Neues für die DIP-Freunde
OP Persönliche Seite #2394664
Zusammengefasst:
Es wird Varianten des LPC111x im DIP28 geben.
Hier die Ankündigung, Quelle lpc2000-group auf Yahoo:
NXP today announced the availability of new low-pin-count package
options -- SO20, TSSOP20, TSSOP28 and DIP28 -- for its market-leading
ARM(R) Cortex(TM)-M0 LPC1100 family of microcontrollers. The new LPC111x
devices are the world's first 32-bit ARM microcontrollers in
low-pin-count packages, and open the door for a broader range of
applications previously closed to typical 32-bit MCUs due to package
footprint or manufacturing constraints. Starting at $0.49, NXP's
low-pin-count devices deliver 50 MIPS of performance compared to the 1
to 5 MIPS performance typical of 8/16-bit MCUs, at a highly competitive
price point enabled by NXP's exceptional capacity in manufacturing
high-volume commodity packages.
"Our Cortex-M0 family has grown to become the most complete offering for
entry-level 32-bit MCUs, and today we extend it to an unprecedented
$0.01-per-MIPS value for traditional 8/16-bit applications," said
Pierre-Yves Lesaicherre, senior vice president and general manager,
microcontrollers and logic, NXP Semiconductors. "Shipping over three
billion TSSOP and SO packages per year gives us the flexibility and
scale to continuously drive towards lower price points and to introduce
sub-40 cent 32-bit MCU solutions in 2012."
With the world's smallest 32-bit MCU, the LPC1102, available in a 2-mm x
2-mm Chip-Scale Package (CSP), NXP is at the forefront of innovation in
microcontroller packaging and has the widest selection of package
options for Cortex-M0 MCUs. The introduction of the new low-pin-count
package options provide reduced footprint and system-cost benefit to
customers throughout the product development cycle. SO and DIP packages
provide ease of customer prototyping with the ability to hand-solder,
simplifying hardware requirements for programming and debugging. TSSOP
packages eliminate potential reflow process in high-volume production.
These easy-to-use and highly reliable packages are popular among
8/16-bit customers and help minimize the number of manufacturing
processes while improving yield to further reduce overall system costs.
Existing LPC1100 customers can easily convert their designs to the
LPC111x low-pin-count devices and reuse their software due to the
identical Cortex-M0 instruction set. In addition, these low-pin-count
packages are designed for easy PCB layout and scalability by sharing the
same pin-out for VDD, VSS, GND, and XTAL.
The LPC1100 series can execute sophisticated algorithms at low power,
meeting the ever-increasing demands of cost-sensitive applications that
8-bit microcontrollers struggle to achieve, such as interfacing with
sensors and performing complex control tasks. For example, a 16-bit
multiply operation performed by an 8-bit microcontroller requires 48
clock cycles at over 770 uA/MHz, while an LPC1100 device can complete
the same task in 1 cycle at 130 uA/MHz.
Along with this high performance capability, NXP's Cortex-M0 LPC1100
family also has numerous innovations in its design:
--  Timers with PWM generation - For each timer, up to four match
registers can be configured as PWM, allowing each timer to support up to
three match outputs as single edge controlled PWM outputs.
--  Dynamic system clock switching - Change frequency on the fly
depending on processing demand. The LPC1100 current consumption at 50
MHz is specified at 7 mA. This can be reduced to a little over 130 uA
when running at 1 MHz on the low-power internal oscillator.
--  Clock output - The clock output with divider can reflect the system
oscillator clock, IRC clock, CPU clock, and the Watchdog clock. The
output can source downstream devices such as other microcontrollers,
CPLD or FPGA.
--  Interrupt via any GPIO - Any GPIO pins can be used as Edge- and
Level-Sensitive interrupt sources.
--  Programmable pull up/down/open drain - Internal pull-up/pull-down
resistor, pseudo open drain or bus keeper function.
--  Enhanced GPIO pin manipulation - Capable of simultaneously reading
Bit/Byte/Word or toggling up to 22 I/Os per instruction.
