupt requests (shorten as Int.Req.) signals are all visible in the Timer Interrupt Flag
in „AVR (AT90USB162) - Sleep Mode und PCINT“ · Mikrocontroller und Digitale Elektronik ·
PDF
am79c961.pdf
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1563 CSR108–109: Buffer Management Scratch . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1564 CSR112: Missed Frame Count . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1564
PDF
Data_sheet_XBee_XBee-Pro_Series_2.pdf
Additional Information 154 Remote AT Command Request 107 Create Source Route 108 AT Command Response 109 Modem Status 109 ZigBee Transmit Status 110 ZigBee Receive Packet 111 ZigBee Explicit Rx Indicator 112 ZigBee IO Data Sample Rx Indicator 113 XBee Sensor Read Indicator 114 Node Identification Indicator
PDF
Bi8921.pdf
40 57 69 56 24 26 56 99 99 99 99 99 14 17 22 29 51 87 80 62 47 66 99 99 99 99 99 99 18 22 37 56 68 109 103 77 99 99 99 99 99 99 99 99 24 35 55 64 81 104 113 92 99 99 99 99 99 99 99 99 49 64 78 87 103 121 120 101 99 99 99 99 99 99 99 99 72 92 95 98 112 100 103 99 99 99 99 99 99 99 99 99 Offset within
in „pollin kamera au-85“ · Mikrocontroller und Digitale Elektronik ·
Datei
display.c
0x40, 0x40, 0x40, 0x40, 0x7e, 0x00 }, // 108 l { 0x00, 0x42, 0x66, 0x5a, 0x42, 0x42, 0x42, 0x00 }, // 109 m { 0x00, 0x42, 0x62, 0x52, 0x4a, 0x46, 0x42, 0x00 }, // 110 n { 0x00, 0x3c, 0x42, 0x42, 0x42, 0x42, 0x3c, 0x00 }, // 111 o { 0x00, 0x7c, 0x42, 0x42, 0x7c, 0x40, 0x40, 0x00 }, // 112 p { 0x00, 0x3c,
PDF
GD32F103xx_Datasheet_V2.5.pdf
0x5003 FFFF Reserved 0x4008 0000 - 0x4FFF FFFF Reserved 0x4004 0000 - 0x4007 FFFF Reserved 0x4002 BC00 - 0x4003 FFFF Reserved 0x4002 B000 - 0x4002 BBFF Reserved 0x4002 A000 - 0x4002 AFFF Reserved 0x4002 8000 - 0x4002 9FFF Reserved 0x4002 6800 - 0x4002 7FFF Reserved 0x4002 6400 - 0x4002 67FF Reserved
in „Unterschiede CS32F103C8T6 und STM32F103C8T6“ · Mikrocontroller und Digitale Elektronik ·
PDF
wt8871.pdf
PLL, 107 AVD25_PLL Analog power for analog front end PLL, 108 PLL27M_LF Loop filter for 27MHz PLL. 109 AVD25_27M 2.5V power.. 110 AVSS_27M Ground. 111 AVSS_CVBS Ground. 112 AVD25_CVBS 2.5V power. 113 CVBSI AI CVBS buffer input 114 CVBSBO AO CVBS buffer output 115 NC No connect. 116 SOGI SOG input. Composite
in „LCD Display HT070I36-E00“ · Mikrocontroller und Digitale Elektronik ·
PDF
M16C62_Hardware.pdf
(b8) b7 b0 b7 b0 Symbol Address When reset CRCD 03BD 1, 03BC 16 Indeterminate Function Values that R W can be set CRC calculation result output register 0000 16to FFF16 A CRC input register b7 b0 Symbo Address When reset CRCIN 03BE 16 Indeterminate Function Values
in „M16C Parallel pinbelegung“ · Mikrocontroller und Digitale Elektronik ·
PDF
datasheet.pdf
CPUD- 105 62 KCLK/GP27 PECISB 106 V 61 3VSB Vtt T 60 KBRST PECI 107 T 59 GA20M NC 108 58 SI/AUXFANIN1 109 57 RIA#/GP60 NC 110 56 AUXFANIN0 111 DCDA#/GP61 CPUFANIN0 112 55 VSS SYSFANIN 113 54 SOUTA/GP62(PENKBC) SST 114 3 53 SINA/GP63 CPUFANOUT0 115 V 52 DTRA#/GP64(PENROM) SYSFANOUT 116 C W83627DHG 51 RTSA
in „(Windows/Winbond) CPU Temperatur auslesen“ · Mikrocontroller und Digitale Elektronik ·
PDF
AVR-Tutorial.pdf
Ergebnis 0b00001100, wobei ein Rest von 1 bleibt. Der Dividend 0b01101101 entspricht der Dezimalzahl 109, der Divisor 0b00001001 der Dezimalzahl 9. Und wie man sich mit einem Taschenrechner leicht überzeugen kann, ergibt die Division von 109 durch 9 einen Wert von 12, wobei 1 Rest bleibt. Die Binärzahl für 12 lautet 0b00001100, das Ergebnis stimmt also. ldi r16, 109 ; Dividend ldi r17, 9 ; Divisor ; Division r16 : r17 ldi r18, 8 ; 8 Bit Division clr r19 ; Register für die Zwischenergebnisse / Rest clr r20 ; Ergebnis divloop: lsl r16 ; Zwischenergebnis mal 2 nehmen
in „AVR-Tutorial als PDF“ · Offtopic ·
PDF
8020rev26.pdf
Parameter Header. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .109 Table 59 - CD-ROM Media Type Codes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .109 Table 60 - CD-ROM Audio Control Mode Page Format. . . . . . . . . . . . . . . .
