vector mit 0 initalisieren
Gast #2311569
vector <= std_logic_vector(to_unsigned(integer_wert, integer_länge);
z.b.
vector <= std_logic_vector(to_unsigned(5,8);
ist das gleiche wie
vector <= "00000101";
Gast #2311719
>> allerdings sind die Constaten vom typ std_Ulogic_vector
vector <= std_logic_vector(to_unsigned(to_integer(unsigned(Konstante)), vector'length));
zwar ziemlich wild, sollte aber funktionieren.
Gast #2312084
leider bekomme ich eine Fehlermeldung die ich nicht einordnen kann.
ERROR:HDLParsers:808 - "C:/Projekte/VHDL/trash/test/test.vhd" Line 36.
resize can not have such operands in this context.
Unten der Quellcode:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_logic_arith.all;
use IEEE.numeric_std.all;
use work.test2.all;
entity test is
port(
  out_vector: out std_ulogic_vector(16 downto 0));
end test;
architecture Behavioral of test is
begin
out_vector <= std_ulogic_vector(resize(unsigned(testt), out_vector'length));
end Behavioral;
library IEEE;
use IEEE.STD_LOGIC_1164.all;
package test2 is
constant testt : std_ulogic_vector(2 downto 0) := "001";
end test2;
package body test2 is
end test2;
Gast #2312096
Raus damit!
vorher:
Model Technology ModelSim PE vcom 10.0b Compiler 2011.05 May  5 2011
-- Loading package STANDARD
-- Loading package TEXTIO
-- Loading package std_logic_1164
-- Loading package std_logic_arith
-- Loading package NUMERIC_STD
-- Loading package test2
-- Compiling entity test
-- Compiling architecture Behavioral of test
** Error: res.vhd(17): (vcom-1078) Identifier "unsigned" is not directly visible.
   Potentially visible declarations are:
        ieee.NUMERIC_STD.UNSIGNED (subtype declaration)
        ieee.std_logic_arith.UNSIGNED (type declaration)
** Error: res.vhd(17): Illegal type conversion to ieee.std_logic_1164.STD_ULOGIC_VECTOR (operand type is not known).
** Error: res.vhd(19): VHDL Compiler exiting
nachher:
Duke
Moderator (Firma: Titel) Persönliche Seite #2312262
Und dann der:
> std_ulogic_vector
Nimm stattdessen die weltweit üblichen std_logic...
Der ulogic hatte vor geraumer Zeit mal den Vorteil, dass die Simulation
schneller durchlief. Mit aktuellen Compilern ist dieser Vorteil weg, und
alle anderen verwenden weltweit std_logic. Damit lassen sich dann
nämlich auch Tristate Busse beschreiben...
#2312705
@manhunt
Die gleichen Regeln kenne ich auch. std_logic ist nur fuer Chip IOs
erlaubt, die auch einen tri-state driver haben. Jedes andere Signal ist
std_ulogic,
@lkmiller
In meinem Environment geht es da nicht um Simulationsperformance,
sondern darum, dass das  versehentlichte Zuweisen zweier Gleichungen auf
das gleiche Signal, bei std_logic hat der Compiler eine resolution
function (worst case ein 'X' innerhalb des Chips) hat, bei std_ulogic
aber eine Fehlermeldung provoziert wird. Das hilft viele Probleme schon
sehr frueh zu erkennen. Das letzte Mal, das mir chipinterne tri-atate
Signale begegnet sind, ist ca. 20 Jahre her, aber da hatte es schon mehr
Nachteile als Vorteile ('x' als Ergebnis der resolution function, double
selection an Multiplexer Stufen [war nicht vhdl, sondern eine
syntaktisch aehnliche Sprache]).
Seit dieser Zeit gilt fuer mich:
Chipintern : std_Ulogic fuer interne Signale um doppelte Zuweisungen vom
Compiler erkennen zu lassen und std_ulogic nur da, wo ich weiss, das
tri-state (HZ) im Spiel ist, also an chip IOs.
PS: Spaetestens die Synthese wird (sollte) meckern, wenn zwei
Zuweisungen auf ein Signale erfogen, aber das wird in der Regel
wesentlich spaeter erkannt.
