msp430 gcc4 / asm-files assembler umsetzen & einbinden
OP #2218711
versuche gerade die Code-Beispiele von TI für den MSP430 auf GCC4
umzusetzen. Verwende einen MSP430F449.
http://focus.ti.com/general/docs/litabsmultiplefilelist.tsp?literatureNumber=slaa290a
Mit den ASM files habe ich noch Schwierigkeiten.
ORIGINAL RTC_WDT.asm
            .cdecls C,LIST,"msp430.h"
            .ref  incrementSeconds
            .def  WDT_1sec_wake
            .text
WDT_1sec_wake
            mov.w   #WDT_ADLY_1000, &WDTCTL ; WDT 1 second interrupt
            bis.b   #WDTIE,&IE1             ; Enable WDT interrupt
            bis.b   #GIE,  SR
            ret
WDT_ISR;
            call    #incrementSeconds       ; tick one second
            reti                            ;
;           Interrupt Vectors Used
            .sect   WDT_VECTOR               ; WDT Vector
            .short  WDT_ISR                  ;
23
            .end
und meine
UMSETZUNG RTC_WDT.asm
für msp430 gcc4
;            .cdecls C,LIST,"msp430.h"
;            .ref  incrementSeconds
;            .def  WDT_1sec_wake
#include "msp430x44x.h"
#include "wdt_a.h"
            .text
.global WDT_1sec_wake
WDT_1sec_wake:
            bis.b   #GIE,  SR
            ret
.global WDT_ISR
WDT_ISR:
            reti                            ;
24
25
26
            .short  WDT_ISR                  ;
27
            .end
Der Builder sagt:
**** Rebuild of configuration Debug for project versuch ****
**** Internal Builder is used for build               ****
msp430-gcc.exe -IC:\mspgcc4\msp430\include -O3 -g3 -Wall -c -fmessage-length=0 -mmcu=msp430x449 -o_test\WDT_example.o ..\_test\WDT_example.c
../_test/WDT_example.c:81: warning: return type of `main' is not `int'
msp430-as.exe -mmcu=msp430x449 -IC:\mspgcc4\msp430\include -o_test\RTC_WDT.o ..\_test\RTC_WDT.asm
msp430-as.exe -mmcu=msp430x449 -IC:\mspgcc4\msp430\include -o_test\RTC.o ..\_test\RTC.asm
msp430-gcc.exe -mmcu=msp430x449 -oversuch.elf _test\WDT_example.o _test\RTC_WDT.o _test\RTC.o
_test\RTC_WDT.o: In function `WDT_1sec_wake':
(.text+0x2): undefined reference to `WDT_ADLY_1000'
(.text+0x4): undefined reference to `WDTCTL'
(.text+0x8): undefined reference to `WDTIE'
(.text+0xa): undefined reference to `IE1'
(.text+0xe): undefined reference to `GIE'
(.text+0x10): undefined reference to `SR'
Build error occurred, build is stopped
Time consumed: 1266  ms.
Die references von WDT_ADLY_1000, WDTCTL, WDTIE, IE1, GIE, SR sind in
"wdt_a.h" definiert.
Warum findet der ggc4 sie nicht? Oder habe ich was falsch deklariert?
Grüße
Moderator Persönliche Seite #2218976
Du rufst den Assembler direkt auf, der hat keine Ahnung, was ein
#include ist.  Vermutlich wird ihm das # einfach ein Kommentar-
zeichen sein. ;-)
Der gängige Weg ist es, die Datei mit dem Suffix .S zu benennen
(großes "S"!) und sie dem Compiler zum Fraß vorzuwerfen.  Das große
S ist dem ein Zeichen, dass er die Datei zuerst durch den Präprozessor
jagen soll und dann dem Assembler füttern.
