Fehler bei Nutzung von <avr/eeprom.h>
OP #2556763
Moin!
Folgende Funktionen werfen bei mir Fehler, genauer genommen dir Aufrufe
der EEPROM-Makros darin:
void check_eemem(void){
  uint8_t temp;
  temp = eeprom_read_byte(&chip_erase_check);
  #define CHECK_NEGATIVE 0xAA
  if(temp == CHECK_NEGATIVE){
    return;
  PROG_ACTIVE_PORT |= (1<<PROG_ACTIVE); // indicate EEPROM default writing
  eeprom_write_byte(&prog_speed_eemem, 175);
  eeprom_write_byte(&prog_wait_eemem, 175);
  eeprom_write_word(&powerleda_on_eemem, POWERLED_ON);
  eeprom_write_word(&powerledb_on_eemem, POWERLED_ON);
  eeprom_write_byte(&chip_erase_check, CHECK_NEGATIVE);
void init_variables_from_eeprom(void){
23
24
  prog_speed = eeprom_read_byte(&prog_speed_eemem);
25
  prog_wait = eeprom_read_byte(&prog_wait_eemem);
26
  powerleda_on = eeprom_read_word(&powerleda_on_eemem);
27
  powerledb_on = eeprom_read_word(&powerledb_on_eemem);
28
29
Die Fehlermeldung:
avr-gcc-462 -mmcu=attiny4313 -Os -o vitrinencontroller.o
/tmp/ccHdXgBX.o: In function `check_eemem':
vitrinencontroller.c:(.text+0x6c): undefined reference to `__eerd_byte_tn4313'
vitrinencontroller.c:(.text+0x7a): undefined reference to `__eewr_byte_tn4313'
vitrinencontroller.c:(.text+0x82): undefined reference to `__eewr_byte_tn4313'
vitrinencontroller.c:(.text+0x8c): undefined reference to `__eewr_word_tn4313'
vitrinencontroller.c:(.text+0x96): undefined reference to `__eewr_word_tn4313'
vitrinencontroller.c:(.text+0x9e): undefined reference to `__eewr_byte_tn4313'
/tmp/ccHdXgBX.o: In function `init_variables_from_eeprom':
vitrinencontroller.c:(.text+0xa6): undefined reference to `__eerd_byte_tn4313'
vitrinencontroller.c:(.text+0xb0): undefined reference to `__eerd_byte_tn4313'
vitrinencontroller.c:(.text+0xba): undefined reference to `__eerd_word_tn4313'
vitrinencontroller.c:(.text+0xc8): undefined reference to `__eerd_word_tn4313'
collect2: ld returned 1 exit status
Ich habe leider keinen Schimmer woher der Fehler kommt oder wie ich ihn
beheben kann.
GCC-Version ist 4.6.2 (für Linux)
Wäre euch für einen Tipp oder sogar eine Lösung sehr dankbar!
Ist es vielleicht schlauer, die Funktionen zum Lesen und Schreiben auf
den EEPROM selbst zu schreiben?
LG :)
PS: Hier nochmal die verbose-Ausgabe und Variablendeklaration:
avr-gcc-462 -mmcu=attiny4313 -Os -o vitrinencontroller.o vitrinencontroller.c -v
Using built-in specs.
COLLECT_GCC=avr-gcc-462
COLLECT_LTO_WRAPPER=/opt/cross/avr/lib64/gcc/avr/4.6.2/lto-wrapper
Target: avr
Configured with: ../gcc-4.6.2/configure -v --prefix=/opt/cross/avr --exec-prefix=/opt/cross/avr --libdir=/opt/cross/avr/lib64 --libexecdir=/opt/cross/avr/lib64 --mandir=/opt/cross/avr/share/man --infodir=/opt/cross/avr/share/info --with-gnu-ld --with-gnu-as --target=avr --enable-languages=c,c++ --program-prefix=avr- --program-suffix=-462 --with-sys-root=/opt/cross/avr --disable-nls --disable-libssp --with-dwarf2 --with-ppl --with-cloog
Thread model: single
gcc version 4.6.2 (GCC)
COLLECT_GCC_OPTIONS='-mmcu=attiny4313' '-Os' '-o' 'vitrinencontroller.o' '-v'
 /opt/cross/avr/lib64/gcc/avr/4.6.2/cc1 -quiet -v -imultilib avr25 vitrinencontroller.c -quiet -dumpbase vitrinencontroller.c -mmcu=attiny4313 -auxbase vitrinencontroller -Os -version -o /tmp/cc2CdcMf.s
GNU C (GCC) version 4.6.2 (avr)
  compiled by GNU C version 4.5.1 20101208 [gcc-4_5-branch revision 167585], GMP version 4.3.1, MPFR version 2.4.1, MPC version 0.8.2
GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072
ignoring nonexistent directory "/opt/cross/avr/lib64/gcc/avr/4.6.2/../../../../avr/sys-include"
#include "..." search starts here:
#include <...> search starts here:
 /opt/cross/avr/lib64/gcc/avr/4.6.2/include
 /opt/cross/avr/lib64/gcc/avr/4.6.2/include-fixed
 /opt/cross/avr/lib64/gcc/avr/4.6.2/../../../../avr/include
End of search list.
