LPC18xx ARM Cortex M3 CMSIS Problem bei Funktionsaufruf von SSP_Init
Gast #3179319
ich benötige Hilfe bei C-Programmierung. Ich möchte den SSP-Treiber aus
der CMSIS-Bibliothek verwenden. Jetzt kriege ich es aber nicht hin die
Funktion SSP_Init aufzurufen.
Kann mir bitte jemand bei dem richtigen Aufruf helfen?
Hier ist die SSP_Init:
void SSP_Init(LPC_SSPn_Type *SSPx, SSP_CFG_Type *SSP_ConfigStruct)
  uint32_t tmp;
  uint32_t prescale, cr0_div, cmp_clk, ssp_clk;
  CHECK_PARAM(PARAM_SSPx(SSPx));
  if(SSPx == LPC_SSP0) {
    /* Set up clock and power for SSP0 module */
    //LPC_CGU->BASE_SSP0_CLK = (SRC_PL160M_0<<24) | (1<<11);
    CGU_EntityConnect(CGU_CLKSRC_PLL1, CGU_BASE_SSP0);
  } else if(SSPx == LPC_SSP1) {
    /* Set up clock and power for SSP1 module */
    //LPC_CGU->BASE_SSP1_CLK = (SRC_PL160M_0<<24) | (1<<11);
    CGU_EntityConnect(CGU_CLKSRC_PLL1, CGU_BASE_SSP1);
  } else {
    return;
  /* Configure SSP, interrupt is disable, LoopBack mode is disable,
   * SSP is disable, Slave output is disable as default
  tmp = ((SSP_ConfigStruct->CPHA) | (SSP_ConfigStruct->CPOL) \
24
    | (SSP_ConfigStruct->FrameFormat) \
25
                | (SSP_ConfigStruct->Databit))    \
26
    & SSP_CR0_BITMASK;
27
  // write back to SSP control register
28
  SSPx->CR0 = tmp;
29
30
  tmp = SSP_ConfigStruct->Mode & SSP_CR1_BITMASK;
31
  // Write back to CR1
32
  SSPx->CR1 = tmp;
33
34
  // Set clock rate for SSP peripheral
35
36
    ssp_clk = CGU_GetPCLKFrequency(CGU_PERIPHERAL_SSP0);
37
  else
38
    ssp_clk = CGU_GetPCLKFrequency(CGU_PERIPHERAL_SSP1);
39
  cr0_div = 0;
40
  cmp_clk = 0xFFFFFFFF;
41
  prescale = 2;
42
  while (cmp_clk > SSP_ConfigStruct->ClockRate)
43
44
    cmp_clk = ssp_clk / ((cr0_div + 1) * prescale);
45
    if (cmp_clk > SSP_ConfigStruct->ClockRate)
46
47
      cr0_div++;
48
      if (cr0_div > 0xFF)
49
50
        cr0_div = 0;
51
        prescale += 2;
52
53
54
55
56
    /* Write computed prescaler and divider back to register */
57
    SSPx->CR0 &= (~SSP_CR0_SCR(0xFF)) & SSP_CR0_BITMASK;
58
    SSPx->CR0 |= (SSP_CR0_SCR(cr0_div)) & SSP_CR0_BITMASK;
59
    SSPx->CPSR = prescale & SSP_CPSR_BITMASK;
60
In der Header-Datei lpc18xx_ssp.h ist die Struktur wie folgt
programmiert:
typedef struct {
  uint32_t Databit;
    uint32_t CPHA;
  uint32_t CPOL;
  uint32_t Mode;
  uint32_t FrameFormat;
  uint32_t ClockRate;
} SSP_CFG_Type;
Ich habe die Funktion nun wie folgt aufgerufen:
SSP_Init(LPC_SSP0,SSP_CFG);
Ich bekomme immer noch einen Fehler angezeigt (LPCXpresso IDE). Also
stimmt mein Funktionsaufruf nicht.
Vielen Dank!
Gruß Martin