All die Konstanten da drin, die dir der Linker anmeckert, sollte der
Assembler gar nicht mehr symbolisch sehen, sondern bereits durch den
Präprozessor aufgelöst numerisch.  Unix-Assembler (zu denen der GNU
Assembler gehört) beklagen sich jedoch nicht über Dinge, die sie nicht
kennen, sondern nehmen sie stillschweigend als "global undefined" in
die Symboltabelle auf, in der Hoffnung, dass der Linker das dann schon
irgendwie parat haben wird.  Daher kommt die Meckerei nicht vom
Assembler selbst, sondern erst vom Linker.
OP #2220044
Vielen Dank für die Info!
Dateiname aus RTC_WDT.S geändert.
Jedoch
            .def  WDT_1sec_wake
            .text
WDT_1sec_wake:
            bis.b   #GIE,  SR
            ret
.global WDT_ISR
WDT_ISR:
            reti                            ;
24
            .short  WDT_ISR                  ;
25
            .end
liefert:
msp430-as.exe -mmcu=msp430x449 -IC:\mspgcc4\msp430\include -o_test\RTC.o ..\_test\RTC.S
msp430-as.exe -mmcu=msp430x449 -IC:\mspgcc4\msp430\include -o_test\RTC_WDT.o ..\_test\RTC_WDT.S
..\_test\RTC_WDT.S: Assembler messages:
..\_test\RTC_WDT.S:75: Error: unknown pseudo-op: `.cdecls'
..\_test\RTC_WDT.S:76: Error: unknown pseudo-op: `.ref'
..\_test\RTC_WDT.S:77: Error: unknown pseudo-op: `.def'
Time consumed: 968  ms.
und
;auskommentiert            .cdecls C,LIST,"msp430.h"
;auskommentiert            .ref  incrementSeconds
;auskommentiert            .def  WDT_1sec_wake
            .text
WDT_1sec_wake:
            bis.b   #GIE,  SR
            ret
.global WDT_ISR
WDT_ISR:
            reti                            ;
24
            .short  WDT_ISR                  ;
25
            .end
liefert
msp430-gcc.exe -mmcu=msp430x449 -o20110606.elf _test\WDT_example.o _test\RTC_WDT.o _test\RTC.o
Time consumed: 1375  ms.
Wie kann man ihm die references von WDT_ADLY_1000, WDTCTL, WDTIE, IE1,
GIE, SR beibringen?
Muss mann noch an den Linker Flags was drehen?
Grüße
Moderator Persönliche Seite #2220118
J. R. schrieb:
> msp430-as.exe -mmcu=msp430x449 -IC:\mspgcc4\msp430\include ...
Du sollst bitte den Compiler aufrufen damit, nicht den Assembler.
Das Kommando "msp430-gcc" (das .exe darfst du dir getrost klemmen)
ist der sogenannte Compiler-Treiber, der die einzelnen Stufen der
"Backends" anhand der Dateiendung der Quelldatei ermittelt und der
Reihenfolge nach aufruft.  Der braucht (außer den -I-Optionen) nur
noch die Option -c, für "compilier' das mal".
Nein, zum Geier[tm].  Der Linker hat damit nichts zu tun, diese
Konstanten sollen bereits vor dem Assemblieren in Zahlen verwandelt
werden, und dafür zuständig ist der Präprozessor.
Der Linker hat exakt Null Ahnung davon, was ein WDT_ADLY_1000 sein
könnte, und der muss diese Ahnung auch nicht haben.
OP #2220163
Ergebnis vom Geier :-/
**** Rebuild of configuration Debug for project Versuch ****
msp430-gcc -c -mmcu=msp430x449 -IC:\mspgcc4\msp430\include -o_test\RTC_WDT.o ..\_test\RTC_WDT.S
../_test/RTC_WDT.S: Assembler messages:
../_test/RTC_WDT.S:75: Error: unknown pseudo-op: `.cdecls'
../_test/RTC_WDT.S:76: Error: unknown pseudo-op: `.ref'
../_test/RTC_WDT.S:77: Error: unknown pseudo-op: `.def'
Time consumed: 484  ms.
