EEPROM vertauscht Werte.
OP #2265118
Hallo.
Hab lang gelesen und nix gefunden zum Problem.
System:
Atmega 16
AVR-Studio
Code ist:
______________________________________________________________________
_
globals.h:
uint8_t A1TimeOn[1], A1TimeOff[1], A2TimeOn[1], A2TimeOff[1],
A3TimeOn[1], A3TimeOff[1], A4TimeOn[1], A4TimeOff[1];
_
main.c:
#include <avr/eeprom.h>
#include "globals.h"
int main(){
A1TimeOn[0] = 0;A1TimeOn[1] = 0;A1TimeOff[0] = 0;A1TimeOff[1] =
0;A2TimeOn[0] = 0;A2TimeOn[1] = 0;A2TimeOff[0] = 0;A2TimeOff[1] =
0;A3TimeOn[0] = 0;A3TimeOn[1] = 0;A3TimeOff[0] = 0;A3TimeOff[1] =
0;A4TimeOn[0] = 01;A4TimeOn[1] = 0;A4TimeOff[0] = 0;A4TimeOff[1] = 0;
get_A1TimeOn_EEdata();
get_A1TimeOff_EEdata();
get_A2TimeOn_EEdata();
get_A2TimeOff_EEdata();
get_A3TimeOn_EEdata();
get_A3TimeOff_EEdata();
get_A4TimeOn_EEdata();
get_A4TimeOff_EEdata();
while (1)
hier ist dann z.B. die Ausgabe der EEPROM-Werte
__
eeprom.c:
uint8_t eeFooByte1 EEMEM;    //TurnSW
uint8_t eeFooByte2 EEMEM;    //A1syn_0
uint8_t eeFooByte3 EEMEM;    //A1syn_1
uint8_t eeFooByte4 EEMEM;    //A2syn_0
uint8_t eeFooByte5 EEMEM;    //A2syn_1
uint8_t eeFooByte6 EEMEM;    //A3syn_0
uint8_t eeFooByte7 EEMEM;    //A3syn_1
uint8_t eeFooByte8 EEMEM;    //A4syn_0
uint8_t eeFooByte9 EEMEM;    //A4syn_1
uint16_t eeFooByte10 EEMEM;    //A1IVOn
uint16_t eeFooByte11 EEMEM;    //A1IVOff
uint16_t eeFooByte12 EEMEM;    //A2IVOn
uint16_t eeFooByte13 EEMEM;    //A2IVOff
uint16_t eeFooByte14 EEMEM;    //A3IVOn
uint16_t eeFooByte15 EEMEM;    //A3IVOff
uint16_t eeFooByte16 EEMEM;    //A4IVOn
uint16_t eeFooByte17 EEMEM;    //A4IVOff
uint8_t eeFooByte18 EEMEM;    //A1TimeOn
uint8_t eeFooByte19 EEMEM;    //A1TimeOn
uint8_t eeFooByte20 EEMEM;    //A1TimeOff
uint8_t eeFooByte21 EEMEM;    //A1TimeOff
uint8_t eeFooByte22 EEMEM;    //A2TimeOn
uint8_t eeFooByte23 EEMEM;    //A2TimeOn
uint8_t eeFooByte24 EEMEM;    //A2TimeOff
uint8_t eeFooByte25 EEMEM;    //A2TimeOff
uint8_t eeFooByte26 EEMEM;    //A3TimeOn
uint8_t eeFooByte27 EEMEM;    //A3TimeOn
uint8_t eeFooByte28 EEMEM;    //A3TimeOff
uint8_t eeFooByte29 EEMEM;    //A3TimeOff
uint8_t eeFooByte30 EEMEM;    //A4TimeOn
uint8_t eeFooByte31 EEMEM;    //A4TimeOn
uint8_t eeFooByte32 EEMEM;    //A4TimeOff
uint8_t eeFooByte33 EEMEM;    //A4TimeOff
Beispielfunktionen:
void get_A1TimeOn_EEdata()
  uint8_t v = 0;
  cli();
  v = eeprom_read_byte(&eeFooByte18);
  if (v > 23)v = 0;
  A1TimeOn[0] = v;
  v = 0;
  v = eeprom_read_byte(&eeFooByte19);
  if (v > 59)v = 0;
  A1TimeOn[1] = v;
  sei();
void set_A1TimeOn_EEdata()
  cli();
  eeprom_write_byte(&eeFooByte18, A1TimeOn[0]);
  eeprom_write_byte(&eeFooByte19, A1TimeOn[1]);
  sei();
__
So und jetzt mal zum Verhalten des Ganzen:
Ich habe also 33 EEPROM-Speichervariablen benannt und es funktioniert
auch soweit alles. Alle 41 Bytes werden beschrieben und ordnungsgemäß
ausgelesen. Nur &eeFooByte19 vertauscht seinen Wert mit &eeFooByte27.
