Linux Bild plotten
Moderator Persönliche Seite #2326558
Ansonsten würde ich libpng vorschlagen.
Habe gerade ein wenig copy&paste aus der man page gemacht (weil's
mich selbst mal interessiert hat), das hier ergibt ein zumindest
lauffähiges Programm und könnte als Gerippe wohl dienen:
#include <png.h>
#include <stdio.h>
#include <setjmp.h>
#define file_name "test.png"
#define ERROR 1
png_byte data0[] = { 0, 10, 20, 30 },
  data1[] = { 10, 25, 40, 55 },
  data2[] = { 20, 40, 60, 80 },
  data3[] = { 30, 55, 80, 105 };
png_byte *row_pointers[4] = {
  data0, data1, data2, data3
void write_row_callback(png_structp png_ptr, png_uint_32 row,
                        int pass)
  /* put your code here */
24
int
25
main(void)
26
27
  FILE *fp = fopen(file_name, "wb");
28
  if (!fp)
29
30
      return (ERROR);
31
32
33
  png_structp png_ptr = png_create_write_struct(PNG_LIBPNG_VER_STRING, NULL,
34
                                                NULL, NULL);
35
  if (!png_ptr)
36
    return (ERROR);
37
38
  png_infop info_ptr = png_create_info_struct(png_ptr);
39
  if (!info_ptr)
40
41
      png_destroy_write_struct(&png_ptr,
42
                               (png_infopp)NULL);
43
      return (ERROR);
44
45
  if (setjmp(png_jmpbuf(png_ptr)))
46
47
      png_destroy_write_struct(&png_ptr, &info_ptr);
48
      fclose(fp);
49
      return (ERROR);
50
51
  png_init_io(png_ptr, fp);
52
53
  png_set_write_status_fn(png_ptr, write_row_callback);
54
55
  /* turn on or off filtering, and/or choose
56
     specific filters.  You can use either a single
57
     PNG_FILTER_VALUE_NAME or the bitwise OR of one
58
     or more PNG_FILTER_NAME masks. */
59
#if 0
60
  png_set_filter(png_ptr, 0,
61
                 PNG_FILTER_NONE  | PNG_FILTER_VALUE_NONE |
62
                 PNG_FILTER_SUB   | PNG_FILTER_VALUE_SUB  |
63
                 PNG_FILTER_UP    | PNG_FILTER_VALUE_UP   |
64
                 PNG_FILTER_AVG   | PNG_FILTER_VALUE_AVG  |
65
                 PNG_FILTER_PAETH | PNG_FILTER_VALUE_PAETH|
66
                 PNG_ALL_FILTERS);
67
#endif
68
  /* set the zlib compression level */
69
  png_set_compression_level(png_ptr,
70
                            Z_BEST_COMPRESSION);
71
72
  /* set other zlib parameters */
73
  png_set_compression_mem_level(png_ptr, 8);
74
  png_set_compression_strategy(png_ptr,
75
                               Z_DEFAULT_STRATEGY);
76
  png_set_compression_window_bits(png_ptr, 15);
77
  png_set_compression_method(png_ptr, 8);
78
  png_set_compression_buffer_size(png_ptr, 8192);
79
80
  png_set_IHDR(png_ptr, info_ptr,
81
               4, 4,            /* width, height */
82
               8,               /* bit_depth */
83
               PNG_COLOR_TYPE_GRAY,
84
               PNG_INTERLACE_NONE,
85
               PNG_COMPRESSION_TYPE_DEFAULT,
86
               PNG_FILTER_TYPE_DEFAULT);
87
  png_write_info(png_ptr, info_ptr);
88
  png_write_image(png_ptr, row_pointers);
89
90
  png_write_end(png_ptr, info_ptr);
91
92
93
  fclose(fp);
94
95
  return 0;
96
