[STM32] Der USART mal wieder
OP #2141012
bin neu im ARM programmieren und versuche mich gerade daran den USART2
zum rennen zu bringen, der USART1 wird schon zum Download des Programmes
benutzt.
Das Board habe ich hierher http://www.futurlec.com/ET-STM32_Stamp.shtml
Hier dann mal der Code
/******** USART initialisieren ********/
void USART_Configuration(void)
  USART_InitTypeDef USART_InitStructure;
  GPIO_InitTypeDef GPIO_InitStructure;
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); // Enable GPIOA on APB2 peripheral clock
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE); // Enable AFIO Clock
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE); // Enable USART2 Clock
  GPIO_StructInit(&GPIO_InitStructure); // Set GPIO to default values
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; // Set TX(PA2)
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; // Set as output Push-Pull
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; // Set freq. of PortPin
  GPIO_Init(GPIOA, &GPIO_InitStructure);   // Initialize
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3; // Set RX(PA3)
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING ; // Set as floating input
  USART_StructInit(&USART_InitStructure); // Initializes structure with default values
24
    USART_DeInit(USART2); // Put everything back to power-on defaults
25
26
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE); // Enable USART2 on APB1 peripheral clock
27
28
  // ------------------------------ USART2 Configuration ------------------------------
29
  USART_InitStructure.USART_BaudRate = 115200; // The Baudrate
30
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; // Software or Hardware FlowControl
31
  //USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; // Enable RX and TX
32
  USART_InitStructure.USART_Mode = USART_Mode_Tx; // Enable RX and TX
33
  USART_InitStructure.USART_Parity = USART_Parity_No; // No Parity Bit
34
  USART_InitStructure.USART_StopBits = USART_StopBits_1; // One Stopbit
35
  USART_InitStructure.USART_WordLength = USART_WordLength_8b; // 8-Bit Word length of Data
36
  USART_Init(USART2, &USART_InitStructure); // Now do the setup
37
38
  USART_Cmd(USART2, ENABLE); // Enable USART2
39
Wenn ich ein Oszi an besagten TX Pin hänge(PA2) tut sich leider nix, hab
auch schon ein wenig das Forum durchstöbert, konnte aber keine Fehler
erkennen.
OP #2141038
Joar, senden tu ich natürlich
/******** RCC initialisieren ********/
void RCC_Configuration(void)
  ErrorStatus HSEStartUpStatus;
    RCC_DeInit(); // RCC system reset(for debug purpose)
    RCC_HSEConfig(RCC_HSE_ON); // Enable HSE
    HSEStartUpStatus = RCC_WaitForHSEStartUp(); // Wait till HSE is ready
    if(HSEStartUpStatus == SUCCESS)
      FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable); // Enable Prefetch Buffer
      FLASH_SetLatency(FLASH_Latency_2); // Flash 2 wait state
      RCC_HCLKConfig(RCC_SYSCLK_Div1); // HCLK = SYSCLK
      RCC_PCLK2Config(RCC_HCLK_Div1); // PCLK2 = HCLK
      RCC_PCLK1Config(RCC_HCLK_Div2); // PCLK1 = HCLK/2
      RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9); // PLLCLK = 8MHz * 9 = 72 MHz
      RCC_PLLCmd(ENABLE); // Enable PLL
      while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET); // Wait till PLL is ready
23
24
      RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); // Select PLL as system clock source
25
26
      while(RCC_GetSYSCLKSource() != 0x08); // Wait till PLL is used as system clock source
27
28
29
30
int main(void)
31
32
  RCC_Configuration(); // System Clocks Configuration
33
  USART_Configuration(); // USART initialisieren
34
35
  while(1)
36
37
     USART_SendData(USART2, 'T');
38
  while(USART_GetFlagStatus(USART2, USART_FLAG_TXE) == RESET);
39
40
OP #2141043
Matthias K. schrieb:
> TxD PA2 muss auf alternative Funktion konfiguriert werden.
> GPIO_InitStructure.GPIO_Mode  =  GPIO_Mode_AF_PP;     // Pin-Mode
> Und zeig mal die eigentliche Senderoutine.
> AFIO brauchst Du nicht zu enablen, solange die Standardpins für die
> UART2 verwendet werden.
Optimal, jetzt fluppt es, danke, lag am GPIO_Mode_Out_PP, hab es ersetzt
und jetzt sieht man auch was feines am Oskar.
