STM32F4 UART2 - Empfangen mit DMA
Gast #4053466
Hallo Zusammen,
ich versuche gerade 1 Byte auf dem UART2 des STM32F4-Discovery Board mit
DMA zu empfangen. Mit Interrupts hat alles relativ problemlos
funktioniert, hier aber irgendwie nicht. Senden mit DMA tut ohne
Probleme.
UART Initialisierung
    uart2Handle.Instance = USART2;
    uart2Handle.Init.BaudRate = 2000000;
    uart2Handle.Init.WordLength = UART_WORDLENGTH_8B;
    uart2Handle.Init.StopBits = UART_STOPBITS_1;
    uart2Handle.Init.Parity = UART_PARITY_NONE;
    uart2Handle.Init.HwFlowCtl = UART_HWCONTROL_NONE;
    uart2Handle.Init.Mode = UART_MODE_TX_RX;
    uart2Handle.Init.OverSampling = UART_OVERSAMPLING_16;
    /* NVIC for USART2 */
    HAL_NVIC_SetPriority(USART2_IRQn, 15, 0);
    HAL_NVIC_EnableIRQ(USART2_IRQn);
DMA Initialisierung
     /* DMA'ize TX path */
     hdma_tx.Instance                 = DMA1_Stream6;
     hdma_tx.Init.Channel             = DMA_CHANNEL_4;
     hdma_tx.Init.Direction           = DMA_MEMORY_TO_PERIPH;
     hdma_tx.Init.PeriphInc           = DMA_PINC_DISABLE;
     hdma_tx.Init.MemInc              = DMA_MINC_ENABLE;
     hdma_tx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;
     hdma_tx.Init.MemDataAlignment    = DMA_MDATAALIGN_BYTE;
     hdma_tx.Init.Mode                = DMA_NORMAL;
     hdma_tx.Init.Priority            = DMA_PRIORITY_LOW;
     hdma_tx.Init.FIFOMode            = DMA_FIFOMODE_DISABLE;
     hdma_tx.Init.FIFOThreshold       = DMA_FIFO_THRESHOLD_FULL;
     hdma_tx.Init.MemBurst            = DMA_MBURST_INC4;
     hdma_tx.Init.PeriphBurst         = DMA_PBURST_INC4;
     HAL_DMA_Init(&hdma_tx);
     /* Link UART TX path to DMA */
     __HAL_LINKDMA(&uart2Handle, hdmatx, hdma_tx);
     /* DMA'ize RX path */
     hdma_rx.Instance                   = DMA1_Stream5;
23
     hdma_rx.Init.Channel               = DMA_CHANNEL_4;
24
     hdma_rx.Init.Direction             = DMA_PERIPH_TO_MEMORY;
25
     hdma_rx.Init.PeriphInc             = DMA_PINC_DISABLE;
26
     hdma_rx.Init.MemInc                = DMA_MINC_DISABLE;
27
     hdma_rx.Init.PeriphDataAlignment   = DMA_PDATAALIGN_BYTE;
28
     hdma_rx.Init.MemDataAlignment      = DMA_MDATAALIGN_BYTE;
29
     hdma_rx.Init.Mode                  = DMA_NORMAL;
30
     hdma_rx.Init.Priority              = DMA_PRIORITY_LOW;
31
     hdma_rx.Init.FIFOMode              = DMA_FIFOMODE_DISABLE;
32
     hdma_rx.Init.FIFOThreshold           = DMA_FIFO_THRESHOLD_HALFFULL;
33
     hdma_rx.Init.MemBurst = DMA_MBURST_SINGLE;
34
     hdma_rx.Init.PeriphBurst = DMA_PBURST_SINGLE;
35
36
     HAL_DMA_Init(&hdma_rx);
37
38
     /* Link UART RX path to DMA */
39
     __HAL_LINKDMA(&uart2Handle, hdmarx, hdma_rx);
40
41
42
     /* Set priorities */
43
     HAL_NVIC_SetPriority(DMA1_Stream6_IRQn, 14, 0);
44
     HAL_NVIC_EnableIRQ(DMA1_Stream6_IRQn);
45
46
      HAL_NVIC_SetPriority(DMA1_Stream5_IRQn, 14, 0);
47
     HAL_NVIC_EnableIRQ(DMA1_Stream5_IRQn);
Last but not least die Interrupt Routinen
/* UART DMA RX Handle */
void DMA1_Stream5_IRQHandler(void)
  HAL_DMA_IRQHandler(uart2Handle.hdmarx);
/* UART DMA TX Handle */
void DMA1_Stream6_IRQHandler(void)
  HAL_DMA_IRQHandler(uart2Handle.hdmatx);
/* USART2 interrupt */
void USART2_IRQHandler(void) {
    HAL_UART_IRQHandler(&uart2Handle);
Hat jemand Vorschläge? Ich hab auch schon endlose Bytes auf die
UART-Gebombt, in der Hoffnung das ich nur einen Buffer falsch definiert
hätte. Aber da kommt nix.
Ach du heiliges Frickeltier, man muss einmalig auslesen um den RX-Modus
scharf zu schalten:
   if (HAL_UART_Receive_DMA(&uart2Handle, &int_rx_char, sizeof(uint8_t)) != HAL_OK)
        error_function();
Schönes Wochenende allerseits.
> scharf zu schalten:
> != HAL_OK)
>         error_function();
Ich hänge momentan auch an dem selben Problem Daten via UART im DMA zu
empfangen. Nun ist mir aufgefallen, dass ich einmalig die Funktion
HAL_UART_Receive_DMA() mit den entsprechenden Übergabeparameter in der
main aufrufen muss, damit ich was empfange. Aber warum ist das so? Kann
mir das jemand erklären?
Vielen Dank :)
