Fehlermeldungen UART
OP #3994461
ich habe ein Programm erstellt mit dem ich eine UART Verbindung aufbauen
möchte.
Jedoch bekomme ich eine ganze Menge an Fehlern wenn ich den auf "Build"
gehe.
(AVR Studio 4.18)
Was habe ich falsch gemacht. Der Quelltext stammt aus einem Tutorial.
Sollte also theoretisch funktionieren?
Hier die Fehler:
rm -rf UART.o  UART.elf dep/* UART.hex UART.eep UART.lss UART.map
Build succeeded with 0 Warnings...
avr-gcc  -mmcu=atmega1284p -Wall -gdwarf-2 -Os -std=gnu99
-funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -MD -MP
-MT UART.o -MF dep/UART.o.d  -c  ../UART.c
../UART.c: In function 'uart_init':
../UART.c:14: error: 'UCSRB' undeclared (first use in this function)
../UART.c:14: error: (Each undeclared identifier is reported only once
../UART.c:14: error: for each function it appears in.)
../UART.c:14: error: 'RXEN' undeclared (first use in this function)
../UART.c:14: error: 'TXEN' undeclared (first use in this function)
../UART.c:15: error: 'UCSRC' undeclared (first use in this function)
../UART.c:15: error: 'URSEL' undeclared (first use in this function)
../UART.c:15: error: 'UCSZ0' undeclared (first use in this function)
../UART.c:17: error: 'UBRRH' undeclared (first use in this function)
../UART.c:18: error: 'UBRRL' undeclared (first use in this function)
../UART.c: In function 'uart_putc':
../UART.c:25: error: 'UCSRA' undeclared (first use in this function)
../UART.c:25: error: 'UDRE' undeclared (first use in this function)
../UART.c:26: error: 'UDR' undeclared (first use in this function)
../UART.c: In function 'uart_getc':
../UART.c:32: error: 'UCSRA' undeclared (first use in this function)
../UART.c:32: error: 'RXC' undeclared (first use in this function)
../UART.c:33: error: 'UDR' undeclared (first use in this function)
../UART.c: In function 'main':
../UART.c:48: error: 'length' undeclared (first use in this function)
../UART.c:71: warning: implicit declaration of function 'uart_puts'
../UART.c:74: error: 'UCSRA' undeclared (first use in this function)
../UART.c:74: error: 'UDRE' undeclared (first use in this function)
../UART.c:48: warning: unused variable 'string'
make: *** [UART.o] Error 1
Build failed with 19 errors and 2 warnings...
Gast #3994468
Sieht aus als wär der Fehler in Zeile 42.
Spaß beiseite, zeig dein Quellcode. Obwohl das anhand der
Fehlermeldungen so aussieht, als hättest du vergessen eine bestimmte
Headerdatei einzubinden.
OP #3994487
#define F_CPU 14745600UL     // CPU Taktfrequenz
#include <util/delay.h>       //
#include <avr/io.h>               //
#define BAUD 9200UL        //Baudrate
#define UBRR_BAUD   ((F_CPU/(16UL*BAUD))-1)
void uart_init(void) {
  UCSRB = (1<<RXEN)|(1<<TXEN);      // UART TX und RX einschalten
    UCSRC |= ( 1 << URSEL )|( 3<<UCSZ0 );  // Asynchron 8N1
    UBRRH = (uint8_t) (UBRR_BAUD>>8);
    UBRRL = (uint8_t) (UBRR_BAUD & 0x0ff);
void uart_putc(unsigned char c) {
24
    while (!(UCSRA & (1<<UDRE))) {}  // warten bis Senden möglich
25
    UDR = c;                         // Zeichen senden
26
27
28
29
30
uint8_t uart_getc(void) {
31
    while (!(UCSRA & (1<<RXC))) {} // warten bis Zeichen verfügbar
32
    return UDR;                    // Zeichen aus UDR zurueckgeben
33
34
35
36
37
38
39
//MAIN
40
41
42
43
int main (void) {
44
  uint8_t i;
45
  char c;
46
  char* s;
47
  char string[length+1];
48
49
  uart_init();
50
51
  while(1) {
52
53
   s=string;
54
    i=0;
55
56
    do {
57
    c=uart_getc();
58
      if (c!='\r')  {
59
        *s=c;
60
        uart_putc( c );
61
      s++;
62
      i++;
63
64
65
66
67
  while( i!=length && c!='\r');
68
  *s=0;
69
70
  uart_puts( "\r\n" );
71
  uart_puts( "eingegebender Text: " );
72
  uart_puts( string );
73
74
75
76
77
78
return (0);
79
Gast #3994493
Du hast wohl den falschen Prozessor gewählt, bzw. der Quellcode ist für
einen anderen geschrieben.
Ansstt UDR könnte auch UDR0 erwartet werden, zum Beispiel.
#3994497
Anhand der Parameter vom Compiler vermute ich, dass du den atmega1284p
verwendest. Dort gibt es aber die Register UCSRB usw. gar nicht. Dort
gibt es z.B. UCSR0B und UCSR1B. Ähnliche Varianten mit Zahlen gibt es
für die anderen Register auch. Da müsstest du selbst nochmal einen Blick
ins Datenblatt werfen und zu erfahren welche Register du für welchen
UART Port brauchst. Oder du suchst dir passenden Beispielcode für deinen
Mikrocontroller.
