1 | #ifndef _OpencoreUart_HEADER_FILE_
2 | #define _OpencoreUart_HEADER_FILE_
3 |
4 | #include <stddef.h>
5 | #include "DDStructs.h"
6 |
7 | /***********************************************************************
8 | * *
9 | * UART PHYSICAL DEVICE SPECIFIC INFORMATION *
10 | * *
11 | ***********************************************************************/
12 |
13 | /* REGISTER OFFSETS FROM BASE ADDRESS */
14 | #define OPENCOREUART_RXTX 0x00 //Receiver Buffer and Transmitter Holding Register (THR)
15 | #define OPENCOREUART_IER 0x01 //Interrupt Enable Register
16 | #define OPENCOREUART_IIR 0x02 //Interrupt Identification and FIFO Control Register
17 | #define OPENCOREUART_LCR 0x03 //Line control Register
18 | #define OPENCOREUART_MCR 0x04 //Modem control Register
19 | #define OPENCOREUART_LSR 0x05 //Line status Register
20 | #define OPENCOREUART_MSR 0x06 //Modem status Register
21 |
22 | /*
23 | The registers can be accessed when the 7th (DLAB) bit of the Line Control Register is set to ‘1’. At
24 | this time the above registers at addresses 0-1 can’t be accessed.
25 | */
26 | #define OPENCOREUART_DIVL 0x00 //Divisor Latch Byte 1 (LSB)
27 | #define OPENCOREUART_DIVH 0x01 //Divisor Latch Byte 1 (MSB)
28 |
29 |
30 |
31 | #ifdef __cplusplus
32 | extern "C"{
33 | #endif /* __cplusplus */
34 |
35 | /* device initialization function */
36 | void init_Opencoreuart( OpencoreuartCtx_t * ctx );
37 |
38 |
39 | /*
40 | * GPIO REGISTER MAPPING
41 | */
42 | typedef struct st_Opencoreuart_t{
43 |
44 | /* Receiver oder Transmit FIFO oder Divisor Latch Byte 1 (LSB) */ //REG-0//
45 | volatile unsigned char rxtx;
46 |
47 | /* Interrupt Enable Register oder Divisor Latch Byte 1 (MSB) */ //REG-1//
48 | volatile unsigned char ier;
49 |
50 | /* Interrupt Identification oder FIFO Control*/ //REG-2//
51 | volatile unsigned char iir;
52 |
53 | /* Line Control Register */ //REG-3//
54 | volatile unsigned char lcr;
55 |
56 | /* Modem Control Register */ //REG-4//
57 | volatile unsigned char mcr;
58 |
59 | /* Line Status Register */ //REG-5//
60 | volatile unsigned char lsr;
61 |
62 | /* Modem Status Register*/ //REG-6//
63 | volatile unsigned char msr;
64 |
65 | }Opencoreuart_t;
66 |
67 |
68 | /***********************************************************************
69 | * *
70 | * USER MACROS FOR READ/WRITE OPENCOREUART REGISTERS *
71 | * *
72 | ***********************************************************************/
73 |
74 | #define OPENCOREUART_WR_LCR(X,Y) ((volatile Opencoreuart_t *)((X)->base))->lcr=(Y)
75 | //#define MICO_GPIO_WRITE_DATA(X,Y) ((volatile MicoGPIO_t *)((X)->base))->data=(Y)
76 |
77 |
78 | #ifdef __cplusplus
79 | }
80 | #endif /* __cplusplus */
81 | #endif//_OpencoreUart_HEADER_FILE_
