Matlab error Undefined function or method 'du' for input arguments of type
OP #3070248
I have written that equations but I got an error at the end...
A=0.05;
rho=1.225;
t=0.001;
v=5;
Cu(1)=1.3;
Cl(1)=0.34;
u(1)=0;
a(1)=0;
i=2:1000;
u(i)=u(1)+du(i);
da(i)=ds(i)*360/0.628;
ds(i)=du(i)*t;
a(i)=da(i)+a(i-1);
du(i)=F(i-1)*0.001/0.05;
F(i-1)=(F1(i-1)-F2(i-1))*cos(a(i-1));
F1(i-1)=0.5*1.225*Cu(i-1)*A(i-1)*(v-u(i-1))^2;
F2(i-1)=0.5*1.225*Cl(i-1)*A(i-1)*(v+u(i-1))^2;
A(i-1)=A*cos(a(i-1));
Cu=-0.0053*a(i-1)+1.3;
Cl(1)=0.0053*(180+a(i-1));
??? Undefined function or method 'du' for input arguments of type
'double'.
Error in ==> Scientific at 10
u(i)=u(1)+du(i);
thanks a lot...
OP
A(1)=0.05;
rho=1.225;
t=0.01;
v=5;
u(1)=0;
a(1)=0;
C(1)=1.3;
for i=2:1000
C(i-1)=0.82+0.48*cos(a(i-1));
A(i-1)=A(1)*cos(a(i-1));
F1(i-1)=0.5*1.225*C(i-1)*A(i-1)*(v-u(i-1))^2;
F2(i-1)=0.5*1.225*C(i-1)*A(i-1)*(v+u(i-1))^2;
u(i)=u(1)+du(i);
ds(i)=du(i)*t;
da(i)=ds(i)*2*pi/0.628;
a(i)=da(i)+a(i-1);
end
i corrected the codes in that way...C(1)=1.3; does not make sense but I
left it...
the first line and the last one
a(i)=da(i)+a(i-1);            depend on eachther. that is why i wrote if
end loop. I dont get any fault but my problem is that I got the constant
values for all variables in my Workspace.
thanks a lot
OP
for each variable I got this error
The variable 'F2' appears to change size on every loop iteration (within
a script). Consider preallocating for speed
Explanation
The size of the indicated variable or array appears to be changing with
each loop iteration. Commonly, this message appears because an array is
growing by assignment or concatenation. Growing an array by assignment
or concatenation can be expensive. For large arrays, MATLAB must
allocate a new block of memory and copy the older array contents to the
new array as it makes each assignment.
Programs that change the size of a variable in this way can spend most
of their run time in this inefficient activity. There is also
significant overhead in shrinking an array on each iteration or in
changing the size of a variable on each iteration. In such cases, MATLAB
must reallocate and copy the contents repeatedly.
For scripts, M-Lint cannot determine whether the array was preallocated
before the script was called. Depending on your use of scripts, you
might want to enable or disable this message independently of the
related message (with message ID AGROW) that applies to functions and
class methods.
 Suggested Action
Consider preallocating a variable or array before entering the loop by
using zeros, ones, cell, or a similar function. Preallocating avoids the
need for MATLAB to copy the data from one array to another inside the
loop. For examples of code that do and do not preallocate an array, see
“Preallocating Arrays”
When an array grows by assigning past the end of the array or using
concatenation, preallocation alone does not improve the performance. The
code must use explicit indices also.
Assigning to an array in a script that the caller of the script
preallocated provides an opportunity to create bugs that are difficult
to detect. If the script is called multiple times, these bugs are
particularly difficult to detect. However, there are other uses of
scripts where preallocating in this manner is necessary or even
desirable. In this case, suppress the message for specific assignments
or for the whole script, as described in “Suppressing M-Lint Indicators
and Messages”. It might also be appropriate to suppress this message if
any of the following is true:
The loop code is searching for rare or exceptional events (especially if
you do not expect it to find any).
In this case, it can be reasonable to grow the array only as the loop
code finds such events.
The array is small and will always be small.
In this case, the impact of recopying is also small.
The array was preallocated, but in a way that M-Lint does not recognize.
If you do not know the size of an array before the loop begins,
preallocate it, and then shrink it, if necessary, after the loop
completes.
This is not an error message, but a suggestion for speed increase.
And, did you read this help item?
OP
Yes I read.
I looked at this links
http://www.mathworks.de/support/solutions/en/data/1-18150/
http://www.mathworks.de/de/help/matlab/matlab_prog/techniques-for-improving-performance.html
I tried to apply it also for my file like that:
C=zeros(1000);
A=zeros(1000);
F1=zeros(1000);
F2=zeros(1000);
F=zeros(1000);
du=zeros(1000);
u=zeros(1000);
ds=zeros(1000);
da=zeros(1000);
a=zeros(1000);
However, I see now only matrixes and the first column is for C for
example only 1.3 and the other all columns are zero. It didnt solve my
problem I see again constant values but I have know matrix with zeros...
I couldnt solve yet.
bora bora schrieb:
> C=zeros(1000);
> A=zeros(1000);
> F1=zeros(1000);
> F2=zeros(1000);
> F=zeros(1000);
> du=zeros(1000);
> u=zeros(1000);
> ds=zeros(1000);
> da=zeros(1000);
> a=zeros(1000);
Every Matlab command has its own help item. Its on you to use this help.
From the help text of the "zeros" command:
http://www.mathworks.com/help/matlab/ref/zeros.html:
> B = zeros(n) returns an n-by-n matrix of zeros. An error
> message appears if n is not a scalar.
> B = zeros(m,n) or B = zeros([m n]) returns an m-by-n matrix
> of zeros.
What do you think will "C=zeros(1000)" do?
