Watchdog timer implementation in VHDL
Gast #2467692
warning: may contain traces of nuts!
no warranty to spelling, mistakes, dogs or watches(not even swiss
ones)....
entity watchdog
port
   clk : in std_logic;
   dog : out std_logic
signal watch : integer range 0..desired := 0;
process (clk)
 if rising_edge(clk) then
  if watch<desired then
   watch <= watch + 1;
   dog <= '0';
  else
   watch <= 0;
   dog <= '1';
  end if;
 end if;
end process;
Gast #2467993
>> what about initialisation of the counter?
done. (no grandpa methods)
>> and observation of signal presence?
can't see this requirement
>>  and start up delay to tolerate late occurance?
the early bird catched the worm...
also you probably know: the last is biten by the dogs, so better watch
out.
(the universe tends to maximum irony but still some people don't see it)
Gast #2470506
hiii
friends ...actually we want to detect the clock whether its continuously
going high and low or not....
so if its by fault, its stable at some position let us say "high" (not
going to low)..so then we want to get the reply from the watchdog timer
that something is wrong with clock and it will reset or reply to FPGA or
CPLD....
so do u have any VHDL implimentation logic behind it?.....we tried it
but still its not ok...
Merry xmas to all...
thanks...
Gast #2483933
Actually we need to program the FPGA in VHDL which implements the
Watchdog timer logic...thats our primary requirement..we also thought
about hardware Watchdog timer as an alternative to this...but first we
want to have software algorithm for that.....
