usb-Zugriff uner python geht ncht wie erwartet
OP #4415370
Beim Zugriff auf das (angeschlossene) usb-device erhalte ich folgende
Fehlermeldung:
Traceback (most recent call last):
  File "<stdin>", line 1, in <module>
  File
"/usr/lib/python2.7/dist-packages/spyderlib/widgets/externalshell/sitecu
stomize.py",  line 540, in runfile
    execfile(filename, namespace)
  File "/home/rfr/workspace/python/testUSBaccess.py", line 9, in
<module>
    raise ValueError('Device not found')
ValueError: Device not found
>>> runfile('/home/rfr/workspace/python/testUSBaccess.py',
wdir=r'/home/rfr/workspace/python')
DEVICE ID 173a:2198 on Bus 002 Address 011 =================
 bLength                :   0x12 (18 bytes)
 bDescriptorType        :    0x1 Device
 bcdUSB                 :  0x200 USB 2.0
 bDeviceClass           :    0x0 Specified at interface
 bDeviceSubClass        :    0x0
 bDeviceProtocol        :    0x0
 bMaxPacketSize0        :   0x20 (32 bytes)
 idVendor               : 0x173a
 idProduct              : 0x2198
 bcdDevice              :  0x100 Device 1.0
 iManufacturer          :    0x1 Error Accessing String
 iProduct               :    0x2 Error Accessing String
 iSerialNumber          :    0x3 Error Accessing String
 bNumConfigurations     :    0x1
  CONFIGURATION 1: 102 mA ==================================
   bLength              :    0x9 (9 bytes)
   bDescriptorType      :    0x2 Configuration
   wTotalLength         :   0x20 (32 bytes)
   bNumInterfaces       :    0x1
   bConfigurationValue  :    0x1
   iConfiguration       :    0x0
   bmAttributes         :   0x80 Bus Powered
   bMaxPower            :   0x33 (102 mA)
    INTERFACE 0: Mass Storage ==============================
     bDescriptorType    :    0x4 Interface
     bInterfaceNumber   :    0x0
     bAlternateSetting  :    0x0
     bNumEndpoints      :    0x2
     bInterfaceClass    :    0x8 Mass Storage
     bInterfaceSubClass :    0x6
     bInterfaceProtocol :   0x50
     iInterface         :    0x0
      ENDPOINT 0x81: Bulk IN ===============================
       bLength          :    0x7 (7 bytes)
       bDescriptorType  :    0x5 Endpoint
       bEndpointAddress :   0x81 IN
       bmAttributes     :    0x2 Bulk
       wMaxPacketSize   :   0x40 (64 bytes)
       bInterval        :    0x0
      ENDPOINT 0x2: Bulk OUT ===============================
       bEndpointAddress :    0x2 OUT
       bInterval        :    0x0
EINS
  File
  File "/home/rfr/workspace/python/testUSBaccess.py", line 13, in
<module>
    dev.set_configuration()
  File "/usr/local/lib/python2.7/dist-packages/usb/core.py", line 799,
in set_configuration
    self._ctx.managed_set_configuration(self, configuration)
  File "/usr/local/lib/python2.7/dist-packages/usb/core.py", line 127,
in managed_set_configuration
    self.managed_open()
  File "/usr/local/lib/python2.7/dist-packages/usb/core.py", line 105,
in managed_open
    self.handle = self.backend.open_device(self.dev)
  File "/usr/local/lib/python2.7/dist-packages/usb/backend/libusb1.py",
line 722, in open_device
    return _DeviceHandle(dev)
line 600, in _init_
    _check(_lib.libusb_open(self.devid, byref(self.handle)))
line 552, in _check
    raise USBError(_strerror(ret), ret, _libusb_errno[ret])
usb.core.USBError: [Errno 13] Access denied (insufficient permissions)
den folgende Source produziert:
_--------------------------
import usb.core
import usb.util
# find our device
dev = usb.core.find(idVendor=0x173a, idProduct=0x2198)