OP #2220179
bzw
msp430-gcc -c -mmcu=msp430x449 -IC:\mspgcc4\msp430\include -o_test\RTC.o ..\_test\RTC.S
msp430-gcc -IC:\mspgcc4\msp430\include -O3 -g3 -Wall -c -fmessage-length=0 -mmcu=msp430x449 -o_test\WDT_example.o ..\_test\WDT_example.c
msp430-gcc -mmcu=msp430x449 -o20110606.elf _test\WDT_example.o _test\RTC_WDT.o _test\RTC.o
Time consumed: 1796  ms.
Moderator Persönliche Seite #2220927
Ja, die hattest du doch schon rauskommentiert.
Da musst du wohl im MSP430-Assemblerhandbuch nachlesen, wofür die
gut sein sollen, um dann das Pendant vom GNU-Assembler zu finden.
Aber wenn ich mir die so ansehe, braucht man die wohl nicht.
J. R. schrieb:
> bzw
Das heißt aber, dass der Präprozessor da wohl nach wie vor nicht
drüber gelaufen ist.  Lass ihn mal manuell laufen, indem du das
-c durch ein -E ersetzt und bei -o einen entsprechend anderen
Dateinamen angibst.  Schau dir an, was der Assembler dann gefüttert
bekommt.
OP #2223804
> bekommt.
Also:
msp430-gcc -E -mmcu=msp430x449 -I C:\mspgcc4\msp430\include -o RTC_WDTX.o RTC_WDT.S
liefert als RTC-WDTX.o:
# 1 "RTC_WDT.S"
# 1 "<built-in>"
# 1 "<command line>"
# 1 "RTC_WDT.S"
            .text
WDT_1sec_wake:
            bis.b #GIE, SR
            ret
.global WDT_ISR
WDT_ISR:
            reti ;
23
24
25
26
27
28
29
            .short WDT_ISR ;
30
            .end
sagt Dir das was?
Grüße
OP #2223817
Im
MSP430 Assembly Language Tools v 3.3
User's Guide
http://focus.ti.com/lit/ug/slau131e/slau131e.pdf
steht
"You can use the .cdecls assembler directive to share C headers
containing declarations and prototypes between C and assembly code. Any
legal C/C++ can be used in a .cdecls block and the C/C++ declarations
will cause suitable assembly to be generated automatically, allowing you
to reference the
C/C++ constructs in assembly code."
Weitere Details dort auf S.73:
The .cdecls options control whether the code is treated as C or C++
code; and how the.cdecls block and converted code are presented. Options
must be separated by commas; they can appear in any order:
C = Treat the code in the .cdecls block as C source code (default).
LIST = Include the converted assembly code in any listing file generated
for the containing assembly file."
Er holt sich dort also die Definitionen von WDT_ADLY_1000 etc?
Wie kann ich ihm das mithilfe von mps430gcc beibringen?
Grüße
Moderator Persönliche Seite #2224018
> [avrasm]# 1 "RTC_WDT.S"
> # 1 "<built-in>"
> # 1 "RTC_WDT.S"
(und dann keine weiteren #-Zeilen)
Das heißt, da ist kein include-File drüber gelaufen.
Weiter oben hast du da noch
#include "wdt_a.h"
stehen, und letztere Datei sollte die fehlenden Symbole bringen.
OP #2224097
Für gcc4 musste ich folgendes einbauen:
#include "msp430/wdt_a.h"
doch das Ergebnis:
C:/mspgcc4/msp430/include/msp430/wdt_a.h: Assembler messages:
C:/mspgcc4/msp430/include/msp430/wdt_a.h:23: Error: unknown opcode `sfrw(wdtctl,'
Time consumed: 750  ms.
was passiert da?
Die header files der ggc4 sollte der compiler doch verstehen?
OP #2227327
hiermit läufts
Egebnis ist also
            .text
.global incrementSeconds
WDT_1sec_wake:
;            bis.b   #GIE,  SR
            bis.b   #GIE,  LPM3      ; LPM3 ist richtig
            ret
.global WDT_ISR
WDT_ISR:
            reti                            ;
24
25
26
27
28
            .short  WDT_ISR                  ;
29
            .end