These unique features not only bring design and system benefits, but
also help to accelerate the replacement of 8/16-bit MCUs in many
applications. Other key specifications for the LPC111x devices include:
        --  Cortex-M0 CPU at 130 uA/MHz, up to 50-MHz CPU clock
        --  Up to 4 KB SRAM and 32 KB Flash
        --  SPI, UART and I2C (Fast-mode Plus)
        --  5-channel 10-bit ADC
        --  Two 32-bit Timers and two 16-bit Timers
        --  1% accuracy, 12-MHz IRC
        --  Power Profile options via API calls
Tools
All NXP Cortex-M microcontrollers are software compatible and offer all
the advantages of a single development toolchain. Users can easily
migrate their designs between Cortex-M0 and Cortex-M3 with minimal
effort. The easy-to-use LPCXpresso IDE for the LPC1100 series is priced
under US $30. For further information on LPCXpresso and other
third-party development tools, see www.nxp.com/lpcxpresso , or attend
one of the NXP sponsored sessions at ARM TechCon 2011 this week for a
free development tool.
Pricing and Availability
Recommended distribution unit pricing for 10,000 piece quantities is US
$0.49 for the LPC1110FD20. Samples are available in November 2011.
Additional information is available at
http://www.nxp.com/products/microcontrollers/cortex_m0/lpc1100l/
#2394713
Ich habe die Nachricht selbst gerade gelesen und kann es kaum fassen das
es DIP Gehäuse geben soll. Wenn die Teile dann auch noch ihr besseres
Preis / Leistungsverhältnis zum AVR halten können, haben sie wirklich
das Zeug die Atmegas als Einstiegsdroge für Hobbyisten verdrängen zu
können. Ich persöhnlich warte schon lange auf so eine Nachricht und
freue mich darauf ein paar der Projekte, auf den sonst ein Atmega 8 oder
ähnliches gelandet wäre, damit aufzubauen.
#2792410
Lothar schrieb:
> Klar. Das Ding hat zudem kaum einen Wert, somit fällt auch kein Zoll an.
> Allerdings rentieren sich die Versandkosten für nur 1 Stück kaum.
Sehe gerade, dass man sich für Europa nur als Geschäftskunde anmelden
kann. Und aus Übersee zahle ich 50 € Versand. Leider rentiert sich das
für ~10 Stück wirklich nicht. Schade.
> Um das Geld könnte man gleich das hier nehmen, sind dann auch mehr
> I/O-Pins rausgeführt als bei DIP:
> https://www.olimex.com/dev/lpc-h11xx.html
Sowas habe ich schon und verwende das auch gerne, DIP wäre nur schön
gewesen für viele Kleinstprojekte. Bei Stückpreisen um 1 Euro kann man
ja nix verlieren.
Gast #2792429
Ernst B. schrieb:
> Entgegen meiner Erwartung dürften sich also µC im Dip-Gehäuse doch sehr
> gut verkaufen und entsprechende Stückzahlen bringen.
Das ist stark übertrieben. Selbst alle Bastler Europas zusammen bringen
nicht die Stückzahl auch nur eines einzigen Waschmaschinen-Modells. Ist
nicht abwertend gemeint, nur einfach realistisch. Und chinesische
Billighersteller können schon lang SMD (sonst wären sie auch nicht ganz
so billig).
Gruss Reinhard
#2793836
> so billig).
> Gruss Reinhard
Irgendwo muss ja ein Markt für DIP Bauteile sein, sonst würde Atmel und
Microchip und eben seit neuestem NXP ihre Microcontroller nicht in DIP
rausbringen.
#2793932
Es ist einfach nicht wahr, dass alles was Großserie ist, in SMD
gefertigt wird. Ich habe hier z.B. eine Maus: einseitige LP, ein
optischen Sensor DIP, ein IC DIP, Hühnerfutter auch bedrahtet und die
war noname, also ganz billig gewesen und auch noch nicht soo alt. Es
kommt scheinbar doch auf ein paar Parameter, wie Platzverhältnisse etc.
an, was billiger ist.
Gast #2793976
Die DIP Version hat schon noch ihre Berechtigung für Prototypen und für
deb Hobbybereich.  Das bringt nicht die großen Stückzahlen, aber so
wenige sind es auch nicht.  Auch sorgt dafür das sich mehr Leute mit den
µC beschäftigen und dann ggf. auch später im Beruf den µC schon kennen.
