16X1 LCD zeigt nur 8 Zeichen
OP #3877404
Hallo,is
kannst mir jemand sagen, was an meinem Code falsch ist.
Ich möchte über den 8Bit-Mode ein LDC Display ansteuern
Gelesen habe ich schon wie es geht, es will aber trotzdem nicht
funktionieren.
Hier der c-Code
 * LCD_Anzeige.c
 * Created: 09.11.2014 23:07:36
 *  Author: Admin
#define F_CPU  4000000UL
#include <avr/io.h>
#include <util/delay.h>
/*LCD function declarations */
void LCD_send_command(unsigned char cmnd);
void LCD_send_data(unsigned char data);
void LCD_init();
void LCD_goto(unsigned char y, unsigned char x);
void LCD_print(char *string);
void LCD_blink();
void LCD_scroll(unsigned char direction);
23
24
#define LCD_DATA_PORT   PORTC
25
#define LCD_DATA_DDR  DDRC
26
#define LCD_DATA_PIN  PINC
27
28
#define LCD_CNTRL_PORT  PORTD
29
#define LCD_CNTRL_DDR  DDRD
30
#define LCD_CNTRL_PIN  PIND
31
32
#define LCD_RS_PIN    2
33
#define LCD_RW_PIN    3
34
#define LCD_ENABLE_PIN  4
35
36
37
38
int main(void)
39
40
41
  DDRB = 0xFF;
42
  unsigned char i;
43
44
  LCD_init();
45
  //LCD_goto(1,2);
46
  LCD_print("<<>>HALLO<<>>");
47
  //LCD_goto(2,3);
48
  //LCD_print("WELCOMES YOU");
49
50
  while(1)
51
52
    //for(i=0;i<2;i++)
53
    //LCD_blink();
54
55
    //PORTB = 0xFF;
56
    //_delay_us(1000);
57
    //PORTB = 0x00;
58
    //_delay_us(1000);
59
60
    for(i=0;i<15;i++)
61
    LCD_scroll(0);
62
63
    //for(i=0;i<4;i++)
64
    //LCD_scroll(1);
65
66
    //for(i=0;i<2;i++)
67
    //LCD_scroll(0);
68
69
70
71
/* This function sends a command 'cmnd' to the LCD module*/
72
73
74
  LCD_DATA_PORT = cmnd;
75
  LCD_CNTRL_PORT &= ~(1<<LCD_RW_PIN);
76
  LCD_CNTRL_PORT &= ~(1<<LCD_RS_PIN);
77
78
  LCD_CNTRL_PORT |= (1<<LCD_ENABLE_PIN);
79
  _delay_us(2);
80
  LCD_CNTRL_PORT &= ~(1<<LCD_ENABLE_PIN);
81
  _delay_us(100);
82
83
84
/* This function sends the data 'data' to the LCD module*/
85
86
87
  LCD_DATA_PORT = data;
88
89
  LCD_CNTRL_PORT |= (1<<LCD_RS_PIN);
90
91
92
  _delay_us(2);
93
94
  _delay_us(100);
95
96
97
void LCD_init()
98
99
  LCD_CNTRL_DDR = 0xFF;
100
  LCD_CNTRL_PORT = 0x00;
101
  LCD_DATA_DDR = 0xFF;
102
  LCD_DATA_PORT = 0x00;
103
104
  _delay_ms(50);
105
  LCD_send_command(0x38);
106
  LCD_send_command(0x0C);
107
  LCD_send_command(0x01);
108
  LCD_send_command(0x0E);
109
  _delay_ms(1000);
110
  LCD_send_command(0x14);
111
  LCD_send_command(0x0F);
112
  //LCD_send_command(0x01);
113
   //_delay_ms(10);
114
  LCD_send_command(0xFF);
115
116
  //LCD_send_command(0x06);
117
118
119
120
/* This function moves the cursor the line y column x on the LCD module*/
121
122
123
  unsigned char firstAddress[] = {0x80,0xC0,0x94,0xD4};
124
125
  LCD_send_command(firstAddress[y-1] + x-1);
126
  _delay_ms(10);
127
128
129
130
131
  unsigned char i=0;
132
133
  while(string[i]!=0)
134
135
    LCD_send_data(string[i]);
136
    i++;
137
138
139
140
void LCD_blink()
141
142
  LCD_send_command(0x08);
143
  _delay_ms(250);
144
145
  _delay_ms(250);
146
147
148
149
150
  if(direction == 0)
151
  LCD_send_command(0x18);
152
  else
153
  LCD_send_command(0x1C);
154
155
  _delay_ms(500);
156
OP #3877466
Ok Super danke jetzt bin ich einen Schritt weiter.
Nun wird der Txt hinten (letze 8 Zeichen) angezeigt.
Kann ich ihn jetzt den Txt auch mit einem weiteren Befehl über das ganze
LCD laufen lassen (scolen lassen)
Danke
Tom
#3877508
Auch wenbn es ein Scroll Kommando gibt, so wird dir das niccht viel
helfen.
Dein erstes Ziel ist es, die logische Unterteilung des LCD in 2 Zeilen
(gegen die du nichts machen kannst) aufzuheben und dir eine Funktion zu
schreiben, die sich darum kümmert, dass Ausgaben wie "Hallo Welt!" in 2
Zeilen aufgeteilt werden müssen: Die ersten 8 Zeichen in die erste
Zeile, die weiteren 8 Zeichen in die 2.te Zeile.
Natürlich unter Berücksichtigung der aktuellen Cursorposition und
natürlich unter Berücksichtigung der Textlänge. Steht der Cursor in der
Spalte 2, dann eben nur die ersten 6 Zeichen in die erste Zeile und die
weiteren in die 2. Zeile.
Hast du eine derartige Funktion, so dass du Textausgaben machen kannst,
ohne dich um die tatsächliche vorgegebene logische Zeilenunterteilung
kümmern zu müssen, dann besteht Scrollen darin, dass du deinen zu
scrollenden Text derart ausgibst, dass jeweils 1 Zeichen mehr sichtbar
ist. Um also "Hallo Welt!" auszugeben, gibst du hintereinander aus
"               H"
"              Ha"
"             Hal"
"            Hall"
"           Hallo"
"          Hallo "
"         Hallo W"
"        Hallo We"
usw. usw.
D.h. du musst dich selbst drum kümmern, immer den Teil des Textes an der
richtigen Stelle auszugeben, so dass der Eindruck des Durchscrollens
entsteht. Sowohl bei links- als auch bei rechts-scrollen.
Aber der erste Schritt ist, dass du dich nicht mehr um die logische
Zeilenunterteilung kümmern willst. Wenn du "Hamst Bamsti" ausgeben
willst, dann willst du auch eine Ausgabefunktion haben, der du den
String genau so übergibst, und die dann selbst die Aufteilung in die
erste und zweite Zeile macht, so dass am LCD der Text fortlaufend lesbar
ist.
