Zombieprozesse?
Gast #3456715
Habe folgenden Auszug von ps aux. Wie interpretierst du das Ergebnis?
Sind sinnlose Einträge darunter?
USER    PID   %CPU   %MEM      VSZ     RSS   TTY  STAT   START     TIME   COMMAND
1000  29020    0.0    0.0     6156    1324   ?  SN   18:33     0:00   sw-cp-server: worker process
108    279    0.0    0.0     3480    1244   ?  Ss   Dec18     0:00   dbus-daemon --system --fork --activation=upstart
avahi    402    0.0    0.0     3680    1356   ?  S   Dec18     0:00   avahi-daemon: running [ff.local]
avahi    405    0.0    0.0     3408     452   ?  S   Dec18     0:00   avahi-daemon: chroot helper
bind  24973    0.0    0.4    58916   10240   ?  SNsl   18:31     0:00   /usr/sbin/named -t /var/named/run-root -c /etc/named.conf -u bind -n 2
clamav   7298    0.1    0.0    14092    1876   ?  Ss   Dec22     2:25   /usr/bin/freshclam -d --quiet
mysql   9976    0.1    2.0   220352   42740   ?  Ssl   17:58     0:07   /usr/sbin/mysqld
nutzer  30093    0.0    0.2     7256    4240   ?  SLs   18:57     0:00   proftpd: nutzer - 123.123.123.123: IDLE
postfix  28818    0.0    0.0     4696    1540   ?  SN   18:32     0:00   qmgr -l -t fifo -u
postfix  28911    0.0    0.0    66568    1700   ?  SNsl   08:04     0:01   /usr/lib/plesk-9.0/psa-pc-remote -p inet:12768@localhost
postfix  30383    0.0    0.0     4552    1412   ?  SN   19:07     0:00   pickup -l -t fifo -u -c
postfix  30465    0.0    0.1     7140    2728   ?  SN   19:12     0:00   tlsmgr -l -t unix -u -c
root      1    0.0    0.0     3472    1800   ?  Ss   Dec18     0:00   init
root      2    0.0    0.0        0       0   ?  S   Dec18     0:00   [kthreadd/207836]
root      3    0.0    0.0        0       0   ?  S   Dec18     0:00   [khelper/2078364]
root      4    0.0    0.0        0       0   ?  S   Dec18     0:00   [rpciod/2078364/]
root      5    0.0    0.0        0       0   ?  S   Dec18     0:00   [rpciod/2078364/]
root      6    0.0    0.0        0       0   ?  S   Dec18     0:00   [rpciod/2078364/]
root      7    0.0    0.0        0       0   ?  S   Dec18     0:00   [rpciod/2078364/]
root      8    0.0    0.0        0       0   ?  S   Dec18     0:00   [rpciod/2078364/]
root      9    0.0    0.0        0       0   ?  S   Dec18     0:00   [rpciod/2078364/]
23
root     10    0.0    0.0        0       0   ?  S   Dec18     0:00   [rpciod/2078364/]
24
root     11    0.0    0.0        0       0   ?  S   Dec18     0:00   [rpciod/2078364/]
25
root     12    0.0    0.0        0       0   ?  S   Dec18     0:00   [nfsiod/2078364]
26
root    150    0.0    0.0     2788     592   ?  S   Dec18     0:00   upstart-udev-bridge --daemon
27
root    210    0.0    0.0     3188    1312   ?  Ss   Dec18     0:00   /sbin/udevd --daemon
28
root    379    0.0    0.1    10996    2840   ?  Ss   Dec18     0:00   /usr/sbin/cupsd -F
29
root    913    0.0    0.0     2800     484   ?  S   Dec18     0:00   upstart-socket-bridge --daemon
30
root   1254    0.0    0.1     6636    2180   ?  Ss   Dec18     0:00   /usr/sbin/sshd -D
31
root   1284    0.0    0.0     7096    1524   ?  Ss   Dec18     0:00   /usr/sbin/modem-manager
32
root   1581    0.0    0.0     2572     872   ?  Ss   Dec18     0:01   cron
33
root   1588    0.0    0.0     2128     616   ?  Ss   Dec18     0:00   acpid -c /etc/acpi/events -s /var/run/acpid.socket
34
root   1708    0.0    0.1    26436    2192   ?  Ssl   Dec18     0:09   NetworkManager
35
root   1763    0.0    0.0    28608    1716   ?  Sl   Dec18     0:07   /usr/lib/policykit-1/polkitd --no-debug
36
