AVR Studio 5 ignoriert Code Zeilen
OP #2494286
bei mir scheint AVR Studio 5 gewisse Zeilen einfach zu ignorieren.
Speziell geht es um sie Zeilen 10 bis 13:
  if (adc1_Offset == 0x8000)
    InitWithZero = true;
    adc1_Offset = 0x0000;
Beim debuggen behält ''adc1_Offset '' stehts den Wert 0x8000. Auch
"InitWithZero" wird nicht auf True gestellt.
Schaut man sich die ensprechende Assembler-Code an, so tauchen die
beiden Variablen gar nicht auf!!
Was mach ich denn falsch? Oder ist das ein Bug?
HILFE!!? :'(
/**///  LoadUpHighSide()
uint16_t LoadUpHighSide(void)
{  AVR_Func_USART_SendString("\n\nLoadUpHighSide");
  static uint16_t adc1_Offset = 0x8000;
  uint8_t InitWithZero = false;
  //////  get iAct (i_L) offset  ////////////////////////////////////////////
    // first start executed before
    while(  !(ADCA_CH1_INTFLAGS&0x01)&0x01 );
    ADCA_INTFLAGS = 0b0010;    //clear ADC1 flag
    adc1_Offset = ADCA_CH1_RES-0x1234;
    for (uint8_t i=1; i<=3; i++)
      ADCA_CTRLA |= (0b0010<<2);  // ([3210]<<2): channel 1
23
24
25
      adc1_Offset += (ADCA_CH1_RES);
26
      adc1_Offset+=10;
27
28
29
    adc1_Offset = adc1_Offset>>2;  //div 4
30
    adc1_Offset = adc1_Offset - 512;
31
32
33
  //////  ADC1 conversion (iAct,i_L)  ////////////////////////////////////////
34
35
36
  ADCA_INTFLAGS = 0x02;    //clear ADC1 flag
37
38
  //////  get values  ////////////////////////////////////////////
39
  uint16_t iSet = 512 - LOADUP_CURRENT_ADC;
40
  uint16_t iAct = (ADCA_CH1_RES >> 2) - adc1_Offset;
41
42
  //////  select current sensor  ////////////////////////////////////////////////
43
  #if CURRENT_SENSOR_I_MAX == 50    // sensor range =  -50A ...  +50A
44
    iAct = ( (iAct+512) >> 1 );  // (iL-512)/2 + 512
45
  #elif CURRENT_SENSOR_I_MAX == 100  // sensor range = -100A ... +100A
46
    //  do nothing
47
  #else
48
    #error define 'CURRENT_SENSOR_I_MAX'
49
  #endif
50
51
  //////  control current to 2 A  ////////////////////////////////////////////
52
  uint16_t LoadUpPWM = CurrentControl(iSet, iAct, InitWithZero, boost, 0x0000);
53
  LoadUpPWM = LoadUpPWM>>7;
54
  TCF0_CCA = LoadUpPWM;
55
  TCF0_CCC = LoadUpPWM;
56
57
  return 0x1234;
58
000004B8  LDS R24,0x21C9    Load direct from data space
000004BA  LDS R25,0x21CA    Load direct from data space
000004BC  SUBI R24,0x00    Subtract immediate
000004BD  SBCI R25,0x80    Subtract immediate with carry
000004BE  BREQ PC+0x03    Branch if equal
000004BF  LDI R20,0x00    Load immediate
000004C0  RJMP PC+0x0030    Relative jump
--- D:\dSeb work\AVRStudio5\LeoCode NightBuild\EM\default/.././main.c ----------
000004C1  LDS R24,0x022B    Load direct from data space
000004C3  SBRS R24,0    Skip if bit in register set
000004C4  RJMP PC-0x0003    Relative jump
000004C5  LDI R24,0x02    Load immediate
000004C6  STS 0x0206,R24    Store direct to data space
000004C8  LDS R18,0x022C    Load direct from data space
000004CA  LDS R19,0x022D    Load direct from data space
000004CC  SUBI R18,0x34    Subtract immediate
000004CD  SBCI R19,0x12    Subtract immediate with carry
000004CE  LDI R20,0x01    Load immediate
