STM32F401 flashen geht nicht
OP #3714231
Hallo!
ich versuche einen Program auf STM32F401 Discovery Board zu übertragen ,
der auf STM32F407 Disc.Board problemlos geflasht wird. Hab gemerkt, dass
der STM32F01 andere Flash und Ram Größen hat als STM32F407.
Kann mir jemand helfen, wie ich den flash file ändere.
Viele Grüße!
(gdb) load prog.elf
Loading section .isr_vector, size 0x188 lma 0x8000000
Loading section .text, size 0x36dc lma 0x8000188
Loading section .rodata, size 0x80 lma 0x8003864
Loading section .ARM, size 0x8 lma 0x80038e4
Loading section .init_array, size 0x8 lma 0x80038ec
Loading section .fini_array, size 0x4 lma 0x80038f4
Loading section .data, size 0x8cc lma 0x80038f8
Loading section .jcr, size 0x4 lma 0x80041c4
Error finishing flash operation
**  File        : stm32_flash.ld
**  Abstract    : Linker script for STM32F401VC Device with
**                256KByte FLASH, 64KByte RAM
**                Set heap size, stack size and stack location according
**                to application requirements.
**                Set memory bank area and size if external memory is used.
**  Target      : STMicroelectronics STM32
**  Environment : Atollic TrueSTUDIO(R)
**  Distribution: The file is distributed “as is,” without any warranty
**                of any kind.
**  (c)Copyright Atollic AB.
**  You may use this file as-is or modify it according to the needs of your
23
**  project. This file may only be built (assembled or compiled and linked)
24
**  using the Atollic TrueSTUDIO(R) product. The use of this file together
25
**  with other tools than Atollic TrueSTUDIO(R) is not permitted.
26
27
28
29
30
/* Entry Point */
31
ENTRY(Reset_Handler)
32
33
/* Highest address of the user mode stack */
34
_estack = 0x2000FFFF;    /* end of 64K RAM */
35
36
/* Generate a link error if heap and stack don't fit into RAM */
37
_Min_Heap_Size = 0;      /* required amount of heap  */
38
_Min_Stack_Size = 0x400; /* required amount of stack */
39
40
/* Specify the memory areas */
41
MEMORY
42
43
  FLASH (rx)      : ORIGIN = 0x08000000, LENGTH = 512K
44
  RAM (xrw)       : ORIGIN = 0x20000000, LENGTH = 96K
45
  MEMORY_B1 (rx)  : ORIGIN = 0x60000000, LENGTH = 0K
46
  CCMRAM (rw)     : ORIGIN = 0x10000000, LENGTH = 0K
47
48
49
/* Define output sections */
50
SECTIONS
51
52
  /* The startup code goes first into FLASH */
53
  .isr_vector :
54
55
    . = ALIGN(4);
56
    KEEP(*(.isr_vector)) /* Startup code */
57
    . = ALIGN(4);
58
  } >FLASH
59
60
  /* The program code and other data goes into FLASH */
61
  .text :
62
63
    . = ALIGN(4);
64
    *(.text)           /* .text sections (code) */
65
    *(.text*)          /* .text* sections (code) */
66
    *(.glue_7)         /* glue arm to thumb code */
67
    *(.glue_7t)        /* glue thumb to arm code */
68
    *(.eh_frame)
69
70
    KEEP (*(.init))
71
    KEEP (*(.fini))
72
73
    . = ALIGN(4);
74
    _etext = .;        /* define a global symbols at end of code */
75
  } >FLASH
76
77
  /* Constant data goes into FLASH */
78
  .rodata :
79
80
    . = ALIGN(4);
81
    *(.rodata)         /* .rodata sections (constants, strings, etc.) */
82
    *(.rodata*)        /* .rodata* sections (constants, strings, etc.) */
83
    . = ALIGN(4);
84
  } >FLASH
85
86
  .ARM.extab   : { *(.ARM.extab* .gnu.linkonce.armextab.*) } >FLASH
87
  .ARM : {
88
    __exidx_start = .;
89
    *(.ARM.exidx*)
90
    __exidx_end = .;
91
  } >FLASH
