Hallo Forum,
ich habe heute morgen versucht mein Programm zu ordnen.
Ich habe mir einen Artikel über Header durchgelesen und dann die beiden
Dateien fabriziert. Leider kommen immer die Fehlermeldungen:
Error 1 'UBRR0H' undeclared (first use in this function) C:\Users\Timm\Documents\AVRStudio\test uart\test uart\uart_timmy.c 7 3 test uart
Error 2 each undeclared identifier is reported only once for each function it appears in C:\Users\Timm\Documents\AVRStudio\test uart\test uart\uart_timmy.c 7 3 test uart
Error 3 'F_CPU' undeclared (first use in this function) C:\Users\Timm\Documents\AVRStudio\test uart\test uart\uart_timmy.c 7 13 test uart
Error 4 'BAUD' undeclared (first use in this function) C:\Users\Timm\Documents\AVRStudio\test uart\test uart\uart_timmy.c 7 13 test uart
Error 5 'UBRR0L' undeclared (first use in this function) C:\Users\Timm\Documents\AVRStudio\test uart\test uart\uart_timmy.c 8 3 test uart
Error 6 'UCSR0B' undeclared (first use in this function) C:\Users\Timm\Documents\AVRStudio\test uart\test uart\uart_timmy.c 9 3 test uart
Error 7 'TXEN0' undeclared (first use in this function) C:\Users\Timm\Documents\AVRStudio\test uart\test uart\uart_timmy.c 9 17 test uart
Error 8 'RXEN0' undeclared (first use in this function) C:\Users\Timm\Documents\AVRStudio\test uart\test uart\uart_timmy.c 9 30 test uart
Error 9 'UCSR0C' undeclared (first use in this function) C:\Users\Timm\Documents\AVRStudio\test uart\test uart\uart_timmy.c 11 3 test uart
Error 10 'UCSZ01' undeclared (first use in this function) C:\Users\Timm\Documents\AVRStudio\test uart\test uart\uart_timmy.c 11 16 test uart
Error 11 'UCSZ00' undeclared (first use in this function) C:\Users\Timm\Documents\AVRStudio\test uart\test uart\uart_timmy.c 11 28 test uart
Error 12 'UCSR0A' undeclared (first use in this function) C:\Users\Timm\Documents\AVRStudio\test uart\test uart\uart_timmy.c 17 14 test uart
Error 13 'UDRE0' undeclared (first use in this function) C:\Users\Timm\Documents\AVRStudio\test uart\test uart\uart_timmy.c 17 27 test uart
Error 14 'UDR0' undeclared (first use in this function) C:\Users\Timm\Documents\AVRStudio\test uart\test uart\uart_timmy.c 21 5 test uart
Error 15 'UCSR0A' undeclared (first use in this function) C:\Users\Timm\Documents\AVRStudio\test uart\test uart\uart_timmy.c 38 14 test uart
Error 16 'RXC0' undeclared (first use in this function) C:\Users\Timm\Documents\AVRStudio\test uart\test uart\uart_timmy.c 38 27 test uart
Error 17 'UDR0' undeclared (first use in this function) C:\Users\Timm\Documents\AVRStudio\test uart\test uart\uart_timmy.c 40 12 test uart
Warning 18 control reaches end of non-void function C:\Users\Timm\Documents\AVRStudio\test uart\test uart\uart_timmy.c 41 1 test uart
Leider finde ich den Fehler nicht. Falls einer gerade Zeit hat, könnte
er sich das ja mal ansehen.
Vielen Dank im voraus!!
Datein:
* uart_timmy.h
* Created: 10.12.2012 12:03:14
* Author: Timm
#ifndef UART_TIMMY_H_
#define UBRR_VAL ((F_CPU+BAUD*8)/(BAUD*16)-1)
#define BAUD_REAL (F_CPU/(16*(UBRR_VAL+1)))
#define BAUD_ERROR ((BAUD_REAL*1000)/BAUD)
#define UART_TIMMY_H_
externvoiduart_init(void);
externintuart_putc(unsignedcharc);
externvoiduart_puts(char*s);
externcharuart_getc(void);
externvoiduart_gets(char*Buffer,uint8_tMaxLen);
#endif /* UART_TIMMY_H_ */
#include<avr/io.h>
#include"uart_timmy.h"
voiduart_init(void)
UBRR0H=(UBRR_VAL>>8);
UBRR0L=UBRR_VAL;
UCSR0B|=(1<<TXEN0)|(1<<RXEN0);// | (1<<RXCIE0);
// Frame Format: Asynchron 8N1
UCSR0C=(1<<UCSZ01)|(1<<UCSZ00);
while(!(UCSR0A&(1<<UDRE0)))/* warten bis Senden moeglich */
UDR0=c;/* sende Zeichen */
return0;
23
24
25
26
/* puts ist unabhaengig vom Controllertyp */
27
28
29
while(*s)
30
{/* so lange *s != '\0' also ungleich dem "String-Endezeichen" */
31
uart_putc(*s);
32
s++;
33
34
35
36
charuart_getc(void)
37
38
while(!(UCSR0A&(1<<RXC0)))// warten bis Zeichen verfuegbar
39
40
returnUDR0;// Zeichen aus UDR an Aufrufer zurueckgeben
41
42
43
44
45
uint8_tNextChar;
46
uint8_tStringLen=0;
47
48
NextChar=uart_getc();// Warte auf und empfange das nächste Zeichen
49
50
// Sammle solange Zeichen, bis:
51
// * entweder das String Ende Zeichen kam
52
// * oder das aufnehmende Array voll ist
53
while(NextChar!='\n'&&StringLen<MaxLen-1){
54
*Buffer++=NextChar;
55
StringLen++;
56
57
58
59
// Noch ein '\0' anhängen um einen Standard
60
// C-String daraus zu machen
61
*Buffer='\0';
62
63
64
// Passende Größe des Arrays wählen!