Besser gesagt wird nicht der Wert von &eeFooByte27 in &eeFooByte27
gespeichert, sondern A3TimeOn[1] ( was den Wert von &eeFooByte27
übernehmen soll ) nimmt den von &eeFooByte19??? Alle anderen Werte sind
korrekt und die Routinen sind alle gleich geschrieben. Deshalb verstehe
ich nicht, weshalb es immer nur bei diesen zwei Werten hapert.
Kennt das Problem jemand? bitte helft mir, da ich keine Erklärung hab
und vieles schon versucht; So z.B. die Speicheradressen fest zu
benennen. Das Prob ist das Gleiche.
Vielen Dank
OP #2265180
könnt ihr beiden mir mal sagen was ihr hier eigendlich wollt? nur dummes
gequatsche! nix - aber garnix - produktives. ihr geht mir vielleicht
aufn sack. Und woher nimmt sigmund das recht mich zu beleidigen? aus was
für nem loch bist du denn gerobt? wenn du nichts anderes zu sagen hast,
dann verp..dich einfach.
ich danke allen die produktive vorschläge haben!
Gast #2265200
>Also - daran liegts nicht!
Da hast du recht. Der Fehler ist nicht leicht zu finden, aber unsere
halbe Entwicklungsabteilung wurde einmal darauf angesetzt, ein ähnliches
Problem zu lösen. Es ist eigentlich ganz einfach: du musst ausschließen,
dass 0 auftritt in Zeile ^W
Ach so. Dann mach ich das mal. Man kann trotz Unwissen auch freundlich
bleiben.
OP #2265214
Fantastisch Eeprommer - Jedenfalls was deine Hilfsbereitschaft angeht!
Vielen Dank!
Ja beim Start steht in allen Zellen ja 255. Wenn ich dann das erste Mal
beschreibe, verwende ich als Default Minimum mal 0 als Ascii 48 bzw. Hex
0x30. Das sind alles keine Nullen im Sinne von 0x00. Hab ich da nen
Denkfehler?
Gast #2265218
>Alle anderen Arrays mit xxx[1] funktionieren
>wie erwartet!
Genau genommen sind das dann gar keine Arrays.
Und funktionieren tun sie nur wenn du mit xxx[0] = x
darauf zugeifst. Bei xxx[1] = x schreibst du irgendwo
in den Speicher. Und das gibt dann mehr oder weniger
lustige Nebeneffekte. Aber ich mach vom Acker.
Er weiss es ja besser.
OP #2265224
Ich verstehe deine Laune nicht Eeprommer. Markier mir bitte den Satz, in
dem ich über dich geschimpft hab. Dann weiß ichs einfach für die
Zukunft.
Was spricht dagen, dass ich nicht alles weiß und frage? Mit Array[2] das
habe ich alles schon programmiert. Aber das Problem ist nicht weg
deshalb. Ist doch nicht so als würde ich eure Vorschläge in den Wind
schlagen?!
#2265244
Matthias T. schrieb:
> Nur hilft ein ...[2] auch nicht
Trotzdem ist es ein Fehler den du machst wenn du nur ein array mit
uint8_t bla[1];
definierst und es mit
x = bla[1];
ansprichst.
Der Zugriff ist definitiv falsch (auch wenn es dein oben benanntes
Problem nicht lösen mag).
holger und andere war oben so nett(!) und haben dich schon drauf
hingewiesen und du pubst sie an. Ich weiß nicht, ob das die richtige Art
ist, sich Hilfe zu holen.
OP #2268640
So! Nach dem ihr mir alle so super geholfen habt, bin ich euch natürlich
ne Antwort schuldig, woran es jetzt wirklich lag; falls mal wieder
jemand das Problem hat.
Also am Array[1] lags NICH! (aber das hatte ich ja weiter oben schon
dreimal erwähnt).
Im obigen Code ist zu sehen, dass der Kontroller direkt mit der main()
(und damit zu arbeiten) beginnt. Und genau da hatte der Frosch die
Locken. Der Eeprom braucht volle Betriebsspannug um ordnungsgemäß
arbeiten zu können, sonst wirds Wirrwarr. Nachdem ich in Folge dieser
Erkenntnis (kam nicht von mir!) nen _delay_ms(150); direkt nach main()
eingefügt hatte lief alle stabil. ...und wenn er nich stirbt...!
