Run on Target Hardware: ERROR
Gast #3834195
hallo,
ich möchte eine Schaltung auf dem Beagleboneblack simulieren aber es
wird folgendes angezeigt:
______________________________________________________________________
__
The call to realtime_make_rtw_hook, during the after_make hook generated
the following error:
Error executing SSH command: make: Entering directory
`/home/etw/untitled_rtt'
"gcc" -I"./" -O2 -mcpu=cortex-a8 -mfpu=neon -mfloat-abi=softfp
-D"MODEL=untitled" -D"NUMST=1" -D"NCSTATES=0" -D"HAVESTDIO="
-D"ONESTEPFCN=0" -D"EXT_MODE=1" -D"TERMFCN=1" -D"MAT_FILE=0"
-D"MULTI_INSTANCE_CODE=0" -D"INTEGER_CODE=0" -D"MT=0" -D"TID01EQ=0"
-D"_USE_TARGET_UDP_=" -D"_RUNONTARGETHARDWARE_BUILD_=" -c ./linuxUDP.c
./ext_svr.c ./ext_work.c ./rtiostream_interface.c ./updown.c
./rtiostream_tcpip.c ./ert_main.c ./untitled.c ./untitled_data.c
"gcc" ./linuxUDP.o ./ext_svr.o ./ext_work.o ./rtiostream_interface.o
./updown.o ./rtiostream_tcpip.o ./ert_main.o ./untitled.o
./untitled_data.o -lm -ldl -lpthread -lrt -o ./MW/untitled
/usr/bin/ld: error: ./MW/untitled uses VFP register arguments,
./linuxUDP.o does not
/usr/bin/ld: failed to merge target specific data of file ./linuxUDP.o
./ext_svr.o does not
/usr/bin/ld: failed to merge target specific data of file ./ext_svr.o
./ext_work.o does not
/usr/bin/ld: failed to merge target specific data of file ./ext_work.o
./rtiostream_interface.o does not
./updown.o does not
/usr/bin/ld: failed to merge target specific data of file ./updown.o
./rtiostream_tcpip.o does not
./ert_main.o does not
/usr/bin/ld: failed to merge target specific data of file ./ert_main.o
./untitled.o does not
/usr/bin/ld: failed to merge target specific data of file ./untitled.o
./untitled_data.o does not
./untitled_data.o
collect2: ld returned 1 exit status
make: Leaving directory `/home/etw/untitled_rtt'
make: *** [MW/untitled] Error 1
The build process will terminate as a result.
_
Kann jemand mir helfen?
Bedanke im Voraus!
LG
Gast #3834380
vielen dank für schnelle Antworten.
Wenn ich gut verstanden habe, das Problem liegt bei der Verbindung der
Simulink mit dem Hardware(BBB).
Also, vor der Simulation, ich muss mein Modell mit dem BBB verbinden.
Wenn ich "Connect to Target" klicke, dann wird die oben vorliegende
ERROR-Nachricht angezeigt.
Im Matlab wird folgendes angezeigt:
"Unable to establish connection with server '192.168.x.x' . Verify that
your application is serving on port '17725'."
Kann jemand mir in kurzer Linien erklären, wie kann ich Simulink-Modell
mit BBB verbinden.
Ich habe schon im Google gesucht, aber kein Erfolg bis jetzt!
Bedanke im Voraus!
