TC35 C+ Programmierfehler?
Gast #3775588
hallo an alle :)
ich verzweifle bald
mein code steht und funktioniert so:
#include <SoftwareSerial.h>
SoftwareSerial mySerial(8, 9);
String inData = "";
char last;
#include <DHT.h>
#include <SD.h>
#define DHTPIN 2
#define DHTTYPE DHT22
DHT dht1 (DHTPIN, DHTTYPE);
#include <SPI.h>
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 RTC;
const int chipSelect = 4;
const int analogInPin = A0;
int sensorValue = 0;
void setup()
24
  Wire.begin();
25
  RTC.begin();
26
  Serial.begin(9600);
27
  Serial.println("Starte...");
28
29
  mySerial.begin(9600);
30
  mySerial.println("AT");
31
  pinMode(10, OUTPUT);
32
33
  if (!SD.begin(chipSelect))
34
35
    Serial.println("Card failed, or not present");
36
    return;
37
38
39
  Serial.println("card initialized.");
40
  Serial.println("");
41
  delay(1000);
42
43
44
void call(String n)
45
46
  mySerial.print("ATD");
47
  mySerial.print(n);
48
  mySerial.println(";");
49
  Serial.println("Starte Anruf...");
50
  delay(10000);
51
  mySerial.println("ATH");
52
  Serial.print("Anruf an ");
53
  Serial.print(n);
54
  Serial.println(" beendet");
55
56
57
void loop()
58
59
60
  while (Serial.available() > 0)
61
62
    char recieved = Serial.read();
63
    inData += recieved;
64
65
    if (recieved == '\n')
66
67
      Serial.print("Arduino Received: ");
68
      Serial.print(inData);
69
70
71
72
  DateTime now = RTC.now();
73
74
  if (inData == "d")
75
76
    Serial.print(now.day(), DEC);
77
    Serial.print('.');
78
    Serial.print(now.month(), DEC);
79
    Serial.print('.');
80
    Serial.print(now.year(), DEC);
81
    Serial.print(' ');
82
    Serial.print(now.hour(), DEC);
83
    Serial.print(':');
84
    Serial.print(now.minute(), DEC);
85
    Serial.print(':');
86
    Serial.println(now.second(), DEC);
87
    Serial.println();
88
89
90
  String dataString = "";
91
92
  sensorValue = analogRead(analogInPin);
93
94
  float h = dht1.readHumidity();
95
96
  float t = dht1.readTemperature();
97
98
  if (isnan(t) || isnan(h))
99
100
    Serial.println ("Fehler - Lesen von Luftfeuchte bzw. Temperatur");
101
    Serial.println("Gaswert soll: < 100");
102
    Serial.print("Gaswert ist:  < ");
103
    Serial.println(sensorValue);
104
    Serial.println("");
105
106
107
  if (inData == "a")
108
109
    Serial.print("Feuchte:        ");
110
    Serial.print(h);
111
    Serial.println(" %   ");
112
    Serial.print("Temperatur:     ");
113
    Serial.print(t);
114
    Serial.println(" C");
115
116
117
118
    Serial.println("");
119
    delay(1000);
120
121
122
  if (last != now.minute())
123
124
    byte a = h;
125
    byte b = t;
126
    byte c = sensorValue;
127
    dataString += String(a);
128
    dataString += ",";
129
    dataString += String(b);
130
    dataString += ",";
131
    dataString += String(c);
132
    dataString += ",";
133
    dataString += String(now.day(), DEC);
134
    dataString += ".";
135
    dataString += String(now.month(), DEC);
136
    dataString += ".";
137
    dataString += String(now.year(), DEC);
138
    dataString += ",";
139
    dataString += String(now.hour(), DEC);
140
    dataString += ":";
141
    dataString += String(now.minute(), DEC);
142
    dataString += ";";
143
144
    File dataFile = SD.open("datalog.txt", FILE_WRITE);
145
146
    if (dataFile)
147
148
      dataFile.println(dataString);
149
      dataFile.close();
150
      Serial.println(dataString);
151
      Serial.println("Gespeichert - SD: 'datalog.txt'");
152
153
    else
154
155
      Serial.println("Fehler - Lesen von SD: 'datalog.txt'");
156
157
158
    last = now.minute();
159
160
    Serial.println("");
161
162
163
  if (inData == "c")
164
165
    call("x");
166
167
168
  if (inData.length() > 4)
169
170
    call(inData);
171
172
173
  dataString="";
174
  inData = "";
175
  delay(100);
176
177
wenn ich jetzt an diesem code aber was ändere, sei es eine zeile in
call() oder ich setzte, was ich gerne hätte folgenden code egal wohin in
meinen sketch, sagt er fehler beim sd karte lesen...
if ((sensorValue > 60) || (t > 50) || h > 80))
  mySerial.print("AT+CMGF=1\r");
  delay(100);
  mySerial.println("AT+CMGS=\"xxxxxx\"");
  delay(100);
  mySerial.print("Temp: ");
  mySerial.print(t);
  mySerial.println(" C");
  mySerial.print("Feuchte: ");
  mySerial.print(h);
  mySerial.println(" %");
  mySerial.print("Gas: ");
  mySerial.print(sensorValue);
  delay(100);
  mySerial.println((char)26);
also auch wenn ich etwas unerhebliches ändere streikt er sofort, ich
verstehe es einfach nicht, vollkommen gleichgültig ob ich den code nach
oder vor der speicheranweisung setzte, sofort geht das speichern nicht
mehr...
kann mir da bitte einer helfen, vlt wirke ich ja irgendwie auf den
speicherprozess ein, allerdings reicht es auch schon nur in call() etwas
zu verändern, eine kleinigkeit und er streikt...
hilfe
#3775865
Kann sein.
