MSP430 LaunchPad Taster Interrupt
OP #2788931
#include <msp430g2231.h>
/* MSP430 PushButton that toggles LEDs On and Off                                       */
/* Description: PushButton in P1.3 through interrupt turns on and off the LED at P1.0   */
/* and P1.6.  By changing the P1.3 interrupt edge, the interrupt is called every time   */
/* the button is pushed and pulled; toggling the LED everytime.                         */
/* (#1 Pull Up)LaunchPad revisions 1.3 and 1.4 come with R34 populated. The 47-kO resistor is used as a pullup for the button S2. */
/* If the port P1.3 is driven to ground, as suggested to keep the power consumption down, the pullup resistor generates an additional current of approximately 77 µA. */
/* To reduce the power consumption, the port should stay in input mode or the resistor should be removed if button S2 is not used. The internal pullup of the MSP430G2xx can be used instead. */
#define LED1    BIT0
#define LED2    BIT6
#define BUTTON  BIT3
int main(void)
    WDTCTL = WDTPW + WDTHOLD;           /* Stop watchdog timer */
    P1DIR |= (LED1 + LED2);             /* Set LEDs to output direction */
                                        /* P1.3 must stay at input (this is the default) */
23
24
    P1OUT &= ~(LED1 + LED2);            /* turn LEDs off */
25
    P1IE |= BUTTON;                     /* P1.3 interrupt enabled */
26
    P1IFG &= ~BUTTON;                   /* P1.3 IFG cleared */
27
    /* P1REN |=  BUTTON;  (see #1) Enable the Pull Up? */
28
    __enable_interrupt();               /* enable all interrupts */
29
30
    while(1) {
31
      __delay_cycles(100000);
32
      P1OUT ^= LED1 ;
33
34
    /* endless loop */
35
36
37
// Port 1 interrupt service routine
38
#pragma vector=PORT1_VECTOR
39
__interrupt void Port_1(void)
40
41
    P1OUT ^= (LED1 + LED2);              /* LED toggle */
42
43
Hallo, ich habe das Problem, dass ich auf meinem LaunchPad nicht auf
Durck des Tasters reagieren kann.
Das Programm lässt die rote LED toggeln. Wenn der Interrupt auslöst
werden zudem die rote und die grüne LED getoggelt.
Am Ende der ISR hab ich außerdem einen Breakpoint gesetzt.
Komisches verhalten: Wenn ich die aus dem uC Pin ausgeführte
Steckerleiste P1.3 anpacke funktioniert es so wie gedacht. Wenn ich den
Taster drücke passiert nichts.
Ich besitze die Rev.1.5. In dieser Version wurde der externe Pull-Up
Widerstand vom Board entfernt. Deswegen habe ich den internen durch die
Zeile
P1REN |=  BUTTON;
aktiviert. Jedoch wirkt sich das noch negativer aus. Sodass die Sache
mit der Steckerleiste nicht einmal mehr funktioniert.
Hat jemand eine Idee?
OP
Martin schrieb:
> P1OUT |= BUTTON;
> P1DIR &= ~BUTTON;
P1OUT |= BUTTON;
Damit gebe ich aber doch Saft auf den Button. Nicht das was ich möchte.
P1DIR &= ~BUTTON;
P1.3 must stay as input (this is the default)! - Also es ist von anfang
an ein Eingang. P1DIR sieht zu Laufzeit so aus:
P0       P7
 100000010
Scheint mir korrekt.
Okay, mit Martins Änderung sieht mein Programm so aus:
#define LED1    BIT0
#define LED2    BIT6
#define BUTTON  BIT3
int main(void)
23
24
25
    P1OUT |= BUTTON;
26
    P1DIR &= ~BUTTON;
27
28
29
     P1REN |=  BUTTON;  /*(see #1) Enable the Pull Up? */
30
31
32
    while(1) {
33
34
      P1OUT ^= LED1 ;
35
36
    /* endless loop */
37
38
39
40
41
42
43
44
45
46
Und es läuft. Wenn ich Einen Pin als Eingang setze und dann aber Saft
draufgebe. Was tut dies dann? - Scheinbar aktiviere ich damit den
internen Pull-Up. Aber was für einen Sinn hat dann P1REN? Wähle ich
damit ob ich Pull-Up oder Pull-Down möchte?
//edit: Hab die Erklärung gefunden
PxREN
The resistor enable register is a very useful feature for the ports.
Sometimes it is helpful to pull the voltage up to Vcc or down to Vss,
such as when you attach a push button to a pin.  The resistor enable
register lets you turn on that ability.  When a PxREN bit is enabled,
you can select it as a pull-up or pull-down resistor by setting the
corresponding bit in PxOUT, 1 for up, 0 for down.
Im User Guide für die MSP430F5xx sind die Port-Funktionen besser
erklärt.
PxOUT, PxDIR und PxREN beeinflussen sich gegenseitig
PxDIR PxREN PxOUT    I/O Configuration
 0      0     x       Input
 0      1     0       Input with pulldown resistor
 0      1     1       Input with pullup resistor
 1      x     x       Output
Christian Q. schrieb:
> Aber warum kann man nicht auch AVR-like die Register manipulieren? ala
> P1DIR  |= (1 << LED1) | (1 << LED2);
> Ich fand das zu meinen atmega-Zeiten ganz übersichtlich.
Reine Frage der C-Library. Aber welchen großen Vorteil nun
gegenüber
P1DIR |= LED1 | LED2;
hat, ist mir auch nicht ganz  klar.
OP
Da konnte man schön die Datenrichtung eines Port definieren. Ob Eingang
oder Ausgang.
Wie sage ich in dieser Schreibweise, dass es ein Eingang ist?
Würd das so machen:
P1DIR &= ~BUTTON;
wäre bei der AVR lib schön:
P1DIR  |= (1 << LED1) | (1 << LED2) | (0 << BUTTON);
> Würd das so machen:
> P1DIR &= ~BUTTON;
Meist besser einfach mit
P1DIR = LED1 | LED2;
Nur da wo ein Ausgang sein soll wird das Bit gesetzt, alles andere
bleibt Eingang.
Nur wenn später im Programm ein Portpin von Ausgang zurück auf Eingang
umgeschaltet werden soll ist etwas wie
P1DIR &= ~BUTTON;
sinnvoll.
> wäre bei der AVR lib schön:P1DIR  |= (1 << LED1) | (1 << LED2) | (0 << BUTTON);
Das funktioniert bestimmt nicht. Eine '1' im P1DIR an Bitpos BUTTON kann
man nicht per ODER löschen.
Diesen Shift-Sch... findet man nur beim AVR. Richtige Compiler-Libs
erlauben vernünftiges Programmieren.
