MSP430F2013 SPI mit Arduino
OP #4423880
ich suche nach einer Möglichkeit um mit dem MSP430F2013 über SPI daten
an ein Arduino Uno zu senden. Leider habe ich es noch nicht hin
bekommen.
MSP430F2013 Beispiel Code:
SPI full-Duplex 3-wire Master
 *                       MSP430 CODE EXAMPLE DISCLAIMER
 * MSP430 code examples are self-contained low-level programs that typically
 * demonstrate a single peripheral function or device feature in a highly
 * concise manner. For this the code may rely on the device's power-on default
 * register values and settings such as the clock configuration and care must
 * be taken when combining code from several examples to avoid potential side
 * effects. Also see www.ti.com/grace for a GUI- and www.ti.com/msp430ware
 * for an API functional library-approach to peripheral configuration.
 * --/COPYRIGHT--*/
//  MSP430F20x2/3 Demo - SPI full-Duplex 3-wire Master
//  Description: SPI Master communicates full-duplex with SPI Slave using
//  3-wire mode. The level on P1.4 is TX'ed and RX'ed to P1.0.
//  Master will pulse slave reset for synch start.
//  ACLK = n/a, MCLK = SMCLK = Default DCO
//                Slave                      Master
23
//               MSP430F20x2/3              MSP430F20x2/3
24
25
//            |              XIN|-    /|\|              XIN|-
26
27
//            |             XOUT|-     --|RST          XOUT|-
28
29
//            |          RST/NMI|--+<----|P1.2             |
30
//      LED <-|P1.0             |        |             P1.4|<-
31
//          ->|P1.4             |        |             P1.0|-> LED
32
//            |         SDI/P1.7|<-------|P1.6/SDO         |
33
//            |         SDO/P1.6|------->|P1.7/SDI         |
34
//            |        SCLK/P1.5|<-------|P1.5/SCLK        |
35
36
//  M. Buccini / L. Westlund
37
//  Texas Instruments Inc.
38
//  October 2005
39
//  Built with CCE Version: 3.2.0 and IAR Embedded Workbench Version: 3.40A
40
41
42
#include <msp430.h>
43
44
int main(void)
45
46
  volatile unsigned int i;
47
48
  WDTCTL = WDTPW + WDTHOLD;             // Stop watchdog timer
49
  P1OUT =  0x10;                        // P1.4 set, else reset
50
  P1REN |= 0x10;                        // P1.4 pullup
51
  P1DIR = 0x01;                         // P1.0 output, else input
52
  USICTL0 |= USIPE7 +  USIPE6 + USIPE5 + USIMST + USIOE; // Port, SPI master
53
  USICTL1 |= USIIE;                     // Counter interrupt, flag remains set
54
  USICKCTL = USIDIV_4 + USISSEL_2;      // /16 SMCLK
55
  USICTL0 &= ~USISWRST;                 // USI released for operation
56
  USISRL = P1IN;                        // init-load data
57
58
  P1DIR |= 0x04;                        // Reset Slave
59
  P1DIR &= ~0x04;
60
  for (i = 0xFFF; i > 0; i--);          // Time for slave to ready
61
  USICNT = 8;                           // init-load counter
62
  __bis_SR_register(LPM0_bits + GIE);   // Enter LPM0 w/ interrupt
63
64
65
// USI interrupt service routine
66
#if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__)
67
#pragma vector=USI_VECTOR
68
__interrupt void universal_serial_interface(void)
69
#elif defined(__GNUC__)
70
void __attribute__ ((interrupt(USI_VECTOR))) universal_serial_interface (void)
71
#else
72
#error Compiler not supported!
73
#endif
74
75
  if (0x10 & USISRL)
76
    P1OUT |= 0x01;
77
  else
78
    P1OUT &= ~0x01;
79
  USISRL = P1IN;
80
  USICNT = 8;                           // re-load counter
81
SPI full-Duplex 3-wire Slave
//  MSP430F20x2/3 Demo - SPI full-Duplex 3-wire Slave
//                Slave                      Master
24
25
//  October 2005
26
27
28
29
#include <msp430.h>
30
31
int main(void)
32
33
34
35
36
37
  USICTL0 |= USIPE7 + USIPE6 + USIPE5 + USIOE; // Port, SPI slave
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
#else
53
54
#endif
55
56
  if (0x10 & USISRL)
57
    P1OUT |= 0x01;
58
  else
59
    P1OUT &= ~0x01;
60
  USISRL = P1IN;
61
62
Bei Arduino weis ich nicht wie ich nun die MSP430F2013 werte
auslesen/schreiben kann.
Der Titel erweckt den Eindruck, dass es auf MSP430-Seite nicht
funktioniert.
Dadurch ignorieren die Arduino-Leute den Thread vermutlich.
Was du willst, ist wohl den Arduino als SPI-Slave verwenden.
