TLS Verbindungstest
Gast #3257142
ich habe mal die TLS Verbindung meines Providers mit
http://www.checktls.com/index.html getestet, habe aber Probleme das
Kauderwelsch richtig zu verstehen.
Below are the details from your CheckTLS TestSender test
from <testmehl@online.de> via [212.227.126.187]
run on 2013-07-25 10:51:11 EDT.
Original email Subject: cxch2u2gywdkd
Your email was successfully sent securely using TLS.
A transcript of the eMail SMTP session is below:
--> this would be a line from your email system to our test
<-- and this would be a line to your email system from our test
If TLS was negotiated, a line is added:
====tls negotiation successful (cypher: cyphername, client cert: certinfo)
Everything after that line is secure (encrypted), as indicated by:
~~> commands from your system then have wiggly lines
<~~ and responses from our system do too
Any errors that the test noticed are noted in the log by asterisk boxes:
*** ********** Error Note ********* ***
*** The error message would be here ***
24
25
26
27
___TRANSCRIPT BEGINS ON THE NEXT LINE___
28
<-- 220 ts3.checktls.com CheckTLS TestSender Thu, 25 Jul 2013 10:51:09 -0400
29
--> EHLO moutng.kundenserver.de
30
<-- 250-ts3.checktls.com Hello moutng.kundenserver.de [212.227.126.187], pleased to meet you
31
<-- 250-ENHANCEDSTATUSCODES
32
<-- 250-8BITMIME
33
<-- 250-STARTTLS
34
<-- 250 HELP
35
--> STARTTLS
36
<-- 220 Ready to start TLS
37
====tls negotiation successful (cypher: RC4-SHA, client cert: Subject Name: undefined;Issuer  Name: undefined;)
38
~~> EHLO moutng.kundenserver.de
39
<~~ 250-ts3.checktls.com Hello moutng.kundenserver.de [212.227.126.187], pleased to meet you
40
<~~ 250-ENHANCEDSTATUSCODES
41
<~~ 250-8BITMIME
42
<~~ 250 HELP
43
~~> MAIL FROM:<testmehl@online.de>
44
<~~ 250 Ok - mail from testmehl@online.de
45
~~> RCPT TO:<test@TestSender.CheckTLS.com>
46
<~~ 250 Ok - recipient test@TestSender.CheckTLS.com
47
~~> DATA
48
<~~ 354 Send data.  End with CRLF.CRLF
49
~~> Received: from [192.168.178.23] (port-92-206-5-181.dynamic.qsc.de [92.206.5.181])
50
~~>   by mrelayeu.kundenserver.de (node=mreu2) with ESMTP (Nemesis)
51
~~>   id 0M3fOP-1UBVBE1mjZ-00r0b2; Thu, 25 Jul 2013 16:51:09 +0200
52
~~> Message-ID: <51F13B56.8030407@online.de>
53
~~> Date: Thu, 25 Jul 2013 16:51:02 +0200
54
~~> From: XXXXXX XXX <testmehl@online.de>
55
~~> User-Agent: Mozilla/5.0 (Windows NT 5.1; rv:17.0) Gecko/20130620 Thunderbird/17.0.7
56
~~> MIME-Version: 1.0
57
~~> To: test@TestSender.CheckTLS.com
58
~~> Subject: cxch2u2gywdkd
59
~~> X-Enigmail-Version: 1.5.2
60
~~> Content-Type: text/plain; charset=ISO-2022-JP
61
~~> Content-Transfer-Encoding: 7bit
62
~~> X-Provags-ID: V02:K0:RLXCQAV0+mb50Gm4rIA94Q26MX6KSh5Kt5MsfJGKuIG
63
~~>  6AZ8AXYZAJ/GokK+LU3fNMzb8SjMezM3fOnVOSVHXR4dHsDPkx
64
~~>  2Wlc33C6QatIKYL/1BFBMYFrLtnZS9G+enpy4J7ZwmsqrVf1k5
65
~~>  wvGQCY2q/Q5sB371o1XBRW8rEINqkBkDxhJbjV3na4VZFkXaLq
66
~~>  FQEjq5wt/+E9NEoXgcUPRu+Ea1/0QFWR8QjrCBCqX6pTUjOfiO
67
~~>  HaEQC+P8J3ah3pYoN1FB9UC7x739nQerpcrCjPBi2h6SKT0zRk
68
~~>  io9ohXCsBAsNhUuW27n/+Cfd1L4HRgKKE6+NRZZyFd1gi18F/Z
69
~~>  n6I3faMjyv8doJ34MEsc=
70
71
~~> Thank you for using CheckTLS.com!
72
73
<~~ 250 Ok
74
~~> QUIT
75
<~~ 221 ts3.checktls.com closing connection
Es geht um die Zeile "====tls negotiation successful (cypher: RC4-SHA,
client cert: Subject Name: undefined;Issuer  Name: undefined;)"
Wenn ich das richtig verstehe gab es keine Zertifikation und somit wäre
die Verbindung durch Man-in-the-middle angeifbar. Oder sehe ich da was
falsch?
Grüße
Die zwei Felder des Zertifikates sind einfach nicht ausgefüllt oder
werden nicht erkannt. Eigentlich sollte da u.a. der Hostname und
Herausgeber zu finden sein. Mein Mailserver enthält ein dreistufiges
Zertifikat und wird korrekt beim Test angezeigt. Nur am Hostname stört
sich der Test, ist aber die gleiche Kiste.
Das heißt, 1&1 versendet zwar unter Verwendung von TLS, identifiziert
sich aber nicht mit Client-Zertifikat. Dürfte üblich sein,
verschlechtert die ohnehin nicht vorhandene Absenderverifizierung auch
nicht. Der empfangende Server weiß halt dann nicht, ob da wer dazwischen
sitzt.
Andererseits: je nach dem, wen du als MITM ausschließen
willst...manchmal haben die ja auch gültig erscheinende Zertifikate...
RC4-SHA ist natürlich auch nicht das Gelbe vom Ei. Mein lokaler
Eingangsserver handlet beim Receiver Test von checktls.com
DHE-RSA-AES256-SHA aus. Der Ausgangsserver meines Providers dagegen
sendet komplett ohne TLS.
Es ist noch ein weiter Weg^^
darf man fragen welchen Provider du hast?
Wir sollten hier eine Liste der Provider mit ihren Verschlüsselungen
machen.
1. 1&1 : TLS-->Ja      Zertifikat-->Nein
Grüße
Persönliche Seite
Malte S. schrieb:
> 2. Versatel : TLS-->Nein ---
3. domain*go TLS (AES256-SHA), Client-Zertifikat Nein
Ein Clientzertifikat macht in diesem Szenario auch nicht so wahnsinnig
viel Sinn, es sei denn man möchte nur von bestimmten vertrauten Servern
Mails empfangen/senden, da idr man aber eher von vielen unbekannten
Servern Mails ausgetauscht wird würde das den Mailaustausch schon arg
behindern. Da der Mailserver eh nur "Transportknecht" ist, wäre PGP hier
zielführender, dann könnte man nur von vertrauten Absendern Mails
annehmen, über welche Server die ging wäre dann unerheblich.