in „CD-ROM Laufwerk“ · Mikrocontroller und Digitale Elektronik ·
PDF
INF-8020.pdf
in „ATAPI Packet Commands“ · Mikrocontroller und Digitale Elektronik ·
PDF
S32K-RM.pdf
.................................................................................................. 109 6.2.5 Temporal protection.......................................................................................................................................109 6.2.6 Operational interference protection
PDF
mikrobeginner_gesamt.pdf
Programmablaufstruktur................................................................................................109 9.5.5 Programm.......................................................................................................................109 9.5.6 Simulation mit avr_sim.................................
in „Attiny26 PortD“ · Mikrocontroller und Digitale Elektronik ·
PDF
Advantest_R4131.pdf
n c h e s to lin e N o . 70 when th e r e a d d a ta is s m a lle r th a r i o r e q u a l to 1 x 109 (H z). 50 S e n ä s th e c o rn rn a rd to tu rn th ed ata k n o b c o u n te r c lo c k w is e fo r 1 s te p o f COARSE. 60 R e tu rn s to lin e N o . 3 0 . B ra n c h e s to lin e N o . 1 0 0 w h
in „Advantest Spectrum Analyser R4131B Fehler im Netzteil“ · HF, Funk und Felder ·
PDF
slau056e.pdf
R11 002A7h 0FF14h 04AEBh R11 002A7h 0FF12h 0xxxxh 0FF12h 0xxxxh 0FA34h 0xxxxh 0FA34h 0xxxxh 0FA32h 05BC1h 0FA32h 05BC1h 0FA30h 0xxxxh 0FA30h 0xxxxh 002A8h 0xxh 002A8h 0xxh 002A7h 012h 002A7h 05Bh 002A6h 0xxh 002A6h 0xxh 3-14 RISC 16-Bit CPU Addressing Modes 3.3.6 Indirect Autoincrement Mode The indirect
in „MSP430 LCD Controller“ · Mikrocontroller und Digitale Elektronik ·
PDF
slau056e.pdf
in „MSP430FG439 mit LCD“ · Mikrocontroller und Digitale Elektronik ·
Datei
Teileliste-04-18-2233.html
3.948cm; " class="ce7"><p>SOT-23</p></td><td style="text-align:left;width:3.731cm; " class="ce7"><p>BC 847A SMD</p></td><td style="text-align:left;width:2.776cm; " class="ce7"> </td><td style="text-align:left;width:3.157cm; " class="ce7"> </td><td style="text-align:right; width:1.879cm; " class="ce7">
in „Bauelemente abzugeben“ · Markt ·
PDF
reference_manual.pdf
. . . . . . . . 108 7.3.7 APB2 peripheral clock enable register (RCC_APB2ENR) . . . . . . . . . . 109 7.3.8 APB1 peripheral clock enable register (RCC_APB1ENR) . . . . . . . . . . 111 7.3.9 Backup domain control register (RCC_BDCR) . . . . . . . . . . . . . . . . . . 115 7.3.10 Control/status register
in „I2S zwischen STM32F103RET6 und PCM3168A möglich?“ · Mikrocontroller und Digitale Elektronik ·
PDF
KlangPlusTon_2007-01.pdf
anstelledesvorgesehenenMPSA18(warnicht ten, bis er sich nicht mehr ändert. Der Ruhe- lieferbar) den Typ BC550C einsetzten (Ach- strom beträgt dann 55 mA, so hat’s der Ent- tung:anderePinbelegung),würdeeinHunder- wickler vorgesehen. Eine nennenswerte Er- 71 terpack gerade mal 3 Euro kosten – da kann wärmung
in „Symasym hohe Ausgangsspannung“ · Analoge Elektronik und Schaltungstechnik ·