print dev
# was it found?
if dev is None:
print 'EINS'
# set the active configuration. With no arguments, the first
# configuration will be the active one
# get an endpoint instance
cfg = dev.get_active_configuration()
intf = cfg[(0,0)]
ep = usb.util.find_descriptor(
    intf,
    # match the first OUT endpoint
    custom_match = \
    lambda e: \
        usb.util.endpoint_direction(e.bEndpointAddress) == \
        usb.util.ENDPOINT_OUT)
assert ep is not None
# write the data
ep.write('test')
Dazu folgende Fragen:
wie kann ich das Programm so schreiben, dass verschiedene IdVendors und
IdProduct numbers erkannt werden können?
Was genau sagt mir die Fehlermeldung?
Grüsse
Robert
Gast #4415721
Einfach mal lesen...
Ganz nebenbei wuerd ich das Programm gleich so schreiben, dass es auch
zu Python 3 kompatible ist. Gleich richtig machen erspart spaeter viel
arbeit.
Gast #4415963
>Nein, das war noch nie die richtige Antwort. Stattdessen löst man das
>ganz einfach indem man die Rechte bedarfsgerecht vergibt.
Oder nach öffnen des File Descriptors Privilegien droppen und sich am
besten noch mit chroot() zusätzlich absichern  - wenn mans richtig
machen will. :D
Gast #4416038
> machen will. :D
Genau, allen Menschen den Generalschlüssel zur Bundesbank geben und sie
bitten kurz nach dem Betreten der Bank den Schlüssel abzugeben und nicht
zum Tresoröffnen zu nutzen.
#4416706
>> machen will. :D
Bei UNIX ist das so gang und gäbe und man kann sich sicher sein, dass es
überall funktioniert.
Gast #4417873
Nein, das ist es nicht. Sonst müssten alle Programme die derart
geschrieben wurden mit dem setuid Bit versehen werden und root gehören.
Das geht schon mal (dem Herrn sein Dank) mit scripts nicht.
#!/usr/bin/env python3
import os
print(os.getuid())
print(os.geteuid())
print(os.getresuid())
norbert@Entwicklung:/tmp$ l x.py
-rwsr-xr-x 1 root root 99 Jan  8 20:12 x.py
norbert@Entwicklung:/tmp$ ./x.py
(1000, 1000, 1000)
Wie man sieht wird das 's' von '-rwsr-xr-x' freundlicherweise ignoriert
und ich habe bei Programmausführung weiterhin meine Rechte und nicht
root-Rechte.
Schreibt man das Gleiche zB. in C, dann geht es natürlich (ist aber
schmutzig weil unnötig).
Also, auf unixoiden Systemen versucht man die Anzahl der SUID Programme
so gering wie möglich zu halten.
Daemons geben selbstverständlich alle Rechte die sie nicht benötigen ab
oder laufen in einem speziellen Kontext.
Dementsprechend nicht maximale Rechte vergeben und hoffen,
sondern nur minimal nötige Rechte und entspannt zurücklehnen.
#4418663
Hallo Robert,
sobald du mit einem USB-Gerät kommunizieren willst, sind
Schreib-/Leserechte erforderlich. Lege eine udev-Regel an, die die
Rechte entsprechend einstellt.
1. Im Ordner /etc/udev/rules.d eine Textdatei z.B. 99-local.rules
anlegen und folgende Regel hineinschreiben:
ACTION=="add", SUBSYSTEM=="usb", ENV{DEVTYPE}=="usb_device", ATTR{idVendor}=="173a", ATTR{idProduct}=="2198", RUN{builtin}+="uaccess"
2. Konfiguration vom udev-Dienst neu lesen lassen:
 udevadm control -R
 aus.
3. Das USB-Gerät trennen und wieder verbinden.
Dann sollte dein Script auch ohne root-Rechte laufen.
Falls nicht, kannst du mit
 udevadm monitor -u
 die Aktionen anzeigen lassen, während das Gerät wieder verbunden wird.
Es sollte dann sichtbar sein, dass "uaccess" gesetzt wird.
Viel Spaß,
Detlef
