STM32F3 Externen Interrupt Programmieren
OP #4410903
ich versuche grad an meinem STM32F3 (STM32F303VC) den USER-Button als
Interrupt einzustellen. Es soll eine LED leuchten falls der Interrupt
detektiert wird. Im Prinzip ein Simples Programm.
Das Problem ist ich kann den Interrupt nicht auffangen das Programm
Springt immer zum Default-Handler.
(Default_Handler(void) in der Datei vectors_stm32f30x.c)
Hier Der Code
#include<stm32f30x_conf.h>
int main(void)
    GPIO_InitTypeDef GPIO_InitStructure;
    SystemInit();
    EXTI_InitTypeDef EXTI_InitStructure;
    NVIC_InitTypeDef NVIC_InitStructure;
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA | RCC_AHBPeriph_GPIOE,
ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE);
    //lighting LED
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_Init(GPIOE, &GPIO_InitStructure);
    GPIO_WriteBit(GPIOE, GPIO_Pin_0, Bit_SET);
    //button interrupt
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOA, EXTI_PinSource0);
    //Configure Button EXTI line
    EXTI_InitStructure.EXTI_Line = EXTI_Line0;
    EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
    EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising;
    EXTI_InitStructure.EXTI_LineCmd = ENABLE;
    EXTI_Init(&EXTI_InitStructure);
    //set priotity
    NVIC_InitStructure.NVIC_IRQChannel = EXTI0_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0F;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0F;
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_InitStructure);
    while(1)
void EXTI0_IRQHandler(void){
  EXTI_ClearITPendingBit(EXTI_Line0);
  if(GPIO_ReadOutputDataBit(GPIOE, GPIO_Pin_15)){
    GPIO_WriteBit(GPIOE, GPIO_Pin_15, Bit_RESET);
  }else{
    GPIO_WriteBit(GPIOE, GPIO_Pin_15, Bit_SET);
//----SPRNGT nach INT hier REIN-------
//Datei:vectors_stm32f30x.c
void _attribute_ ((section(".after_vectors")))
#if defined(DEBUG)
  __DEBUG_BKPT();
#endif
  while (1)
Ich hoffe jemand kann mir dabei weiterhelfen.
Gast #4410965
Shaker A. schrieb:
> Hier Der Code...
Oh nein.
Erwarte lieber nicht, daß die Leute sich da drauf stürzen. Lerne lieber,
wie man einen ordentlichen Startupcode in Assembler selber schreibt
und wie man ohne die leigige ST-Lib zu Potte kommt. Dann hat sich dein
Problem bereits in Luft aufgelöst.
W.S.
Gast #4411665
Es scheint mir das die Benennung von der ISR nicht richtig ist. Damit
endet das in hardfault handler. (ich gehe davon aus das das Problem beim
drucken auf die User Button auftreht). Welche IDE verwendet du ?
Gast #4411719
W.S. schrieb:
> Oh nein.
Hier ist er ja nun wirklich nicht mehr im Startupcode!
Und der Rest ist auch CMSIS.
Kopfschüttel!
Gast #4411808
Versuchen sie mal die Handler in startup_stm32f30x.s zuruck zu finden !
Hier aus ein Beispiel von STM Lib :
/*                 STM32F30x Peripherals Interrupt Handlers                   */
/*  Add here the Interrupt Handler for the used peripheral(s) (PPP), for the  */
/*  available peripheral interrupt handler's name please refer to the startup */
/*  file (startup_stm32f30x.s).                                               */
  * @brief  This function handles External lines 5 to 9 interrupt request.
  * @param  None
  * @retval None
void EXTI9_5_IRQHandler(void)
  if((EXTI_GetITStatus(EXTI_Line6) != RESET))
    /* Toggle LD1 */
    STM_EVAL_LEDToggle(LED1);
    /* Clear the EXTI line 6 pending bit */
    EXTI_ClearITPendingBit(EXTI_Line6);
  else if((EXTI_GetITStatus(EXTI_Line5) != RESET))
23
24
    /* Toggle LD3 */
25
    STM_EVAL_LEDToggle(LED3);
26
27
    /* Clear the EXTI line 5 pending bit */
28
    EXTI_ClearITPendingBit(EXTI_Line5);
29
30
31
32
33
  * @brief  This function handles External lines 10 to 15 interrupt request.
34
  * @param  None
35
  * @retval None
36
37
void EXTI15_10_IRQHandler(void)
38
39
  if(EXTI_GetITStatus(EXTI_Line13) != RESET)
40
41
    /* Toggle LD2 */
42
    STM_EVAL_LEDToggle(LED2);
43
44
    /* Clear the EXTI line 13 pending bit */
45
    EXTI_ClearITPendingBit(EXTI_Line13);
46
47
OP #4412283
Ich Benutze Eclipse(CDT) (+ Arm-Plugin + ST-Flash + OpenOCD)
Ein Start-up Code hab ich nicht.
Assembler wäre auch Neugebiet für mich.
RP6conrad ich habe die zwei Interrupt-Handler eingefügt die  du/Sie
gepostet hast, die haben den Interrupt Leider aber auch nicht auffangen
können.
OP #4415492
Es geht jetzt mein Interrupt Handler wird jetzt angenommen.
Es musste vor dem Handler noch ein ,,extern "C"´´.
Bsp:
extern "C" void EXTI0_IRQHandler(void)
    /* Make sure that interrupt flag is set */
    if (EXTI_GetITStatus(EXTI_Line0) != RESET) {
        /* Toggle LED on PE15 */
      }else{
        /* Clear interrupt flag */
        EXTI_ClearITPendingBit(EXTI_Line12);
Vielen Dank für Euer Engagment.