23
24
25
Compiler executable checksum: ac8561fadc0ef465e608e5307f37bf40
26
27
 /opt/cross/avr/lib64/gcc/avr/4.6.2/../../../../avr/bin/as -v -mmcu=attiny4313 -o /tmp/ccCyvqfh.o /tmp/cc2CdcMf.s
28
GNU assembler version 2.22 (avr) using BFD version (GNU Binutils) 2.22
29
COMPILER_PATH=/opt/cross/avr/lib64/gcc/avr/4.6.2/:/opt/cross/avr/lib64/gcc/avr/4.6.2/:/opt/cross/avr/lib64/gcc/avr/:/opt/cross/avr/lib64/gcc/avr/4.6.2/:/opt/cross/avr/lib64/gcc/avr/:/opt/cross/avr/lib64/gcc/avr/4.6.2/../../../../avr/bin/
30
LIBRARY_PATH=/opt/cross/avr/lib64/gcc/avr/4.6.2/avr25/:/opt/cross/avr/lib64/gcc/avr/4.6.2/../../../../avr/lib/avr25/:/opt/cross/avr/lib64/gcc/avr/4.6.2/:/opt/cross/avr/lib64/gcc/avr/4.6.2/../../../../avr/lib/
31
32
 /opt/cross/avr/lib64/gcc/avr/4.6.2/collect2 -m avr25 -o vitrinencontroller.o /opt/cross/avr/lib64/gcc/avr/4.6.2/../../../../avr/lib/avr25/crttn4313.o -L/opt/cross/avr/lib64/gcc/avr/4.6.2/avr25 -L/opt/cross/avr/lib64/gcc/avr/4.6.2/../../../../avr/lib/avr25 -L/opt/cross/avr/lib64/gcc/avr/4.6.2 -L/opt/cross/avr/lib64/gcc/avr/4.6.2/../../../../avr/lib /tmp/ccCyvqfh.o -lgcc -lc -lgcc
33
34
/tmp/ccCyvqfh.o: In function `check_eemem':
35
36
37
38
39
40
41
/tmp/ccCyvqfh.o: In function `init_variables_from_eeprom':
42
43
44
45
46
/// EEPROM variables
uint8_t chip_erase_check EEMEM;
uint8_t prog_speed_eemem EEMEM;
uint8_t prog_wait_eemem EEMEM;
uint16_t powerleda_on_eemem EEMEM;
uint16_t powerledb_on_eemem EEMEM;
OP #2557976
J. W. schrieb:
>> und schau rein woher er diese
>> Funktionen nehmen will.
> Ist angehängt.
Achso, sorry. Ich sollte ja selber schauen. Das habe ich auch, aber
leider werde ich nicht wirklich schlau draus.
Die Suche hier bringt übrigens auch nichts, was hilft.
LG :)
Nachtrag: Im Map-File findet sich nur dieser Abschnitt zum EEPROM. Aber
da steht ja nirgens, woher er die Funktionen nehmen will? Ist das
überhaupt das Problem, was mit 'undefined reference' gemeint ist?
Im Mapfile finde ich, wenn ich das richtig deute, wohl nur die
Speicheradressen der EEPROM-Variablen.
.eeprom         0x0000000000810000        0x7
 *(.eeprom*)
 .eeprom        0x0000000000810000        0x7 /tmp/cc835xwu.o
                0x0000000000810000                powerledb_on_eemem
                0x0000000000810002                powerleda_on_eemem
                0x0000000000810004                prog_wait_eemem
                0x0000000000810005                prog_speed_eemem
                0x0000000000810006                chip_erase_check
                0x0000000000810007                __eeprom_end = .
OP #2558112
Entwarnung!
Meine eigenen Nachforschungen in Richtung fehlende Implementierung in
der avr-libc von SuSE für den ATtiny4313 waren erfolgreich.
Ich kenne das ja schon: Beitrag "Für ATtiny4313 kompilieren?"
Auch hier hat es wieder geholfen, die Datei .../avr/avr/lib/avr25/libc.a
aus dem Fedora-Repository zu "klauen" und die bestehende aus dem
SuSE-Repo damit zu ersetzen.
Läuft alles!
LG :)