Moderator (Firma: Titel) Persönliche Seite #2313660
Die Synthese wird bei std_logic sowas einfach in einen Multiplexer
auflösen:
   output <= inputA when sel='1' else 'Z';
   output <= inputB when sel='0' else 'Z';
Und in Fällen, in denen ein Buskonflikt oder ein undefinierter Pegel
rauskommt, erscheint eine Fehlermeldung.
> Das letzte Mal, das mir chipinterne tri-atate Signale begegnet sind,
Die letzte Architektur bei Xilinx war der Spartan (ohne II oder 3 oder
E/A/AN).
> aber da hatte es schon mehr Nachteile als Vorteile
Begrenzte Ressourcen, lange Turn-Around Zeiten, Bustreiber-Konflikte...
Gast #2313783
> auflösen:   output <= inputA when sel='1' else 'Z';
> E/A/AN).
Da ich den Dietmar kenne, weiss ich auch worueber er redet: Es geht hier
nicht um FPGAs sondern um ASICs/Custom Logic Chips! Und da wird seeeeehr
lange nur simuliert, bevor ueberhaupt mal eine Synthese angeworfen wird.
Und dann bist du echt froh, wenn du rechtzeitig (also bei der
Simulation) einen potentiellen Konflikt gemeldet bekommst. Bis die Jungs
vom Physical Design ueberhaupt anfangen dauert, und wenn du dann wegen
sowas deine komplette Logic ueberdenken/-arbeiten musst dann geht da was
ganz gewaltig schief...
Also nicht nur an FPGA denken, sondern auch an 'was Groesseres...'
Gast #2313795
Erklaerung dazu: Die Jungs und Maedels von PD (physical design) koennen
gar nicht frueher anfangen, da z.B. Macros wie RAMs, CAMs, irgendwelche
Logic-Macros parallel zum Design entwickelt werden. D.h. da gibt es halt
lange Zeit nix fertiges was man synthetisieren kann. Beim FPGA ist das
easy, der Chip ist ja schon fertig, also kann man auch beim entwickeln
auf alle Resourcen zugreifen. Aber wenn's ASIC oder sowas ist, dann
sieht die Welt gleich ganz anders aus...
#2314622
@berndl
Danke fuer deine Erlaeuterungen:
In der Tat handelt es sich um (komplexe) ASICs, d.h. mit einem Versuch
sind >100.000$ 'verbrannt'. 'Einfaches' Nachprogrammieren geht da nicht,
und auf neue Hardware wartest du auch eine gewisse Zeit (mindestens
einen Monat fuer Aenderungen im Metall, wenn es ins Silizium auch
laenger...). Daraus folgt fuer mich: Wenn dir der Compiler beim Finden
eines Fehlers hilfreich sein kann, nutze dieses. Und std_ulogic hat
haertere Bedingungen als std_logic in der resolution function.
@manhunt
Ich halte den Coding style aufgrund meines (speziellen?) Backgrounds
fuer sinnvoll, er koennte deiner Firma Geld sparen (nicht nur wegen den
einmaligen Kosten, sondern auch wegen Time-to-Market).
@lkmiller
Es waren unerkannte Bus-Konflikte, und ein re-spin des Designs mit den
oben genannten Folgen.
Da es kein FPGA design war, war mein post evtl. deplaziert, aber
trotzdem bin ich der Meinung, wenn ein Fehler frueh erkannt wird, sind
die Folgekosten am Geringsten.
PS: Selbst das Debugging der Buskonflikte hat den Fortschritt der
gesamten Inbetriebnahme empfindlich gestoert.
Gast #2314809
Es gibt in Modelsim eine "Synthesis check"-Option, die bereits beim
Kompilieren anzeigt, ob ein Signal einen Cross-Treiber hat.
>>Warning: Nonresolved signal 'test_sig' may have multiple sources.
Wenn diese Simulator-Option zur Verfügung steht (vcom -synthesis_check),
dann benötigt man auch beim ASIC-Design kein "std_Ulogic" mehr.
VG, SuperWilly
  • [vhdl]VHDL-Code[/vhdl]
