Atmel ASF - Problem mit dem ADC
OP #4313172
ich mache gerade die ersten Schritte mit ARM und ASF. Ich habe ein SAM
D10 Xplained Board und möchte eine AD-Wandlung am Pin 1 (PA2 = ADC Pin
0)durchführen.
Aus dem ASF heraus habe ich das Beispiel aus dem quick start guide
verwendet
http://asf.atmel.com/docs/3.16.0/samd21/html/asfdoc_sam0_adc_basic_use_case.html
und damit das folgende Programm geschrieben. Das Problem ist, dass ich
nach der AD-Wandlung für die Variable adc_result immer den Wert 0
bekomme.
 In this use case, the ADC will be configured with the following settings:
 1V from internal bandgap reference
 Div 4 clock prescaler
 12 bit resolution
 Window monitor disabled
 No gain
 Positive input on ADC PIN 0
 Negative input on ADC PIN 1
 Averaging disabled
 Oversampling disabled
 Right adjust data
 Single-ended mode
 Free running disabled
 All events (input and generation) disabled
 Sleep operation disabled
 No reference compensation
 No gain/offset correction
 No added sampling time
 Pin scan mode disabled
24
#include <asf.h>
25
26
struct adc_module adc_instance;
27
void configure_adc(void);
28
29
30
31
  struct adc_config config_adc;        // Create a ADC module configuration struct, which can be filled out to adjust the configuration of a physical ADC peripheral.
32
33
  adc_get_config_defaults(&config_adc);    // Initialize the ADC configuration struct with the module's default values.
34
                        // This should always be performed before using the configuration struct to ensure that all values are initialized to known default settings.
35
  adc_init(&adc_instance, ADC, &config_adc);  // Set ADC configurations
36
  adc_enable(&adc_instance);          // Enable the ADC module so that conversions can be made.
37
38
39
uint16_t adc_result;              // global variable
40
41
int main (void)
42
43
  system_init();
44
  configure_adc();
45
46
  uint16_t result;
47
48
  while (1)
49
50
    cpu_delay_ms(20);  // delay in sys ticks
51
52
    adc_start_conversion(&adc_instance);
53
54
    do
55
56
      /* Wait for conversion to be done and read out result */
57
    } while (adc_read(&adc_instance, &result) == STATUS_BUSY);
58
59
    adc_result = result;
60
61
    asm ("NOP");
62
63
An welcher Stelle in deinem Programm denkst du, das der Compiler wissen
könnte, was du vorhast? ich sehe nirgends auch nur ein Setting, welches
sich auf deine Konfiguration bezieht.
Alles im Kommentar wird übrigens ignoriert.
OP
DerDan schrieb:
> Hallo,
Hier:
Damit sollten lt. Modulbeschreibung die default-Werte des ADC
eingestellt werden.
