Arduino C++ funktioniert nicht
OP #4384252
Ich will ein kleines Programm mit der Arduino IDE schreiben. Nun habe
ich das Problem, dass Folgende Fehlermeldung kommt:
exit status 1
no match for 'operator=' (operand types are 'volatile s_cinematic' and
'volatile s_cinematic')
In AVR Studio funktioniert alles einwandfrei. Warum macht Arduino (gcc)
solche Zickereien? C ist doch eine Untermenge von C++, warum
funktioniert das nicht?
Mein Programm (Fehlerzeile durch ### hervorgehoben):
/*  Calculation of acceleration in koordinates (6 degrees of freedom)
 *  10.12.15
 *  used prefixes:
 *  s_ struct definitions
 *  g_ global variables
 *  d_ preprocessor definitions
//includes
  #include <stdio.h>
  #include <avr/io.h>
  #include <avr/interrupt.h>
//definitions
  #define d_filterlength 10
//custom datatypes
  struct s_cinematic{
    int16_t translation_x1;
    int16_t translation_x2;
    int16_t translation_x3;
    int16_t rotation_x1;
    int16_t rotation_x2;
23
    int16_t rotation_x3;
24
25
//global variables
26
  //contains calculated values of position
27
  struct s_cinematic g_position;
28
  //contains calculated values of velocity
29
  struct s_cinematic g_velocity;
30
  //contains acceleration values, read from gyrosensor
31
  volatile struct s_cinematic g_acceleration[d_filterlength];
32
  volatile int8_t g_acceleration_pointer;
33
//function prototypes
34
  void readgyro();
35
  struct s_cinematic kalman();
36
  void integrate_cinematic(struct s_cinematic input,struct s_cinematic  *output, int8_t mul_translation, int8_t mul_rotation);
37
38
void setup() {
39
  ///configure Timer2 (8-bit) system clock
40
    //TOV on OC2A >> WGM22 WGM21 WGM20
41
    TCCR2A = (1<<WGM20)|(1<<WGM21);
42
    //system tick = 100u >> 2000clk/8=250 >> CS21
43
    TCCR2B = (1<<WGM22)|(1<<CS21);
44
    OCR2A = 249;
45
    //TOV enable
46
    TIMSK2 = (1<<TOIE2);
47
    sei();
48
49
50
//interrupt 100us
51
ISR(TIMER2_OVF_vect){
52
  //read new values
53
    readgyro();
54
  //filter values
55
    struct s_cinematic temp;
56
    temp = kalman();
57
  //integrate acceleration >> velocity
58
    integrate_cinematic(temp, &g_velocity, 1, 1);
59
  //integrate velocity >> position
60
    integrate_cinematic(g_velocity, &g_position, 1, 1);
61
  return;
62
63
64
void loop() {
65
66
67
68
//functions
69
void readgyro(){
70
  //read from gyro
71
72
73
  //overtake new values
74
    ++g_acceleration_pointer;
75
    if(g_acceleration_pointer>=d_filterlength)
76
      g_acceleration_pointer=0;
77
    g_acceleration[g_acceleration_pointer] = (volatile struct s_cinematic)temp; //############
78
  return;
79
80
struct s_cinematic kalman(){
81
82
83
  return temp;
84
85
void integrate_cinematic(struct s_cinematic input, struct s_cinematic  *output, int8_t mul_translation, int8_t mul_rotation){
86
  output->translation_x1 += input.translation_x1;
87
  output->translation_x2 += input.translation_x2;
88
  output->translation_x3 += input.translation_x3;
89
  output->rotation_x1 += input.rotation_x1;
90
  output->rotation_x2 += input.rotation_x2;
91
  output->rotation_x3 += input.rotation_x3;
92
  return;
93
wenn du mir jetzt noch erklärst, wozu du da ein volatile hineincastest
> C ist doch eine Untermenge von C++, warum funktioniert das nicht?
Nö.
Das bedeutet noch lange nicht, das alle Regeln von C und C++ in dieser
Schnittmenge identisch sind. Das C Subset von C++ hat sich über die
Jahre immer weiter von echtem C entfernt.
Ich bin ehrlich gesagt geneigt dir in der Sache recht zu geben. Das
dürfte tatsächlich ein Compiler Fehler sein. Der sucht nach einer
Operation, mit der er an eine volatile struct eine Zuweisung machen
kann. Die gibt es allerdings nicht. Man könnte
* einen entsprechenden Operator schreiben
* das volatile auf der linken Seite wegcasten (schlechte Lösung)
* das Array überhaupt nicht volatile machen. Denn zum einen hat der
Compiler sowieso keine Chance, Zugriffe wegzucachen und zum anderen wird
es nur in der ISR benutzt.
Allerdings ist auch das
//interrupt 100us
  //read new values
sehr optimistisch, wenn der Kommentar stimmt.
Alle Gyros auslesen und einen Kalmanfilter drüber jagen und das alles in
100us auf einem AVR? Da würde ich sagen: bis zum Beweis des Gegenteils
glaube ich das erst mal nicht, dass sich das mit der zeit ausgeht.
OP
Ehrlichgesagt will ich bei C bleiben, da kenn ich mich zumindest
halbwegs aus.
Warum macht volatile bei einer Zuweisung überhaupt einen Unterschied?
Ich dachte das dies nur ein Hinweis für den Compiler ist, damit er die
Variable immer "zugänglich" hält, falls eine Interruptroutine
unvorhergesehen darauf zugreift.
Das wäre eine Idee, allerdings will ich mir nicht die Möglichkeit
verbauen später aus der Hauptschleife darauf zugreifen zu können.
> Allerdings ist auch das//interrupt 100us
>   //read new values
Eine spezielle Anwendung habe ich für das Projekt nicht. Ist erstmal
eher Spielerei. Den Timer werd ich zum Schluss dann so einstellen das
der atmega auch genügend Zeit hat.
> By the way: Ist das überhaupt ein gutes Gerüst, man liest ja öfters,
> dass globale Variablen "böse" sind. Mir fällt da allerdings keine
> einfachere bzw. übersichtlichere Möglichkeit ein.
Was soll es sein, prozedurale Progammierung? OOP?
Bei Anwendung von OOP hat man üblicherweise Objekte, die zur Laufzeit
untereinander Nachrichten austauschen.
In reinem C kann man mit lokalen bzw. modul-globalen Variablen arbeiten.
Wer einen entsprechenden Wert braucht, der ruft eine Funktion auf die
einem genau diesen Wert zurückgibt.
