PIC32MX I2C Modul nicht initialisiert
Gast #3880145
ich nutze das PIC32 Starterkit und versuche eine I2C Kommunikation
aufzubauen.
Der Code sieht wie folgt aus:
#define _SUPPRESS_PLIB_WARNING 1
#include <p32xxxx.h>
#include <stdio.h>
#include <stdlib.h>
#include <plib.h>
#include <stdio.h>
#include <stdlib.h>
#pragma config FPLLMUL = MUL_20, FPLLIDIV = DIV_2, FPLLODIV = DIV_1, FWDTEN = OFF
#pragma config POSCMOD = HS, FNOSC = PRIPLL, FPBDIV = DIV_1
#define SYS_FREQ (80000000L)
#define GetSystemClock()           (SYS_FREQ)
#define GetPeripheralClock()       (SYS_FREQ/1)
#define GetInstructionClock()      (SYS_FREQ)
#define I2C_CLOCK_FREQ             100000
24
#define EEPROM_I2C_BUS              I2C1
25
#define EEPROM_ADDRESS              32        // 0b0100000 = 32 = 0x20
26
27
int main()
28
29
30
    UINT8               i2cData[10];
31
    // erstes Bit -> read/write; 7-Bit Slave Adresse
32
    I2C_7_BIT_ADDRESS   SlaveAddress;
33
    int                 Index;
34
    int                 DataSz;
35
    UINT32              actualClock;
36
    BOOL                Acknowledged;
37
    BOOL                Success = TRUE;
38
    UINT8               i2cbyte;
39
40
    // Initialize debug messages (when supported)
41
    DBINIT();
42
43
    // Set the I2C baudrate
44
    actualClock = I2CSetFrequency(EEPROM_I2C_BUS, GetPeripheralClock(), I2C_CLOCK_FREQ);
45
    if ( abs(actualClock-I2C_CLOCK_FREQ) > I2C_CLOCK_FREQ/10 )
46
47
        DBPRINTF("Error: I2C1 clock frequency (%u) error exceeds 10%%.\n", (unsigned)actualClock);
48
49
50
51
    // Enable the I2C bus
52
    I2CEnable(EEPROM_I2C_BUS, TRUE);
53
54
    // Initialize the data buffer
55
    I2C_FORMAT_7_BIT_ADDRESS(SlaveAddress, EEPROM_ADDRESS, I2C_WRITE);
56
    i2cData[0] = SlaveAddress.byte;
57
    i2cData[1] = 0xFF;              // EEPROM location to program (high address byte)
58
    i2cData[2] = 0xFF;              // EEPROM location to program (low address byte)
59
60
    DataSz = 3;
61
62
63
    // Start the transfer to write data to the EEPROM
64
    if( !StartTransfer(FALSE) )
65
66
        while(1);
67
68
69
70
Beim Debuggen bleibt das Programm immer in der Schleife
        while(1);
hängen.
Hier nochmal die bereitgestellte StartTransfer Funktion:
[c]
BOOL StartTransfer( BOOL restart )
    I2C_STATUS  status;
    Nop();
    Nop();
    Nop();
    // Send the Start (or Restart) signal
    if(restart)
        I2CRepeatStart(EEPROM_I2C_BUS);
    else
        // Wait for the bus to be idle, then start the transfer
        while( !I2CBusIsIdle(EEPROM_I2C_BUS) );
        if(I2CStart(EEPROM_I2C_BUS) != I2C_SUCCESS)
            DBPRINTF("Error: Bus collision during transfer Start\n");
            return FALSE;   // <- Hier wird FALSE zurückgegeben
    // Wait for the signal to complete
    do
        status = I2CGetStatus(EEPROM_I2C_BUS);
    } while ( !(status & I2C_START) );
    return TRUE;
[\c]
Wo False zurückgegeben wird habe ich oben markiert. Scheinbar wird das
Modul nicht richtig konfiguriert. Ich nutze ja das I2C1-Modul. Diese
befinden sich beim PIC32MX795L an den Pins 84 und 86. Bei vorherigen
Pics musste ich noch mittels Peripheral Pin select die Funktionen auf
die jeweiligen Pins Mappen. Dies entfällt offenbar bei dem PIC32. Also
einfach I2C Komponente an Pins 84 u. 86 und fertig!
Irgendwelche Verbesserungsvorschläge oder Ideen woran es liegen kann,
dass ich immer in der Schleife hängen bleibe?
Danke und Gruß
Gast #3880431
Niemand eine Ahnung, woran es liegen könnte, dass ich das Startbit nicht
senden kann? Ich würde einen Softwarefehler fast ausschließen, dass das
Senden des Startbits in nahezu allen LIBs genauso implementiert ist.
Die SCL1 und SDA1 Leitung hab ich über einen 3,9K PullUp einfach an die
entsprechenden Leitung der I2C Komponente gehängt.
Gast #3880492
Hameg schrieb:
> Ist while(1); denn nicht eine Endlosschleife?
richtig, hier bleibt er ja hängen. Wenn das Startbit richtig gesendet
werden würde, sollte in diese Schleife ja idealerweise gar nicht in die
Schleife springen.
Es muss etwas mit der Initialisierung des I2C Moduls zu tun haben.
Über
habe ich ja (so hoffe ich) das I2C1 Modul ausgewählt. Ich bin mir
unsicher ob das alles ist was ich tun muss.
Es gibt auch die weiteren Module wie
*          chn   :  I2C1A
*          chn   :  I2C2A
*          chn   :  I2C3A
*          chn 3  : I2C1
*          chn   :  I2C2
Was es damit auf sich hat ist mir noch nicht so ganz klar!
Gast #3880681
>         while(1);
wenn ich das richtig deute bleibt er in der endlosschleife hängen.
WEIL:
 in der if anweisung hebst du das false wieder auf mit dem !
wenn start transfehr nicht FALSE ist dann
while(1)
da du deine initialisierung hinbekommst ist der start transfer richtig.
Gast #3880788
Es wird in der while Schleife verweilt, weil in
 False zurückgegeben wird.
Ich habe das ganze jetzt mit I2C2 versucht (also nicht mit dem I2C1) und
ich kann zumindest ein Byte übertragen. Leider wird nach dem ersten
Adressbyte kein ACK-Bit gesendet.
Wird bei I2C grundsätzlich nach jedem gesendeten Byte ein ACK-Bit
gesendet?
Wie kann es sein, dass I2C2 funktioniert, aber I2C1 nicht?
Gast #3880903
das kann ich dir leider nicht sagen habe nie mit einem PIC gearbeitet
der diese Auswahl hatte.
> gesendet?
Ja, solange du werte Lesen möchtest.
Wenn du deine werte hast die die brauchst sendest du ein nack und es
wird nicht weitergesendet.
#3880917
Die I2C1-Pins 66 & 67 liegen auch die "alternativen" Ethernetsignale
AETXEN & AETXCLK.
Die würde ich mal abschalten da nach einem Reset ungewiss ist, welche
Einstellung vorhanden ist.
<DEVCFG3.FETHIO = 1> weist Ethernet die Default-Pinbelegung zu. Wenn
dort nach einem Reset "0" steht, ist I2C1 blockiert.