So besonders hoch sind die Kosten für die zusätzliche Variante ja auch
nicht.
Ein Problem ist aber bei einigen schnellen Teilen, dass die
Abblockkondensatoren im DIP nicht mehr nahe genug an den Die kommen.
Gast #2793988
Das Problem ist einfach der Herstellungsprozess. Jede Firma die Bestückt
wird dir erzählen, dass DIP zu bestücken umständlicher und damit teurer
ist.
Was in COmutermäusen drin ist sind zum Teil Restbestände.
Neuere Modelle haben auch mal nen Epoxidblob wo der Chip auf die Platine
gebonded wird.
Gast #2794078
> gefertigt wird.
Veraltete Technik gibt es immer mal, aber SMD hat sich auch deshalb so
schnell durchgesetzt, weil ein SMD-Bestückungsautomat weitaus billiger
ist als eine THT-Linie, und effektiver auch - die SMD-Bautiele sind fast
alle fertig zum Bestücken, nix mit Umgurten, Abschneiden, Sicken usw.
und dann noch mit dem Draht ins Loch treffen...
Gruss Reinhard
Gast #2794082
> gut verkaufen und entsprechende Stückzahlen bringen. Sehr interessant.
Ehrlich - in welcher Welt lebst du? Das ist eine Mitleidsmasche des
Herstellers, dass er für Hobbybastler die Sache noch im DIP Gehäuse
anbietet. Mehr aber auch nicht. Klar gut ist für die Hobbybastler, aber
gib dich nicht der Illusion hin, dass sowas Stückzahlen sind....
Gast #2794102
Wäre doch jetzt mal interessant zu erfahren, wie viel Aufwand es für den
Hersteller ist, einen ohnehin als SMD produzierten Chip kurzfristig in
ein anderes Gehäuse zu vergießen.
Ich hab offen gestanden keine Vorstellung davon, wie das in der Fab
läuft. Könnte mir aber vorstellen, dass die einzelnen Die zerteilt in
irgendeiner 'standardisierten' Form von Tray in den Automaten wandern,
gebondet und vergossen werden. Da würde doch nichtmal viel Rüstzeit
anfallen, oder?
Die Bastler von heute sind die Großkunden von morgen.. oder so ähnlich
Gast #2794136
Wenn man von verschiedenen Halbleiterherstellern die eigentlichen Chips
"nackig" verkauft bekäme, hätte ich eine gute Geschäftsidee:
Alles, was <64 Anschlüsse hat und vom Originalhersteller nur als SMD
"gebaut" wird, als DIL-Schaltkreis zu verkaufen, wenn der Hersteller
meint,
das lohne sich für ihn selbst nicht.
Man bräuchte nicht so einen großen Maschinenpark und könnte alle
möglichen
Leute mit DIL beliefern, denn die Schaltkreise müssen ja "nur" gebondet
und
gekapselt werden.
Koppi Reit bei
Paul Baumann
Gast #2794221
Paul Baumann schrieb:
> eine gute Geschäftsidee...
O ha, da sag ich dir, daß du gleich ein Stück weiter denken solltest:
Nimm nen fertigen im Chipscale-Gehäuse, dazu gleich noch ein paar
Stützkondensatoren, Quarz und Programmieranschluß und setze das Ganze
auf ne LP im DIL40-Format für all diejenigen, die immer noch mit
Steckbrettern basteln.
W.S.
#2794228
Hab ein kommerzielles Ladegerät, da ist ein DIP uC drin.
Wird also kommerziell auch noch verbaut.
#2794256
@W.S.
Du wirst lachen: Das habe ich mit einem Attiny2313 so gemacht und diese
Platine wird von meinen Kompagnons gerne benutzt resp. nachgebaut.
Mir geht es ja nicht nur um Kontroller, sondern auch um viele andere
Schaltkreise, die die Leute gerne einsetzen würden, wenn sie sie nur
erkennen könnten. Dieses "Elektronikgranulat" ist doch Mist und oft
bestimmt die mechanische Größe von Bedienelementen, Kühlkörpern,
Anzeigen
etc. das Volumen von Apparaten. Da ist die Größe der Schaltkreise
völlig Brust.
MfG Paul
