Fast JPEG decoder on AT(x)mega
OP #4394714
This is my implementation of a fast JPEG decoder on 8-bit AVR.
It has been written entirely in assembly language (AVR Studio 4 project)
and needs approx. 5 Kbytes Flash and 2.5 Kbytes RAM. The core IDCT is
based on the implementation used in Tiny JPEG decompressor, (C) Chan
2012.
The decoder supports only sequential 8 bit color JPEG/JFIF images with
4:2:0 horizontal&vertical subsampling, 4:2:2 horizontal or vertical
subsampling and 4:4:4 no subsampling. While testing I've used GIMP for
resizing/encoding the images, offering precise control over the encoding
parameters.
There's only a very basic error handling implemented in the decoder,
it's up to the user to provide valid input data the decoder can handle.
During troubleshooting I've got very big support from JPEGsnoop, a quite
helpful tool for examining the structure of an JPEG file and to follow
the decoding process.
Development was done for ATxmega32A4U but the decoder itself doesn't
depend on special Xmega features and can be adapted to run on ATmega.
Please note: It's not intended to be a copy&paste solution, you have to
adapt the source to the particular resources of your environment, i.e.
controller, display etc.
Find a video to illustrate the speed of the decoder with various clock
frequencies and display dimensions at
https://www.youtube.com/watch?v=0XEoSdZ-Ek0
Compare with https://www.youtube.com/watch?v=Y0Zuu6Df5mQ ,
https://www.youtube.com/watch?v=oMnfp5ZVUkE or
https://www.youtube.com/watch?v=qzLS68eUM0U
The source code provides three different ways to feed the decoder with
input data.
1. Image data in controller's flash memory
Images are included in the code, capable to use flash sizes >65536
bytes.
2. Image data stored on external RAM, connected via SPI
Tested with 23LC1024 serial RAM (128 KBytes). There's a simple loader
implemented to receive a prepared image library via serial interface and
to store it into the serial RAM.
Code could be extended to connect an SPI Flash.
3. Image data received over serial interface
Send JPEG images from PC over serial interface (8n1, RTS handshaking)
with up to 921 Kbit/s.
While the speed of the decoder is near the maximum of what the AVR 8 bit
architecture is capable of, I'm not completely satisfied with the
Huffman decoder part.
If anybody has an idea how to build a decoding tree using RAM more
efficiently but with similar performance, let me know. There might be a
chance to get a slimmed-down version of this code (but still for color
images) working on controllers with only 2 KBytes RAM.
Of course, there are various ways to further optimize the memory usage
with regards to the limited resources of an 8 bit microcontroller if the
constraints are more tightened.
If you only want to handle grayscale JPEG files on your B&W - or
monochrome, to be more general - display, the RGB conversion subroutines
(consuming a whole lot processing power) incl. the coefficient tables
can be thrown away, as well as the conversion part (Huffman decoding &
IDCT) for the Cb/Cr blocks including the corresponding arrays in RAM.
This will increase the decoding speed significantly, almost doubled as a
rough guess.
And if the format of the grayscale JPEG images is fixed to 4:4:4 no
subsampling, the RAM requirements will be satisfied with 2 Kbytes.
An approach to reduce the size of the JPEG image data itself -
especially for small pictures, e.g. 160x128 pixels - could be to omit
optimization of the image during encoding. It might sound paradox, but
let me explain.
"No optimization" usually means the Huffman trees are encoded based on
the JPEG spec (ITU T.81). Hence the DHT segment contains exactly the
same data in every JPEG image encoded this way. So it's no problem to
remove this part from the file and to use precalculated Huffman trees in
the decoder (the decoder could even be optimized to handle more than one
bit at a time when walking through the tree, increasing the speed once
more). Of course, it does only make sense if multiple images have to be
handled.
Gast #4397587
Hmm...
Ich muss zugeben, dass ich bisher weder deinen Code intensiv gelesen
habe noch sehr "familar" mit den Innereien des JPEG-Standards bin.