Schade dass mir kein kluger Kopf hier das sagen konnte. Klar - waren ja
alle mit Array[1] beschäftigt, anstatt wirklich mal zu überlegen!
Bye
Gast #2268662
Das man das EEPROM nicht ohne BOD Fuse enabled betreiben
sollte ist ein alter Hut.
Wenn man so offensichtliche Fehler im Programm sieht
denkt man eben an das naheliegendste.
Gast #2268672
An Stelle von drei Tagen planlosem posten im Forum und der
programmierung völlig blödsinniger delays hättest du mal lieber das
Datenblatt lesen sollen.
EEPROM data corruption can easily be avoided by following this design recommendation:
Keep the AVR RESET active (low) during periods of insufficient power supply voltage.
This can be done by enabling the internal Brown-out Detector (BOD).
If the detection level of the internal BOD does not match the needed detection level,
an external low VCC Reset Protection circuit can be used.
If a reset occurs while a write operation is in progress,
the write operation will be completed provided that the power supply voltage is sufficient.
Gast #2268731
Vielleicht solltest du nächstes mal einfach vermeiden, im Forum zu
fragen. Schließlich sitzen hier sowieso nur Idioten, die nicht richtig
überlegen, sondern einfach mal die offensichtlichen Fehler aufzeigen.
#2268989
Du hattest es erwähnt, ich hatte das gelesen und auch verstanden.
Trotzdem habe ich (und andere) dich netterweise auf diesen
offensichtlichen Fehler (der nicht zu deinem eigentlichen Problem
gehört, ja) hingewiesen.
Dieser Fehler wird dir an anderer Stelle Problem machen.
Das du hier jetzt darüber rumpöbelst, dass man dich auf den Fehler
hingewiesen hat, ist schlicht eine Frechheit!
OP #2269438
Zunächst: Das Array[1]-Ding war von Anfang an ein Kopierfehler von mir,
den ich hätte beseitigen sollen, BEVOR ich hier poste. Ich bin nicht
darauf eingegangen, weil es nicht das Problem geklärt hätte. Natürlich
ist es richtig und ich habe es auch nicht ernsthaft in meinen
Programmablauf angewandt. Also - um mal darauf einzugehen auf die ganze
Diskussion ums Array ( damit das hoffentlich mal vom Tisch ist ) -
Diesbezüglich habt ihr recht und ich habe das nie bezweifelt. Nur - wenn
der Motor am Auto nicht funktioniert, muss ich nicht über fehlende
Reifen am Fahrzeug diskutieren. Sicher fährt das Auto so nicht. Aber den
Motor macht diese Diskussion auch nicht ganz.
Zum Motzen, Pöppeln, oder wie ihr es auch nennt: Leider wurden genau
diese Beiträge wieder aus dem Thread genommen, weshalb ich mich aufregte
am Anfang. Da wurde ich beleidigt ganz dunkel, ohne dass etwas
konstruktives rüber kam. Ohne diese Beiträge kann hier natürlich keiner
mehr nachvollziehen, weshalb es dazu kam. Ich möchte mich davor
bewahren, denen, die mir echt zu helfen versuchten, vor den Latz zu
kacken. Im Gegenteil! Denen danke ich im Nachhinein noch einmal sehr!!!
Bitte fühlt euch also nicht alle angesprochen, wenn ich gemotzt hab. Es
galt einzig jenen, die mich Anfangs als Volltrottel betitelten und jetzt
ihre Beiträge wieder gelöscht haben.
Ich hoffe also - Ärger vom Tisch und Danke für eure Hilfe!!!
Persönliche Seite #2269488
Wenn aber die Fehlerbeschreibung ist:
Auto fährt nicht
und du siehst das keine Reifen montiert sind, was würdest du demjenigem
raten?
Dann kommt als Entgegnung:
Ich hatte die Reifen ja mal montiert,
hat aber auch nicht geholfen, daran liegts nicht.
Du schaust hin: Nur ein Reifen montiert.
Auf erneutes Nachfragen wird dann gesagt die Reifen könne ja garnicht
das Problem sein.
Etwas später dann die Auflösung:
Vergesen in der Bedienungsanleitung zu lesen das man das Auto
mit Benzin betanken muß, jetzt geht alles es kann also nicht an den
Reifen gelegen haben.
Es kommt der Hinweis das die Reifen trotzdem montiert werden müssen
Ach ja übriegens, das Auto ist garnicht das welches ich eigentlich
meinte...
Kann ja mal passieren...