92
93
  .preinit_array     :
94
95
    PROVIDE_HIDDEN (__preinit_array_start = .);
96
    KEEP (*(.preinit_array*))
97
    PROVIDE_HIDDEN (__preinit_array_end = .);
98
  } >FLASH
99
  .init_array :
100
101
    PROVIDE_HIDDEN (__init_array_start = .);
102
    KEEP (*(SORT(.init_array.*)))
103
    KEEP (*(.init_array*))
104
    PROVIDE_HIDDEN (__init_array_end = .);
105
  } >FLASH
106
  .fini_array :
107
108
    PROVIDE_HIDDEN (__fini_array_start = .);
109
    KEEP (*(SORT(.fini_array.*)))
110
    KEEP (*(.fini_array*))
111
    PROVIDE_HIDDEN (__fini_array_end = .);
112
  } >FLASH
113
114
  /* used by the startup to initialize data */
115
  _sidata = LOADADDR(.data);
116
117
  /* Initialized data sections goes into RAM, load LMA copy after code */
118
  .data :
119
120
    . = ALIGN(4);
121
    _sdata = .;        /* create a global symbol at data start */
122
    *(.data)           /* .data sections */
123
    *(.data*)          /* .data* sections */
124
125
    . = ALIGN(4);
126
    _edata = .;        /* define a global symbol at data end */
127
  } >RAM AT> FLASH
128
129
  _siccmram = LOADADDR(.ccmram);
130
131
  /* CCM-RAM section
132
133
  * IMPORTANT NOTE!
134
  * If initialized variables will be placed in this section,
135
  * the startup code needs to be modified to copy the init-values.
136
137
  .ccmram :
138
139
    . = ALIGN(4);
140
    _sccmram = .;       /* create a global symbol at ccmram start */
141
    *(.ccmram)
142
    *(.ccmram*)
143
144
    . = ALIGN(4);
145
    _eccmram = .;       /* create a global symbol at ccmram end */
146
  } >CCMRAM AT> FLASH
147
148
  /* Uninitialized data section */
149
  . = ALIGN(4);
150
  .bss :
151
152
    /* This is used by the startup in order to initialize the .bss secion */
153
    _sbss = .;         /* define a global symbol at bss start */
154
    __bss_start__ = _sbss;
155
    *(.bss)
156
    *(.bss*)
157
    *(COMMON)
158
159
    . = ALIGN(4);
160
    _ebss = .;         /* define a global symbol at bss end */
161
    __bss_end__ = _ebss;
162
  } >RAM
163
164
  /* User_heap_stack section, used to check that there is enough RAM left */
165
  ._user_heap_stack :
166
167
    . = ALIGN(4);
168
    PROVIDE ( end = . );
169
    PROVIDE ( _end = . );
170
    . = . + _Min_Heap_Size;
171
    . = . + _Min_Stack_Size;
172
    . = ALIGN(4);
173
  } >RAM
174
175
  /* MEMORY_bank1 section, code must be located here explicitly            */
176
  /* Example: extern int foo(void) __attribute__ ((section (".mb1text"))); */
177
  .memory_b1_text :
178
179
    *(.mb1text)        /* .mb1text sections (code) */
180
    *(.mb1text*)       /* .mb1text* sections (code)  */
181
    *(.mb1rodata)      /* read-only data (constants) */
182
    *(.mb1rodata*)
183
  } >MEMORY_B1
184
185
  /* Remove information from the standard libraries */
186
  /DISCARD/ :
187
188
    libc.a ( * )
189
    libm.a ( * )
190
    libgcc.a ( * )
191
192
193
  .ARM.attributes 0 : { *(.ARM.attributes) }
194
    STM32F401VCT6 microcontroller featuring 256 KB of Flash memory, 64
KB of RAM in an LQFP100 package
    On-board ST-LINK/V2 with selection mode switch to use the kit as a
standalone ST-LINK/V2 (with SWD connector for programming and debugging)
    Board power supply: through USB bus or from an external 5 V supply
voltage
    External application power supply: 3 V and 5 V
    L3GD20, ST MEMS motion sensor, 3-axis digital output gyroscope.