23
24
000004CF  LDI R21,0x02    Load immediate
25
26
000004D0  LDS R24,0x0200    Load direct from data space
27
000004D2  ORI R24,0x08    Logical OR with immediate
28
000004D3  STS 0x0200,R24    Store direct to data space
29
30
000004D5  LDS R24,0x022B    Load direct from data space
31
000004D7  SBRS R24,0    Skip if bit in register set
32
000004D8  RJMP PC-0x0003    Relative jump
33
34
000004D9  STS 0x0206,R21    Store direct to data space
35
36
000004DB  LDS R24,0x022C    Load direct from data space
37
000004DD  LDS R25,0x022D    Load direct from data space
38
      adc1_Offset+=10;
39
000004DF  ADIW R24,0x0A    Add immediate to word
40
000004E0  ADD R18,R24    Add without carry
41
000004E1  ADC R19,R25    Add with carry
42
43
000004E2  SUBI R20,0xFF    Subtract immediate
44
45
000004E3  CPI R20,0x04    Compare with immediate
46
000004E4  BRNE PC-0x14    Branch if not equal
47
48
000004E5  LSR R19    Logical shift right
49
000004E6  ROR R18    Rotate right through carry
50
000004E7  LSR R19    Logical shift right
51
000004E8  ROR R18    Rotate right through carry
52
53
000004E9  SUBI R18,0x00    Subtract immediate
54
000004EA  SBCI R19,0x02    Subtract immediate with carry
55
000004EB  STS 0x21C9,R18    Store direct to data space
56
000004ED  STS 0x21CA,R19    Store direct to data space
57
000004EF  LDI R20,0x01    Load immediate
58
59
000004F0  LDS R24,0x0200    Load direct from data space
60
000004F2  ORI R24,0x08    Logical OR with immediate
61
000004F3  STS 0x0200,R24    Store direct to data space
#2494303
IntWithZero schon.
Du hast den Optimizer eingeschaltet?
Wozu soll der Compiler hier
adc1_Offset auf 0 setzen, wenn es gleich darauf hier
sowieso wieder einen anderen Wert bekommt?
Dazwischen gibt es keine Möglichkeit, dass adc1_Offset irgendwie
ausgewertet werden könnte, d.h. wenn das Programm erst mal hier
angelangt ist, spielt es keine Rolle, ob adc1_Offset zwischendurch mal 0
war oder nicht.
Deshalb wird der Optimizer die Zuweisung mit 0x0000 wohl rausgeschmissen
haben.
Gast #2494310
Moin Moin, Hab mich jetz nicht durch deinen Code gekämpft aber,
Ich hatte das Problem auch schonmal das der Code offentsichtlich nicht
berücksichtigt wurde. Es lag schlicht und einfach am volatile, das dem
Compiler sagt das die Variable nicht weg optimiert werden soll.
probier es einfach mal aus.
Grüße
Gast #2494336
adc1_Offset ist in den Speicheradressen 0x21C9 und 0x21CA beheimatet.
Dessen Zuweisung
kann der Compiler wegoptimieren, weil adc1_Offset nicht volatile ist und
ein paar Zeilen später ein anderer Wert gesetzt wird.
InitWithZero ist eine nicht statische lokale Variable, d.h. der
Compiler kann versuchen die in einem Register zu halten, und die
Zuweisung
kann der Compiler bis max. vor die schliessende Klammer
verzögern. Und genau das macht er.
ist die Zuweisung.
Gast #2495384
NEIN! NEIN! NEIN! Nicht einfach nen volatile irgendwo hinschmeißen, um
den Optimizer an seiner korrekten arbeit zu hindern. Volatile bitte nur,
wo der Optimizer durch Interrupts nicht wissen kann, dann eine Variable
noch gebraucht wird.