Muß nicht.
Wer soll das wissen? Eine vernünftige Beschreibung des Problems wäre
vielleicht hilfreich (bei "geht nicht" schließ eich zumindest gleich
wieder das Fenster und mache etwas interessanteres).
Ebenso welche Umgebung du hast, wie alle deine eigenen Quelltexte
aussehen, wo der Rest herkomt, ...
TC35 ist ein Siemens Handy? C+ eine Sparversion von C++?
Gast #3775917
das problem ist das er fehler beim lesen von sd ausgibt sobald ich die
gsm anweisung einpflege
ich arbeite mit der "Arduino 1.0.5-r2" sofware von arduino
das tc35 ist ein chip, ich habe das board erworben, hier ein link
http://www.ebay.de/itm/Neu-GSM-SIEMENS-TC35-SMS-drahtlos-Module-UART-232-Free-Voice-Adapter-/320856057878?pt=Elektromechanische_Bauelemente&hash=item4ab482e816
es geht halt nur darum das es so unlogisch ist, der code funktioniert ja
soweit, ändere ich eine kleinigkeit, sei es nur den inhalt eines print
befehls in call(), hat er wieder den fehler beim lesen der sd karte,
egal wo ich den gsm befehl einpflege, fehler beim lesen
der gsm befehl alleine funktioniert, deswegen vermute ich ja das die
sich in die quere kommen oder so, ich brauch aber beide, sonst m uss ich
n zweites board benutzen... :(
#3775953
Und das Arduino läuft auf diesem TC35? Wieviel RAM hat das denn?
Vielleicht läuft ja der Speicher über.
Sowas riecht für mich z.B. nach starker Speicherfragmentierung:
>     dataString += ",";
>     dataString += ",";
>     dataString += ",";
>     dataString += ".";
>     dataString += ".";
>     dataString += ",";
>     dataString += ":";
>     dataString += ";";
Gast #3775963
ok guter ansatz denke ich, nur warum is das nur wenn ich den gsm befehl
einsetze? die variablen sind ja schon beschrieben und wenn ichs flashe
sagt mein kompiler Binäre Sketchgröße: 24.426 Bytes (von einem Maximum
von 32.256 Bytes)
ich verstehe das jetzt so das der speicher überladen sein könnte, nur
habe ich die variablen t,h,sensorValue doch so wie so schon für die
andren funktionen beschrieben, oder versteh ich hier grad was falsch?
#3775975
> einsetze?
Da kommen doch z.B. Strings dazu, oder nicht? Die müssen ja auch
irgendwo gespeichert werden.
> von 32.256 Bytes)
Ich weiß nicht, was bei der Android-Nomenklatur eine "Binäre
Sketchgröße" ist, aber ich vermute, es geht um den Flash. RAM wird aber
auch noch benötigt, und wieviel das ist, weißt du zur Compilezeit nicht.
PS: C++ ist case-sensitiv, also solltest du dir mal eine Tastatur mit
funktionierender Shift-Taste kaufen...
Gast #3776120
so also ich hab jetzt den code angepasst, das anrufen muss ja nicht
sein, jetzt siehts wie folgt aus UND funktioniert, ich danke allen für
die hinweise, das mit dem internen speicher scheint zutreffend gewesen
zu sein..
String inData = "";
char last;
#include <DHT.h>
#include <SD.h>
#define DHTPIN 2
#include <SPI.h>
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 RTC;
int sent = 0;
void setup()
  Wire.begin();
24
  RTC.begin();
25
  Serial.begin(9600);
26
27
28
29
30
31
32
33
34
35
    return;
36
37
38
39
  Serial.println("");
40
  delay(1000);
41
42
43
void loop()
44
45
46
47
48
49
    inData += recieved;
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
    Serial.print("Gaswert ist:    ");
72
73
    Serial.println(" ppm");
74
    Serial.println("");
75
76
77
  if (inData == "a")
78
79
80
    Serial.print(h);
81
82
83
    Serial.print(t);
84
85
86
87
    Serial.println(".00 ppm");
88
    Serial.println("");
89
    delay(1000);
90
91
92
93
94
    byte a = h;
95
    byte b = t;
96
97
98
    dataString += ",";
99
100
    dataString += ",";
101
102
    dataString += ",";
103
104
    dataString += ".";
105
106
    dataString += ",";
107
108
    dataString += ":";
109
110
    dataString += ";";
111
112
113
114
    if (dataFile)
115
116
117
      dataFile.close();
118
119
120
121
    else
122
123
124
125
126
127
128
    Serial.println("");
129
130
131
 if (sent == 0)
132
133
 if ((sensorValue > 80) || (t > 60) || (h > 80) || (inData == "t"))
134
135
136
  delay(100);
137
  mySerial.println("AT+CMGS=\"01725130975\"");
138
  delay(100);
139
  mySerial.println("ALARM!");
140
141
  mySerial.print(t);
142
143
144
  mySerial.print(h);
145
146
147
148
  mySerial.println(".00 ppm");
149
  delay(100);
150
151
  delay(100);
152
  Serial.println("SMS an xxxxx versendet");
153
  Serial.println("");
154
  sent = 1;
155
156
157
158
  dataString="";
159
  inData = "";
160
  delay(100);
161
es funktioniert jetzt jedenfalls DANKE DANKE :)
Gast #3821595
ich schaffe es auch nicht. Alles was ich mit #include <DHT.h> eingebe.
kommt:  fatal error: DHT.h: No such file or directory
compilation terminated. was muss ich machen?????