    LSM303DLHC, ST MEMS system-in-package featuring a 3D digital linear
acceleration sensor and a 3D digital magnetic sensor.
    MP45DT02, ST MEMS audio sensor, omnidirectional digital microphone
    CS43L22, audio DAC with integrated class D speaker driver
    Eight LEDs:
    LD1 (red/green) for USB communication
    LD2 (red) for 3.3 V power on
    Four user LEDs: LD3 (orange), LD4 (green), LD5 (red) and LD6 (blue)
    Two USB OTG LEDs: LD7 (green) VBus and LD8 (red) over-current
    Two pushbuttons (user and reset)
    USB OTG with micro-AB connector
    Extension header for LQFP100 I/Os for a quick connection to the
prototyping board and an easy probing
http://www.st.com/web/catalog/tools/FM116/SC959/SS1532/LN1199/PF259098?icmp=stm32f401discovery_pron_footer_jan2014&sc=stm32f401discovery
OP
Guten Morgen.
ja hab geändert. geht immer noch nicht.
stm32f4xx.h
#if !defined (STM32F40_41xxx) && !defined (STM32F427_437xx) && !defined (STM32F429_439xx) && !defined (STM32F401xx)
  #define STM32F401xx */     /*!< STM32F401CB, STM32F401CC,  STM32F401RB,  STM32F401RC, STM32F401VB and STM32F401VC Devices */
#endif
**                of any kind.
23
24
25
26
27
28
29
30
/* Entry Point */
31
32
33
34
35
36
37
38
39
40
41
MEMORY
42
43
  FLASH (rx)      : ORIGIN = 0x08000000, LENGTH = 256K
44
  RAM (xrw)       : ORIGIN = 0x20000000, LENGTH = 64K
45
46
47
48
49
50
SECTIONS
51
52
53
  .isr_vector :
54
55
    . = ALIGN(4);
56
57
    . = ALIGN(4);
58
  } >FLASH
59
60
61
  .text :
62
63
    . = ALIGN(4);
64
65
66
67
68
    *(.eh_frame)
69
70
    KEEP (*(.init))
71
    KEEP (*(.fini))
72
73
    . = ALIGN(4);
74
75
  } >FLASH
76
77
78
  .rodata :
79
80
    . = ALIGN(4);
81
82
83
    . = ALIGN(4);
84
  } >FLASH
85
86
87
  .ARM : {
88
    __exidx_start = .;
89
    *(.ARM.exidx*)
90
    __exidx_end = .;
91
  } >FLASH
92
93
  .preinit_array     :
94
95
96
97
98
  } >FLASH
99
  .init_array :
100
101
102
103
104
105
  } >FLASH
106
  .fini_array :
107
108
109
110
111
112
  } >FLASH
113
114
115
116
117
118
  .data :
119
120
    . = ALIGN(4);
121
122
123
124
125
    . = ALIGN(4);
126
127
  } >RAM AT> FLASH
128
129
130
131
  /* CCM-RAM section
132
133
  * IMPORTANT NOTE!
134
135
136
137
  .ccmram :
138
139
    . = ALIGN(4);
140
141
    *(.ccmram)
142
    *(.ccmram*)
143
144
    . = ALIGN(4);
145
146
  } >CCMRAM AT> FLASH
147
148
149
  . = ALIGN(4);
150
  .bss :
151
152
153
154
155
    *(.bss)
156
    *(.bss*)
157
    *(COMMON)
158
159
    . = ALIGN(4);
160
161
162
  } >RAM
163
164
165
  ._user_heap_stack :
166
167
    . = ALIGN(4);
168
169
170
171
172
    . = ALIGN(4);
173
  } >RAM
174
175
176
177
  .memory_b1_text :
178
179
180
181
182
    *(.mb1rodata*)
183
  } >MEMORY_B1
184
185
186
  /DISCARD/ :
187
188
    libc.a ( * )
189
    libm.a ( * )
190
    libgcc.a ( * )
191
192
193
194
