Fehler in wait-funktion
Gast #4127367
hi,
ich möchte eine wait-funktion in c mit einem Timer erstellen.
dazu habe ihc es wie folgt gemacht
#define wait_flag = 0x00;
void wait(unsigned int count);
void Timer1_Init(void);
void __attribute__((interrupt, no_auto_psv)) _T1Interrupt(void);
int main (void){
  ADPCFGbits.PCFG0 = 1;
  TRISBbits.TRISB0 = 0;
  LATBbits.LATB0 = 0;
  while(1){
    LATBbits.LATB0 = !LATBbits.LATB0;
    wait(200);
23
24
    unsigned int countzahl;
25
    wait_flag = 1;
26
    countzahl = count/(0,00000006781684027777780*256*1000);
27
    PR1 = countzahl;
28
    TMR1 = 0;           // set timer to 0
29
    T1CONbits.TON = 1;
30
    while(wait_flag!=0){ }
31
32
33
34
    // PR1 and TCKPS are set to call interrupt every 1000ms.´
35
    // Period = PR1 * prescaler * Tcy = 57600 * 256 * 67ns = 1000ms
36
    T1CONbits.TON = 0;    // Clear Timer 1 configuration
37
    T1CONbits.TCKPS = 3;  // Set timer 1 prescaler (0=1:1, 1=1:8, 2=1:64, 3=1:256)
38
    T1CONbits.TSYNC = 1;  // Synchronize external clock input (1: Synchronize, 0: Do not synchronize)
39
    T1CONbits.TCS = 0;    // Timer Clock Source bit (1: External clock from pin TxCK, 0: Internal clock (Fosc/4))
40
    //PR1 = 57600/2;         // Set Timer 1 period (max value is 65535 (16 bit))  -> has to be set to 576 (10ms)
41
    IPC0bits.T1IP = 1;    // Set Timer 1 interrupt priority
42
    IFS0bits.T1IF = 0;    // Clear Timer 1 interrupt flag
43
    IEC0bits.T1IE = 1;    // Enable Timer 1 interrupt
44
    //T1CONbits.TON = 1;    // Turn on Timer 1 // made in _C1Interrupt(void)
45
46
47
48
49
    wait_flag = 0;
50
    T1CONbits.TON = 0;  // stopts timer
51
52
aber er gibt mir den Fehler
Main.c: In function 'wait':
Main.c:84:5: error: lvalue required as left operand of assignment
Main.c:85:26: error: invalid digit "8" in octal constant
Main.c:85:25: warning: left-hand operand of comma expression has no
effect
Main.c: In function '_T1Interrupt':
Main.c:111:5: error: lvalue required as left operand of assignment
make[2]: *** [build/default/production/Main.o] Error 255
make[2]: *** Waiting for unfinished jobs....
nbproject/Makefile-default.mk:101: recipe for target
'build/default/production/Main.o' failed
make[1]: *** [.build-conf] Error 2
make: *** [.build-impl] Error 2
was ist daran falsch? bzw. was bedeutet die Fehlermeldung?
(Firma: Schweigstill IT) Persönliche Seite #4127390
Fehlerhafter Ausdruck:
Korrekter Ausdruck:
countzahl = count/(0.00000006781684027777780*256*1000);
Inwiefern dieser Ausdruck überhaupt sinnvoll ist, steht noch zur
Diskussion. Um zumindest weitere Rundungsfehler bei der Vorberechnung
des Divisors zu reduzieren, kann es sinnvoll sein, die Ganzzahlfaktoren
auch noch in Fließkommazahlen zu wandeln:
countzahl = count/(0.00000006781684027777780*256.0*1000.0);
(Firma: Torrox.de) #4127396
Zeile 84:
wait_flag = 1;
wait_flag hast Du als Makro definiert und löst zu 0x00 auf, da steht
also:
0x00 = 1;
Zeile 85:
Ist ein Ausdruck mit Komma-Operator. Der rechte Operant ist ein oktal
kodiertes Literal (wegen der führenden 0) und in oktal-Zahlen gibt es
die Ziffer 8 nicht. Wahrscheinlich meinst Du 0.000...
mfg Torsten
Moderator (Firma: Titel) Persönliche Seite #4127408
Die Ursache ist, dass ein Integerwert, der mit einer 0 beginnt, als
Oktalzahl interpretiert wird.
Es ist z.B. eine schlechte Idee, aus Gründen der bessern Lesbarkeit
sowas zu schreiben:
a = 2345;
b = 1234;
c = 0123;
d = 0012;
e = 0001;
c und d werden hier unerwarete Werte enthalten: c == 83 bzw. d == 8
Fazit:
Du hast Glück, dass deine Zahl eine 8 enthält...
Das ist eine Idee, die in die Sackgasse führt. Denn damit lässt sich
dieser Timer für nichts Anderes mehr verwenden. Ausserdem ist explizites
Warten sowieso nur Rechenzeitvergeudung...
Gast #4127411
Oder man spart sich diesen Moloch und rechnet:
> countzahl = count * 57.6;
Ganz davon ab finde ich Magic Number sehr unschön, weil sie die
Wartbarkeit des Codes erschweren.
Also lieber:
#define MAGIC_CONSTANT1    (0.00000006781684027777780)
#define MAGIC_CONSTANT2    (256)
#define MAGIC_CONSTANT3    (1000)
#define VERY_MAGIC_CONSTANT (MAGIC_CONSTANT1 * MAGIC_CONSTANT2 * MAGIC_CONSTANT3)
countzahl = count * VERY_MAGIC_CONSTANT;
Gast #4127413
Nachtrag: Da bin ich jetzt natürlich durcheinander gekommen, bei Nutzung
der Defines wie von mir angegeben muss es natürlich wieder lauten
countzahl = count / VERY_MAGIC_CONSTANT;