Aber, nach dem, was ich über den JPEG-Standard weiss, steht doch bei
"Custom"-Decodingtables die Tabellendefinition vollständig und optimal
bereits im File selber, oder?
Wenn das so ist, braucht der Kram in zwei der von dir genannten drei
Möglichkeiten für die Datenquelle überhaupt nicht in das SRAM
transferiert werden, man liest einfach direkt aus der Quelle. Im Falle
des internen Flash dürfte der Overhead (verglichen mit dem Rest der
Vorstellung) vernachlässigbar klein sein und auch bei seriellen Flash
noch nicht allzusehr in's Gewicht fallen. Man muss ja auch bedenken,
dass dafür der Aufwand entfällt, denn Kram überhaupt erstmal in's RAM zu
transferieren.
Und was andere Datenquellen betrifft: Warum nicht auch die
Decodingtabelle statt in's RAM in den EEPROM oder den Flash packen?
Wobei ich hier wegen der deutlich höheren Lese-Effizienz Flash
bevorzugen würde. Da bliebe dann nur das Problem der relativ geringen
Zahl von Erase/Write-Zyklen des Flash.
Und das ist der eigentliche Grund, warum ich überhaupt etwas zu deinem
Posting schreibe. Ich arbeite nämlich gerade an einem Stück Code,
welches unbenutzten Flash als eine Art Datei (mit wear-leveling)
bereitstellt. Ein Mittelding zwischen der Gerätedatei eines Blockdevice
und einer echten Datei. Um das Teil für deine Anwendung fit zu machen,
wäre es eigentlich nur noch nötig, das wear-leveling so abzuändern, das
es möglich wird, "on-demand" einen Block bestimmter Größe temporär aus
dem wear-leveling herauszunehmen und dafür zu sorgen, dass die
physischen Adressen der Pages des Blocks direkt aufeinander folgen.
Wie es der Zufall will, war genau das sowieso geplant (wenn auch noch
nichtmal ansatzweise realisiert), um nachladbaren Code effizient zu
implementieren. Es würde aber natürlich genausogut für ladbare konstante
Datenstrukturen funktionieren.
Wäre das aus deiner Sicht ein sinnvoller Weg zur Umgehung der
RAM-Misere?
OP #4398601
Zur Dekodierung eines Huffman-kodierten Bitstroms braucht es einen
Huffman-Baum. Ein DHT-Segment in einer JPEG-Datei enthält nur die
Beschreibung, wie der entsprechende Huffman-Baum konstruiert werden muß,
aber nicht den Baum selbst, d.h. es gibt für jede Codewortlänge (1, 2, 3
usw. bis 16 Bits) eine Liste mit den Zielwerten, die bei der Dekodierung
letztlich herauskommen sollen.
Die Art und Weise, wie die Knoten des Huffman-Baums miteinander
verknüpft werden, ist natürlich nicht vorgeschrieben, wohl aber die
Zuweisung zu den Codeworten (sonst ergibt die Dekodierung irgendwas,
aber nicht die ursprünglichen Daten).
Die DHT-Segmente (auch wenn es nur die in ITU T.81 vorgeschlagenen sind)
sind in jeder JPEG-/JFIF-Datei enthalten, es gibt m.W. keinen Default,
der ansonsten zu verwenden ist. Deshalb müssen die Huffman-Bäume immer
konstruiert werden, wenn man nicht zusätzliche Einschränkungen definiert
(wie ich am Ende des Eröffnungspostings beschrieben habe).
Meine Implementation des Huffman-Baums verwendet pro Knoten zwei Byte
(egal ob Verzweigungs- oder Endknoten), eins als Pointer zum nächsten
Knoten und eins für den dekodierten Wert, falls es ein Endknoten ist.
Das ist schön homogen für die Adreßarithmetik, aber im Falle von
Verzweigungsknoten ist das Wertebyte natürlich verschwendet. Ich hatte
bislang keine gute Idee, wie das ähnlich schnell (v.a. bei der
Konstruktion des Baums) und kompakt (bzgl. des Programmcodes), aber mit
weniger RAM-Bedarf realisierbar wäre.
