Hallo, ich habe ein Olimex Board (STM32-P207) mit einem Olimex ARM-USB-TINY-H JTAGE Interface. Kann mir jemand helfen?? Folgendes Problem trifft auf, wenn ich den STM32 flashen möchte: C:\Users\michi\Desktop\openocd-x64-0.5.0\bin>openocd-x64-0.5.0.exe -f olimex-arm -usb-tiny-h.cfg -f stm32f2x.cfg Open On-Chip Debugger 0.5.0 (2011-08-09-23:26) Licensed under GNU GPL v2 For bug reports, read http://openocd.berlios.de/doc/doxygen/bugs.html Info : only one transport option; autoselect 'jtag' 300 kHz adapter_nsrst_delay: 100 jtag_ntrst_delay: 100 Info : max TCK change to: 30000 kHz Info : clock speed 300 kHz Info : JTAG tap: stm32f2xxx.cpu tap/device found: 0x4ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x4) Info : JTAG tap: stm32f2xxx.bs tap/device found: 0x06411041 (mfg: 0x020, part: 0 x6411, ver: 0x0) Info : stm32f2xxx.cpu: hardware has 6 breakpoints, 4 watchpoints Info : accepting 'gdb' connection from 3333 Info : device id = 0x20016411 Info : flash size = 1024kBytes Info : The target is not running when halt was requested, stopping GDB. undefined debug reason 6 - target needs reset Info : The target is not running when halt was requested, stopping GDB. Info : The target is not running when halt was requested, stopping GDB. Info : The target is not running when halt was requested, stopping GDB. Info : The target is not running when halt was requested, stopping GDB. Info : The target is not running when halt was requested, stopping GDB. Info : The target is not running when halt was requested, stopping GDB. Info : The target is not running when halt was requested, stopping GDB. Error: JTAG-DP STICKY ERROR Error: MEM_AP_CSW 0x23000052, MEM_AP_TAR 0x40023c08 Error: JTAG-DP STICKY ERROR Error: MEM_AP_CSW 0x23000052, MEM_AP_TAR 0x40023c08 Warn : Block write error address 0x40023c04, wcount 0x1 Info : The target is not running when halt was requested, stopping GDB. Error: JTAG-DP STICKY ERROR Error: MEM_AP_CSW 0x23000052, MEM_AP_TAR 0x40023c08 Error: JTAG-DP STICKY ERROR Error: MEM_AP_CSW 0x23000052, MEM_AP_TAR 0x40023c08 Warn : Block write error address 0x40023c04, wcount 0x1 Info : The target is not running when halt was requested, stopping GDB. Info : The target is not running when halt was requested, stopping GDB. Info : The target is not running when halt was requested, stopping GDB.
hey ysp, ich hatte heute auch mit diesem problem zu kämpfen. mein stm32l1 device ließ sich plötzlich nicht mehr flashen. ich benutze openocd + gdb mit ftdi basiertem adapter. der knackpunkt liegt bei: Warn : Block write error address 0x40023c04, wcount 0x1 um der sache näher zu kommen, kann man bei openocd alle debug meldungen ausgeben. dazu folgendes im gdb eingeben: mon debug_level 3 dann kommst du vermutlich auf eine ausgabe wie diese: Debug: 146 74371 target.c:1930 target_read_u32(): address: 0x40023c18, value: 0x0000050c Error: 147 74371 stm32lx.c:869 stm32lx_wait_until_bsy_clear(): access denied / write protected wenn man im quelltext etwas kramt, kommt man darauf, dass in einem der optionsregister FLASH_SR (flash status register, beim stm32l1 @ 0x40023C18) fehlerbits gesetzt sind: WRPERR (bei mir noch SIZERR), welche bei write-protect violation gesetzt werden. lange rede kurzer sinn, wenn man das read protection level RDP im info block von NVM (siehe reference manual 3.5. option byte description) von 1 auf 0 übergehen lässt, wird der seltsame lese-/schreibschutz aufgehoben. eine beschreibung, wie man diesen übergang von RDP level 1 auf level 0 manuell realisiert, findest du hier: https://my.st.com/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=https%3a%2f%2fmy.st.com%2fpublic%2fSTe2ecommunities%2fmcu%2fLists%2fcortex_mx_stm32%2fFlash%20Programming%20Locked%20Out&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580009C4E14902C3CDE46A77F0FFD06506F5B¤tviews=1855 (ganz kurz beschrieben: schreibschutz für option-register mittels FLASH_OPTKEYR register aufheben laut refman "3.4.1 Unlocking/locking memory" ; (gdb) mon mww 0x1ff80000 0xffee0011 (rdp auf level 1); reset ; schreibschutz nochma aufheben; (gdb) mon mww 0x1ff80000 0xff5500aa (rdp auf level 0)) grüße flo