root  26607    0.0    0.0     2516     988   ?  Ss   18:31     0:00   /usr/sbin/xinetd -dontfork -pidfile /var/run/xinetd.pid -stayalive
37
root  28816    0.0    0.0     4532    1424   ?  SNs   18:32     0:00   /usr/lib/postfix/master
38
root  28831    0.0    0.0     2104     348   ?  SN   18:32     0:00   /usr/sbin/courierlogger -name=imapd -pid=/var/run/imapd.pid -start -name=courier-imapd /usr/lib/couriertcpd -add
39
root  28832    0.0    0.0     3844     748   ?  SN   18:32     0:00   /usr/lib/couriertcpd -address=0 -maxprocs=40 -maxperip=4 -nodnslookup -noidentlookup 143 /usr/sbin/imaplogin /us
40
root  28845    0.0    0.0     2104     344   ?  SN   18:32     0:00   /usr/sbin/courierlogger -name=imapd-ssl -pid=/var/run/imapd-ssl.pid -start -name=courier-imaps /usr/lib/couriert
41
root  28846    0.0    0.0     3844     748   ?  SN   18:32     0:00   /usr/lib/couriertcpd -address=0 -maxprocs=40 -maxperip=4 -nodnslookup -noidentlookup 993 /usr/bin/couriertls -se
42
root  28858    0.0    0.0     2104     348   ?  SN   18:32     0:00   /usr/sbin/courierlogger -name=pop3d -pid=/var/run/pop3d.pid -start -name=courier-pop3d /usr/lib/couriertcpd -add
43
root  28859    0.0    0.0     3844     744   ?  SN   18:32     0:00   /usr/lib/couriertcpd -address=0 -maxprocs=40 -maxperip=4 -nodnslookup -noidentlookup 110 /usr/sbin/pop3login /us
44
root  28872    0.0    0.0     2104     348   ?  SN   18:32     0:00   /usr/sbin/courierlogger -name=pop3d-ssl -pid=/var/run/pop3d-ssl.pid -start -name=courier-pop3s /usr/lib/couriert
45
root  28873    0.0    0.0     3844     748   ?  SN   18:32     0:00   /usr/lib/couriertcpd -address=0 -maxprocs=40 -maxperip=4 -nodnslookup -noidentlookup 995 /usr/bin/couriertls -se
46
root  29018    0.0    0.0     5956     932   ?  SNs   18:33     0:00   sw-cp-server: master process /usr/sbin/sw-cp-serverd
47
root  29219    0.0    0.5    70236   10556   ?  SNs   18:33     0:00   sw-engine-fpm: master process (/etc/sw-engine/sw-engine-fpm.conf)
48
root  30192    0.0    0.1    10260    3288   ?  Ss   19:00     0:00   sshd: root@pts/3
49
root  30291    0.0    0.2     9380    4408   pts/3  Ss   19:00     0:00   -bash
50
root  30761    0.0    0.0     6112    1128   pts/3  R+   19:29     0:00   ps aux
51
syslog   1641    0.0    0.0     2356     728   ?  Ss   Dec18     0:08   /sbin/syslogd -u syslog
52
whoopsie   1600    0.0    0.1    26440    2640   ?  Ssl   Dec18     0:00   whoopsie
Gast #3456746
Meiner ist im Leerlauf viermal so lang.
Fast alle Prozesse pennen. Leerlauf also.
Zumindest keine, die auf den ersten Blick kaputt sind.
Klassische Zombies haben i.d.R. ein 'Z' im Status stehen, bis sie
augeräumt werden.
#3456811
>Zombieprozesse?
Definiere mal "Zombie". Ich sehe nämlich keinen (zumindest nicht
offensichtlich, da Du ja "ps aux" geliefert hast)
Gast #3456855
> Du betreibst also einen Server in Beijing?!
Hier gibt es noch einen anderen thread, da hat einer angst das sein
server gehackt wurde... und der betroffene will gnau diese IP sperren...
Interessanter Zufall... :D
#3456949
Sieht alles normal aus. Keine übermässigen Z (hin und wieder kann es
schon ein paar geben, die verschwinden im Normalfall aber von selbst),
keine auffällig hohen CPU-Zeiten und kein Prozess im D-Zustand.
IMO ist D auch viel "schlimmer" als Z. Entweder heisst das, dass der
Prozess irgendwo im Kernel an einem Lock hängt, meistens beim Warten auf
IO bei zB. total überlasteter Platte. Das ist schonmal ein Zeichen für
falsche Systemauslegung. Oder (noch viel schlimmer) der Prozess steckt
in einem absgetürzten Kerneltreiber fest. Das löst sich eigentlich nie
mehr ausser durch Reboot.