65
// char Line[40]; // String mit maximal 39 zeichen
Der Header ist doch die erste datei ;)
Ich arbeite mit AVR Studio 5.0 .
Habe die Dateien in dem selben Projekt drin wie auch die eigentliche C
Datei.
Wenn ich den selben Code in der C Datei lasse, funktioniert es. Wenn ich
ihn aber so auslagere wie beschreiben, kommt es zu den Fehlern.
Okay sind fast alle Fehlermeldungen weg. Danke!!!
Die einzigen beiden die noch sind:
Error 1 'F_CPU' undeclared (first use in this function) C:\Users\Timm\Documents\AVRStudio\test uart\test uart\uart_timmy.c 7 11 test uart
Error 2 each undeclared identifier is reported only once for each function it appears in C:\Users\Timm\Documents\AVRStudio\test uart\test uart\uart_timmy.c 7 11 test uart
Error 3 'BAUD' undeclared (first use in this function) C:\Users\Timm\Documents\AVRStudio\test uart\test uart\uart_timmy.c 7 11 test uart
Dabei hab ich doch in der Datei das stehen:
* test_uart.c
* Created: 07.12.2012 15:28:36
* Author: Timm
#define F_CPU 16000000UL
#define BAUD 9600
#include<avr/io.h>
#include<util/delay.h>
intmain(void)
uart_init();
uart_putc(0xC);
uart_puts("UART inistalisiert!\r\n");
DDRD=0b1111111;
while(1)
23
24
uart_puts("So ein Scheiss, dass es an einer null lag!\r\n");
Sören Timm schrieb:> Dabei hab ich doch in der Datei das stehen:
Die, in der main() steht, interessiert nicht.
Deine Fehlermeldungen beziehen sich auf uart_timmy.c
> Korrigiert:>
So und jetzt gehst du diese Datei, und zwar nur diese C-Datei von oben
nach unten durch und stellst dir die Frage.
Wo kommt da F_CPU her?
Wo kommt da BAUD her?
Wie gesagt: Was in main.c steht, interessiert nicht. Das hier ist die
uart_timmy.c. Und uart_timmy.c wird für sich alleine kompiliert. Wenn
sich der Compiler uart_timmy.c vornimmt, hat er alles vergessen, was er
je aus main.c erfahren hat.
In C ist eine C-Datei eine abgeschlossene Einheit. Sie wird für sich
selbst und ohne Ansehen anderer C-Dateien compiliert. Was du daher in
anderen C-Dateie stehen hast, mag zwar für die dortige C-Datei super
sein, ist aber für diese hier uninteressant.
In welcher Datei steht das und für welche Datei wird der Fehler
ausgegeben? Genau hinsehen.
Diese Definition gehört aus diesem Grund nicht in eine Quelltextdatei,
sondern als Compileroption ins Makefile.
Sören Timm schrieb:> #define F_CPU 16000000UL> #define BAUD 9600
hast du das auch in deiner zweiten C Datei?d
Wenn nein dann ist das der Fehler,
wenn ja ist es Käse weil es sinnvollerweise nur an einer Stelle
definiert wir
So es funktioniert!
Senden und empfangen!
Nur wie bekomme ich es jetzt hin, das die Baudrate und die Frequenz nur
in der test_uart.c angegeben werden muss?
Das es sinnvoll ist ist mir klar.
Bei delay.h geht es ja auch irgendwie...
Sören Timm schrieb:> Nur wie bekomme ich es jetzt hin, das die Baudrate und die Frequenz nur> in der test_uart.c angegeben werden muss?
indem du sie im makefile definierst,
wenn du keinen hast dann in irgendwelchen Options
Und wenn du noch mal scharf darüber nachdenkst, dann kommst du zu dem
Schluss: gar nicht!
> Das es sinnvoll ist ist mir klar.> Bei delay.h geht es ja auch irgendwie...
Nö.
Auch bei delay.h geht es nicht. Jede C-Datei, die delay.h inkludiert,
muss für sich selbst wieder dafür sorgen, dass sie irgendwo eine
Definition für F_CPU herkriegt.
Bei F_CPU ist es sinnvoll, die in die Projektoptionen mit aufzunehmen.
Denn diese Einstellungen werden dem Compiler bei jegem COmpiliervorgang
immer mitgegeben.
Es spricht aber auch nichts dagegen, dass man sich ein Header-File
macht, in dem alle diese Konfigurationssachen gesammelt werden UND man
die Forderung erhebt, dass jedes C-File genau dieses Header File
inkludieren MUSS.
Eine eigene Frage?
Dieser Thread ist über 13 Jahre alt.
