Strahlenfestigkeit PMOS
tom schrieb:
> Warum sind PMOS-Transistoren gegen Strahlung weniger empfindlich
> als
> NMOS Transistoren?
Ich vermute den Grund mal hierin:
Neutron transmutation doping
Neutron transmutation doping (NTD) is an unusual doping method for
special applications. Most commonly, it is used to dope silicon n-type
in high-power electronics. It is based on the conversion of the Si-30
isotope into phosphorus atom by neutron absorption as follows:
            ^{30}\mathrm{Si} \, (n,\gamma) \, ^{31}\mathrm{Si}
\rightarrow \, ^{31}\mathrm{P} + \beta^- \; (\mathrm{T}_{1/2} = 2.62 h).
In practice, the silicon is typically placed near a nuclear reactor to
receive the neutrons. As neutrons continue to pass through the silicon,
more and more phosphorus atoms are produced by transmutation, and
therefore the doping becomes more and more strongly n-type. NTD is a far
less common doping method than diffusion or ion implantation, but it has
the advantage of creating an extremely uniform dopant
distribution.[18][19]
Energiereiche Neutronen können Silizium in Phosphor umwandeln. Eine
weitere Aufdotierung durch Strahlung ist dabei unkritischer, als eine
Umdotierung. Wenn in einer Zone N und P Dotierung gleichzeitig
auftreten, hast du quasi einen Kurzschluss und keine halbleitenden
Eigenschaften mehr.
Das ist aber meine Interpretation des Ganzen, ich bin kein Physiker oder
Fertigungs-Ing. ;-)
Ich habe das hier gefunden:
"Before radiation, the threshold
voltage of the parasitic transistors is so large that the voltage
forced on the gate cannot turn on the parasitic transistors. As a
result, the parasitic transistors have an effect on the 1/f noise
of the MOS transistor. In the radiation environment, the total
dose will cause a lot of positive trapped charges in the STI layers,
which will deplete or even inverse the p-type substrate under
the STI layers, resulting in the threshold voltage reducing of
the parasitic transistors. As the threshold voltages of the parasitic
transistors are reduced, the 1/f noise of the MOS transistor
will increase. The NMOS transistors are built on p-type substrate,
so after radiation we observed that 1/f noise increases
obviously
But for PMOS, it is a different case. Because PMOS transistors
are built on an n-type substrate, the positive trapped
charges caused by radiation cannot deplete or inverse the ntype
substrate. As a result, after radiation the magnitude of the
threshold voltage of the parasitic transistors will not be reduced
and the 1/f noise will not increase. That is the reason why
PMOS transistors are more resistant to radiation damage than
NMOS."
Rongbin, Hu, Wang Yuxin, and Lu Wu. "The total dose effects on the 1/f
noise of deep submicron CMOS transistors." Journal of Semiconductors
35.2 (2014): 024006.
Wie kann ein zB ein posttives alpha Teilchen (Ladung 2e) ein p-Substrat
invertieren (das p substrat hat doch schon einen elekronen mangel)?
Und warum hat es keinen EInfluss auf ein n-Subtrat, dieses besitzt doch
einen elektronen überschuss. Sollte es hier nicht zu einen Ausgleich
kommen?
Persönliche Seite
Hm, wir haben mal gelernt, dass bei CMOS-Prozessen der die "0"
schaltende n-Kanal-Transistor so gebaut wird, dass ein lokales
p-Substrat über eine "drive in"-Diffusion in ein mit BOR-vordotiertes
n-Substrat erzielt wird. Damit wäre dies gfs auch ein Folge einer
unzureichenden Dotierung.
> invertieren
Schlechtes Beispiel. Alpha Strahlung hat so eine geringe Eindingtiefe,
dass bei normalen Packages das Si nicht erreicht wird.
Neutronenstahlung oder hochenergetisches Teilchen aus einem
Beschleuniger haben dieses Problem nicht.
