Atmega138PA mit Arduino bzw. Atmel Studio
Gast #4437100
Hallo alle.
Ich benutze Atmel Studio um damit auf Arduino ebene meine uC zu
programmieren.
Bisher waren Tiny84 / 85 und Atmega328 dabei... keine Probleme
Sowohl bei der Arduino IDE als auch bei Atmel Studio mit diesem "Arduino
Plugin" nenn ich das mal.
So nun habe ich einen Atmega168PA..
Arduino IDE...  Compiling Ok.... aber upload geht nicht....
beim Atmel Studio... ein "Blink" programm kann ich drauf laden.
Aber sobald ich das nehme was eigentlich drauf soll, spuckt der jede
menge Fehler raus.... nur wenn meine SPI.h einbinde
This build would be faster if you upgraded to Visual Micro Gold Edition
+ USB debugger http://www.visualmicro.com
Please wait ...
Compiling 'TEEEEST' for 'ATmega168PA on a breadboard (8 MHz internal
clock)'
SPI.h:In static member function 'static byte SPIClass::transfer(byte)'
SPI.h:56: error: 'SPDR' was not declared in this scope
SPI.h:57: error: 'SPSR' was not declared in this scope
SPI.h:57: error: 'SPIF' was not declared in this scope
SPI.h:In static member function 'static void
SPIClass::attachInterrupt()'
SPI.h:63: error: 'SPCR' was not declared in this scope
SPI.h:63: error: 'SPIE' was not declared in this scope
SPIClass::detachInterrupt()'
SPI.h:67: error: 'SPCR' was not declared in this scope
SPI.h:67: error: 'SPIE' was not declared in this scope
SPI.cpp:In static member function 'static void SPIClass::begin()'
SPI.cpp:29: error: 'SPCR' was not declared in this scope
SPI.cpp:29: error: 'MSTR' was not declared in this scope
SPI.cpp:30: error: 'SPE' was not declared in this scope
SPI.cpp:In static member function 'static void SPIClass::end()'
SPI.cpp:44: error: 'SPCR' was not declared in this scope
SPI.cpp:44: error: 'SPE' was not declared in this scope
SPIClass::setBitOrder(uint8_t)'
SPI.cpp:50: error: 'SPCR' was not declared in this scope
SPI.cpp:50: error: 'DORD' was not declared in this scope
SPI.cpp:52: error: 'SPCR' was not declared in this scope
SPI.cpp:52: error: 'DORD' was not declared in this scope
SPIClass::setDataMode(uint8_t)'
SPI.cpp:58: error: 'SPCR' was not declared in this scope
SPIClass::setClockDivider(uint8_t)'
SPI.cpp:63: error: 'SPCR' was not declared in this scope
SPI.cpp:64: error: 'SPSR' was not declared in this scope
Hi, danke aber leider nicht...
habe mal als board den originalen Arduino ausgewählt... in der Arduino
IDE.. keine Probleme
und im Atmel stuio... das oberere Schauspiel
