Product of two dirac impulses
Hello,
look at the definition of the delta Impulse. You will find
d(x)=1 for x=0, else 0
So d(x) * d(x) gives 2*d(x)
Using the definition, you can give an answer onto your second question
by yourself.
Btw: I guess the question is wrong. I think you mean d(t)*f(t) =
d(t)*f(0) or Integral over d(t)*f(t) results to f(0)
I hope this was useful,
best regards,
Florian
Florian Pfanner schrieb:
> Hello,
> by yourself.
> best regards,
> Florian
I think d(0) is infinity.
> Hello,
> by yourself.
> best regards,
> Florian
Okay. Thanks!
And ist than d(x-x0) * d(x) = d(x0) =0?
first of all you should clarify whether we're talking about discrete
time or continuous time.
In the first case delta[t] is 0 exept for t=0 where it is 1. This is an
easy answer to your question. And you've already got it.
The continuous time case is more elaborate as delta(t) is 0 for all t
exept for t=0 where it converges to positive infinity. This is due to
the fact that the integral over delta(t) needs to be 1 in both domains.
So in theory delta(t)*delta(t) should be equivalent to delta(t) as the
integral of both is 1=1².
> discrete
I mean the continuous time case.
