AT90CAN128 uart RX Interrupt
OP #3926521
Hallo
Beschäftige mich gerade mit dem Prozessor AT90CAN128
Beim Empfangen von Daten über RXD0 resetet mein System.
Das ende klappt.
Aber auch nur beim Empfangen von einen char tillt alles.
Gruss
//C Code Example (1)
#include "pins.h"
#include "uart.h"
#include <avr/interrupt.h>
unsigned int buffercounter = 0;
char usart_rx_buffer[BUFFER_SIZE],newdata;
char *rx_buffer_pointer_in  = &usart_rx_buffer[0];
char *rx_buffer_pointer_out  = &usart_rx_buffer[0];
unsigned char receive_char;
void USART0_Init (unsigned long baudrate)
//void USART0_Init (unsigned long baudrate)
  unsigned long baud = (F_CPU/(16*baudrate))-1;
  SETBIT (DDRE,PE1);
  /* Set baud rate */
  UBRR0H = (unsigned char) (baud>>8);
  UBRR0L = (unsigned char) baud;
  /* Set frame format: 8data, no parity & 2 stop bits */
23
  UCSR0C = (0<<UMSEL0) | (0<<UPM0) | (1<<USBS0) | (3<<UCSZ0);
24
  /* Enable receiver and transmitter */
25
//  UCSR0B = (1<<RXEN0) | (1<<TXEN0);
26
    UCSR0A =0;
27
  UCSR0B =(1 << TXEN0 | 1 << RXEN0 | 1<< RXCIE0);
28
  //return baud;
29
30
31
void USART0_Transmit (unsigned char data)
32
33
  /* Wait for empty transmit buffer */
34
  while ( ! ( UCSR0A & (1<<UDRE0)));
35
  /* Put data into buffer, sends the data */
36
  UDR0 = data;
37
38
39
void SendRs232(char* string)//Nullterminiert
40
41
  unsigned char ende = 0;
42
  int i=0;
43
  while(!ende)
44
45
    unsigned char data = string[i++];
46
    if(data == 0)
47
      ende = 1;
48
    else
49
      USART0_Transmit(data);
50
51
52
53
ISR (USART_RX0)
54
55
56
57
      while (!(UCSR0A & (1<<RXC0)));
58
       receive_char=UDR0;
59
/*    receive_char=UDR0 &127;  // &127 damit auch 7 Datenbit funktioniert.
60
    usart_rx_buffer[buffercounter]=receive_char;
61
  buffercounter++;
62
63
    if((buffercounter > BUFFER_SIZE - 1)||(receive_char==13))
64
65
     if((buffercounter < BUFFER_SIZE )&&(receive_char==13))
66
         usart_rx_buffer[buffercounter+1]=0; // f?r stringende !
67
     buffercounter=0;
68
69
70
71
72
Gast #3926530
Im Anhang das ganze in lesbar. Jede IDE und jeder bessere Editor hat
automatische Formatierung. Wie kann man in so einem Wust programmieren
und hoffen, den Überblick zu behalten?
Franz Suahnein schrieb:
> ISR (USART_RX0)
Bist du sicher, dass der Name des Interrupt-Vektors, USART_RX0, korrekt
ist?
Da zb das entsprechende Bit im UCSR0A den Namen RXC0 trägt, hätte ich
als Name jetzt mal eher USART_RXC0 angenommen. Aber ich gebe zu, dass
Atmel da mit den Bezeichnungen nicht ganz einheitlich ist. Allerdings
teilt dir der Compiler ja als Warnung mit, dass er mit dem Namen des
INterrupts nichts anfangen kann.
Allerdings ist es auch so, dass das Symptom "Reset beim Auftreten eines
Interrupt Ereignisses" ein deutliches Indiz für einen Schreibfehler im
Interrupt Namen ist
das ist ziemlich sinnlos.
Die Interrupt Funktion ist aufgerufen worden, WEIL ein Zeichen an der
UART vorliegt, das abgeholt werden will. Das brauchst du hier nicht mehr
testen. An dieser Stelle steht einwandfrei und zweifellos fest, dass es
ein Zeichen in UDR0 gibt.
OP #3926665
Hallo
So mal geändert.
Aber der Prozessor resetet nicht sonder kommt garnicht mehr.
Bei dem AT90CAN128 ist das ISP System auch auf TX0 RX0,also
zusammengeschaltet mit MISO und MOSI.
Auch die Routine ohne Interrupt bringt das programm zu stehen.
Mit dem Ozsi sieht alles gut auch.
Auch nach dem programmieren das den AVR-ISP entfernen bringt nichts.
Was kann es noch sein.
ISR(USART0_vec)
/ISR (USART0)
main_counter++;
//      while (!(UCSR0A & (1<<RXC0)));
     receive_char=UDR0;
  buffercounter++;
     buffercounter=0;
24
uint8_t USART0_Receive(void)
25
26
  while ( !(UCSR0A & (1<<RXC0)) );
27
  main_counter++;
28
  return UDR0;
29
#3926705
Hast du auch die Freigabe des Interrupts hier
rausgenommen?
Man kann es nicht oft genug betonen.
Wenn es eine ISR nicht gibt, du den entsprechenden Interrupt aber
freigibt, dann kommt es beim Auftreten des Interrupts zu einem Reset.
Ob es die ISR nicht gibt, weil du sie nicht geschrieben hast, oder weil
sie nicht als solche erkannt wurde, weil du dich im Namen vertan hast,
ist dabei unerheblich. Nicht benutzbar ist nicht benutzbar und der dann
benutzte Default-Handler macht nun mal einen Reset.
OP #3926716
  /* Set baud rate */
  UCSR0B =(1 << TXEN0 | 1 << RXEN0 | 0<< RXCIE0);
Will hoffen das mit dem "0<<RXCIE0" richtig ist.
ISR(USART0_vec)
sollte doch auch richtig sein.
