STM32F4 Timer PWM + Interrupt
OP #3672452
ich möchte gerne auf meinem STM32F407VGT am Pin PC7 einen akustischen
Signalgeber per PWM ansteuern.
Grundsätzlich funktioniert das auch schon allerdings möchte ich per
Interrupt nach mehrmaligem ausführen des Signals, den Timer wieder
austellen.
Hier erst einmal der Code:
volatile uint8_t beeps = 0;
void BuzzerInit(void)
  GPIO_InitTypeDef GPIO_InitStructure;
  TIM_TimeBaseInitTypeDef TIM_TimeBase_InitStructure;
  TIM_OCInitTypeDef TIM_OC_InitStructure;
  NVIC_InitTypeDef NVIC_InitStructure;
  GPIO_InitStructure.GPIO_Pin = buzzerPin;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
  GPIO_Init(buzzerPort, &GPIO_InitStructure);
  GPIO_PinAFConfig(buzzerPort, GPIO_PinSource7, GPIO_AF_TIM8);
  TIM_TimeBase_InitStructure.TIM_ClockDivision = 0;
  TIM_TimeBase_InitStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBase_InitStructure.TIM_Prescaler = 41999; // 168.000.000 / 42.000 = 4000 (1s = 4000 Ticks)
  TIM_TimeBase_InitStructure.TIM_Period = 1599; // 1600 / 4000 = 0,4 (Überlauf nach 0,4 Sekunden)
23
  TIM_TimeBaseInit(TIM8, &TIM_TimeBase_InitStructure);
24
25
26
  TIM_OC_InitStructure.TIM_OCMode = TIM_OCMode_PWM2;
27
  TIM_OC_InitStructure.TIM_OCIdleState = TIM_OCIdleState_Reset;
28
  TIM_OC_InitStructure.TIM_OCNIdleState = TIM_OCNIdleState_Set;
29
  TIM_OC_InitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
30
  TIM_OC_InitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
31
  TIM_OC_InitStructure.TIM_OutputState = TIM_OutputState_Enable;
32
  TIM_OC_InitStructure.TIM_OutputNState = TIM_OutputNState_Disable;
33
  TIM_OC_InitStructure.TIM_Pulse = 1199;  // Buzzer 0,1s an 0,3s aus
34
  TIM_OC2Init(TIM8, &TIM_OC_InitStructure); //Channel 2
35
36
  TIM_OC2PreloadConfig(TIM8, TIM_OCPreload_Enable);
37
  TIM_ARRPreloadConfig(TIM8, ENABLE);
38
39
  /* Main Output Enable */
40
  TIM_CtrlPWMOutputs(TIM8, ENABLE);
41
42
  /* Enable Timer-Update */
43
  TIM_ITConfig(TIM8, TIM_IT_Update, ENABLE); //DIESE ZEILE ERZEUGT MEIN PROBLEM!!!!!
44
45
46
  /* TIM8 Update Interrupt */
47
  NVIC_InitStructure.NVIC_IRQChannel = TIM8_UP_TIM13_IRQn;
48
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
49
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0E;
50
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0E;
51
  NVIC_Init(&NVIC_InitStructure);
52
53
54
55
void BuzzerBeep(uint8_t beeptimes)
56
57
  beeps = beeptimes;
58
59
  /* TIM8 counter enable */
60
  TIM_Cmd(TIM8, ENABLE);
61
62
63
void TIM8_UP_TIM13_Handler(void)
64
65
  //TIM_ClearFlag(TIM8, TIM_FLAG_Update);
66
  //TIM_ClearITPendingBit(TIM8, TIM_IT_Update);
67
  LedYellowOn();
68
69
  if (beeps > 1)
70
71
     beeps--;
72
73
  else
74
75
     beeps = 0;
76
     /* TIM8 counter disable */
77
     TIM_Cmd(TIM8, DISABLE);
78
79
Sobald ich die Zeile zur Aktivierung des Interrupt-Updates einfüge,
bleibt das Programm hängen... Ich verstehe echt nicht was hier das
Problem ist.
Den Handler habe ich noch zu keinem Zeitpunkt erreicht!!!
Timer8 und GPIOC werden schon vorher mit Clock versorgt.
Gast #3678207
Hast du mal einen anderen IRQ Channel ausprobiert? Zb.
NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
und dann
void TIM8_IRQHandler(void){
Gast #3678217
Warum ist das hier auskommentier?
[c]
[\c]
So wie ich es in erinnerung habe, bleibt er in dem Interrupt hängen,
wenn man diese Befehle nicht ausführt. Vielleicht springst du ja
einmalig in den Interrupt-Handler und bleibst da dann hängen?!
Gast #3678221
Nicht einmalig, sondern immer wieder bis das Flag gelöscht wird.
#3678269
Das funktioniert so auch nicht. Das NVIC Register hat insgesamt nur 4
Bit für die Prioritäten.
Du kannst mit
void NVIC_PriorityGroupConfig(uint32_t NVIC_PriorityGroup)
 einstellen, wie sich die 4 Bit aufteilen. Aber 2 mal 15 Werte hast du
nicht zur Verfügung.
Allerdings sollte das nicht zu einem kompletten "Aufhängen" führen.
Mike
OP #3679062
nun kamen ja doch noch ein paar Antworten, schön :)
asdfg schrieb:
> Deinen TIM8_UP_TIM13_Handler in der Vektortabelle
> an der richtigen Stelle eingetragen?
Ich habe den Handler in der Datei "stm32f4xx_it.c" platziert und in der
entsprechenenden Header-Datei bekannt gemacht.
Ich habe Testweise, Teile des Codes auskommentiert. Allerdings sollte,
wenn der Handler überhaupt erreicht wird die gelbe LED angehen
(LedYellowOn()) aber das tut sie nicht, daher gehe ich davon aus, dass
der Handler garnicht erreicht wird und der Fehler durch die konkrete
Zeile oder in Kombination mit einer anderen entsteht.
> Du kannst mitvoid NVIC_PriorityGroupConfig(uint32_t NVIC_PriorityGroup)
In der SP-Library steht dazu:
uint8_t NVIC_InitTypeDef::NVIC_IRQChannelPreemptionPriority
Specifies the pre-emption priority for the IRQ channel specified in NVIC_IRQChannel. This parameter can be a value between 0 and 15 as described in the table MISC_NVIC_Priority_Table A lower priority value indicates a higher priority
und
uint8_t NVIC_InitTypeDef::NVIC_IRQChannelSubPriority
Specifies the subpriority level for the IRQ channel specified in NVIC_IRQChannel. This parameter can be a value between 0 and 15 as described in the table MISC_NVIC_Priority_Table A lower priority value indicates a higher priority
Ich bin immer nun immer noch nicht weiter mit dem Problem...
OP #3680391
Christian schrieb:
> Hat der Compiler nicht gemeckert, dass er den IRQ-Handler nicht kennt??
Naja ich hab halt meine eigene Funktion definiert, ist ja nichts
verkehrt dran, nur der Interrupt konnte halt nicht dort reinspringen.
Die "Freischaltung" des Handlers war ja richtig:
