GCC ARM Embedded -> Compiler bug! Dereferenzierung von Pointern.
Gast #4487805
GCC scheint offenbar ein Problem mit der dereferenzierung von Pointern
zu haben. Hier der Beispiel code:
#define    MAX_A    4
#define    MAX_AS  5
typedef    char    str16[16];
typedef    struct  stc_a*    ptr_stc_a;
typedef    struct  stc_a  {
                            U8        number_a;
                            str16     text_a;
                          } t_a, *ptr_t_a;
typedef    t_a            arr_t_a[MAX_AS];
typedef    arr_t_a*       ptr_arr_t_a;
typedef    struct  stc_b*   ptr_stc_b;
typedef    struct  stc_b    {
                              U8              number_b;
                              ptr_arr_t_a     arr_a;
                            } t_b, *ptr_t_b;
23
24
25
#define    PTR_ARR_A      (ptr_arr_t_a)&array_a
26
27
const      arr_t_a        array_a = {
28
                                      {0,"ZERO\0"},
29
                                      {1,"ONE\0"},
30
                                      {2,"TWO\0"},
31
                                      {3,"THREE\0"},
32
                                      {4,"FOUR\0"}
33
34
35
          t_b            b        = { 0, PTR_ARR_A };
36
37
          ptr_t_b        ptr_b;
38
39
40
#define    CR      PUTCH0('\r')
41
42
void test_stc(void)
43
44
  U8    i;
45
46
  ptr_b = (ptr_t_b)&b;
47
48
  CR;
49
  my_prints("TEST\r");
50
  my_printf("ptr_b            = %lp\r",ptr_b);
51
  my_printf("&b               = %lp\r",&b);
52
  my_printf("&array_a         = %lp\r",&array_a);
53
54
  my_printf("sizeof(t_a)      = 0x%02X\r",sizeof(t_a));
55
  my_printf("sizeof(arr_t_a)  = 0x%02X\r",sizeof(arr_t_a));
56
  my_printf("sizeof(t_b)      = 0x%02X\r",sizeof(t_b));
57
58
  CR;
59
  my_prints("Addresses dereferencing ptr_b \r");
60
  my_printf("ptr_b->number_b = %lp\r",&(ptr_b->number_b));
61
  for(i=0;i<MAX_AS;i++)
62
63
    my_printf("ptr_b->arr_a[%d] = %lp\r",i,&(ptr_b->arr_a[i]));
64
65
66
  CR;
67
  my_prints("Addresses const array_a in FLASH \r");
68
  my_printf("&array_a = %lp\r",&(array_a));
69
70
71
    my_printf("&array_a[%d] = %lp\r",i,&(array_a[i]));
72
73
Debug Ausgabe (UART)
MCU          : Spansion FM3 MB9BF516N ARM Cortex-M3
Firmware     : v00.02
CM3 CMSIS    : v04.30
GNUC         : v05.02.01 (46712)
Compiled     : Feb 29 2016 @ 13:28:05
TEST
ptr_b            = 0x1fff8038
&b               = 0x1fff8038
&array_a         = 0xba5c
sizeof(t_a)      = 0x11
sizeof(arr_t_a)  = 0x55
sizeof(t_b)      = 0x08
ptr_b->number_b            = 0x1fff8038
ptr_b->arr_a[0]            = 0xba5c
ptr_b->arr_a[1]            = 0xbab1
ptr_b->arr_a[2]            = 0xbb06
ptr_b->arr_a[3]            = 0xbb5b
ptr_b->arr_a[4]            = 0xbbb0
24
&array_a                   = 0xba5c
25
&array_a[0]                = 0xba5c
26
&array_a[1]                = 0xba6d
27
&array_a[2]                = 0xba7e
28
&array_a[3]                = 0xba8f
29
&array_a[4]                = 0xbaa0
Wie man sieht wird bei der Derefenzierung des Arrays über
"ptr_b->arr_a[x]" der pointer mit sizeof(arr_t_a) incrementiert anstatt
den anstatt mit sizeof(t_a)...
Irgendwelche ideen/workarounds???
Hab das Problem auch schon auf launchpad gepostet. Nur reagiert da
keiner...
[Mod: Code-Tags ergänzt]
Schönes Verwirrspiel hast du da gebaut!
Ist doch absolut korrekt, und kein Compiler Bug.
ptr_b->arr_a ist ein Zeiger auf ein Array von Typ arr_t_a. Somit sind
Zugriffe auf ptr_b->arr_a[i] logischerweise immer auf Vielfache der
Größe von arr_t_a.
Natürlich hast du nur 1 Array, somit sind Zugriffe mit i>0 illegal.
Wolltest du vielleicht einfach schreiben:
(*ptr_b->arr_a) [i]
So wird erst auf das Array zugegriffen, und dann auf dessen i-tes
Element.
Dann mal so...
vielleicht wird es dann etwas klarer!!
  uint8_t        number;
  ptr_arr_t_a   paa = &array_a;;
Zugriff auf das member "number_a" im i-ten Element des "array_a"  :
  number = array_a[i].number_a ;
Wie Dr. Sommer korrekterweise gezeigt hat ist
Zugriff auf das member "number_a" im i-ten Element des "array_a"  über
den Pointer paa :
  number = (*paa)[i].number_a;
Es gilt aber auch :  (*qualifier).member == qualifier->member
Ist der "qualifier" vom typ "x" als array deklariert,
z.b. "typdef   x    qualifier[size]"
muß der Compiler zwingend auch den Pointer um sizeof(x) incrementieren
(KR A.7.1)
A.7.1.
If the type of an expression or subexpression is "array of T," for some type T, then
the value of the expression is a pointer to the first object in the array, and the type of
the expression is altered to ''pointer to T." This conversion does not take place if the
expression is the operand of the unary & operator, or of ++, --, sizeof, or as the left
operand of an assignment operator or the . operator. Similarly, an expression of type
"function returning T," except when used as the operand of the & operator, is converted
to "pointer to function returning T."
Sowie KR A7.3
-> group left to right !!!
A7.3 Postfix Expressions
The operators in postfix expressions group left to right.
postfix -expression:
   primary-expression
   postfix-expression [ expression ]
   postfix-expression ( argument-expression-listopt
   postfix-expression . identifier
   postfix-expression -> identifier
   postfix-expression ++
   postfix-expression --
argument-expression-list:
  assignment -expression
  argument-expression-list , assignment-expression
A7.3.1 Array References
A postfix expression followed by an expression in square brackets is a postfix expression
denoting a subscripted array reference. One of the two expressions must have type
"pointer to T', where T is some type, and the other must have integral type; the type of
the subscript expression is T. The expression E 1 [ E2] is identical (by definition) to
23
* ( ( E 1 ) + ( E2) ) . See §A8.6.2 for further discussion.
und Auszug KR A.8.6.2
A8.6.2 Array Declarators
The array subscripting operation is defined so that E1[E2] is identical to
*(E1 + E2). Therefore, despite its asymmetric appearance, subscripting is a commutative
operation. Because of the conversion rules that apply to + and to arrays (§§A6.6,
A7.1, A7.7), if E1 is an array and E2 an integer, then E1[E2] refers to the E2-th
member of E1.
  number = paa[i]->number_a;
Da die in der BNF von ANSI C so vorgesehen ist.
%token int_const char_const float_const id string enumeration_const
postfix_exp    : primary_exp
              | postfix_exp '[' exp ']'
              | postfix_exp '(' argument_exp_list ')'
              | postfix_exp '('      ')'
              | postfix_exp '.' id
              | postfix_exp '->' id
              | postfix_exp '++'
              | postfix_exp '--'
primary_exp    : id
              | const
              | string
              | '(' exp ')'
exp            : assignment_exp
              | exp ',' assignment_exp
24
assignment_exp    : conditional_exp
25
                  | unary_exp assignment_operator assignment_exp
26
27
28
assignment_operator  : '=' | '*=' | '/=' | '%=' | '+=' | '-=' | '<<=' | '>>=' | '&=' | '^=' | '|='
29
30
31
unary_exp    : postfix_exp
32
            | '++' unary_exp
33
            | '--' unary_exp
34
            | unary_operator cast_exp
35
            | 'sizeof' unary_exp
36
            | 'sizeof' '(' type_name ')'
37
38
39
typedef_name    : id
40
41
42
>  assignment_exp
43
44
>  (postfix_exp) assignment_operator assignment_exp
45
>  (primary_exp) assignment_operator assignment_exp
46
>  (id) assignment_operator assignment_exp
47
>  number (assignment_operator) assignment_exp
48
>  number = (assignment_exp)
49
>  number = unary_exp assignment_operator assignment_exp
50
>  number = (unary_exp) assignment_operator assignment_exp
51
>  number = (postfix_exp) assignment_operator assignment_exp
52
>  number = (postfix_exp '->' id) assignment_operator assignment_exp
53
>  number = ((postfix_exp '[' exp ']')) '->' id) assignment_operator assignment_exp
54
>  number = ((primary_exp '[' exp ']')) '->' id) assignment_operator assignment_exp
55
>  number = ((id '[' exp ']')) '->' id) assignment_operator assignment_exp
56
>  number = ((paa '[' exp ']')) '->' id) assignment_operator assignment_exp
57
58
59
>  number = ((paa '[' const ']')) '->' id) assignment_operator assignment_exp
60
>  number = ((paa '[' 1 ']')) '->' id) assignment_operator assignment_exp
61
62
63
64
65
66
Am Schluss
67
..und sry ich kenne Compiler die das so umsetzen und den pointer auf das
N-te Element des arrays setzten (e.g. Softune IDE)!!
Moderator Persönliche Seite
Ma H. schrieb:
> Dann mal so...
> [gefühlte 100e Zeilen folgen]
Sorry, viel zu lang. Da macht sich keiner die Mühe, das durchzulesen,
geschweige denn auch noch zu verstehen.
Schreibe bitte einen 3-bis-8-Zeiler, der das Problem verdeutlicht und
compilierbar(!) ist.
Dazu noch maximal 3 Zeilen Text. Das reicht.
Ma H. schrieb:
> OK.. Ich seh nur Schwätzer hier...!!
Nein, Leute aus der Praxis, die sich so ein undurchdringliches Stück
Code wie da oben nicht freiwillig antun würden.
Hab's gerade versucht, sorry.
Bevor du den Standard zitierst, solltest du erstmal die Begriffe
lernen.  Ein "qualifier" ist im Standard etwas ganz anderes als das,
wie du den Begriff hier benutzt (und das stiftet mehr als Verwirrung).
Du kannst dem GCC übrigens ruhig zutrauen, dass er die Zeigerarithmetik
prinzipiell beherrscht, der macht das nicht erst seit gestern.
Ansehen. Nachdenken. Verstehen...
#include <stdio.h>
int main()
  int arr[5] = {0,1,2,3,4};
  int* parr = arr;
  int (*pparr)[5] = &arr;
  int i;
  for (i=0;i<5;i++)
    printf("arr[%d] : %x\n", i, (unsigned int)&arr[i]);
  printf("\n");
  for (i=0;i<5;i++)
    printf("parr[%d] : %x\n", i, (unsigned int)&parr[i]);
  printf("\n");
  for (i=0;i<5;i++)
    printf("pparr[%d] : %x\n", i, (unsigned int)&pparr[i]);
  printf("\n");
  printf("=======================\n");
24
25
  typedef struct
26
27
    int foo;
28
    int *parr;
29
  } tsparr;
30
  tsparr sparr = {0, parr};
31
  tsparr* psparr = &sparr;
32
33
  typedef struct
34
35
    int foo;
36
    int (*pparr)[5];
37
  } tspparr;
38
  tspparr spparr = {0, pparr};
39
  tspparr* pspparr = &spparr;
40
41
  for (i=0;i<5;i++)
42
    printf("psparr->parr[%d] : %x\n", i, (unsigned int)&(psparr->parr[i]));
43
  printf("\n");
44
45
  for (i=0;i<5;i++)
46
    printf("pspparr->pparr[%d] : %x\n", i, (unsigned int)&(pspparr->pparr[i]));
47
48
  return 0;
49
Oliver
Wenn du richtige und zielführende Antworten als Geschwätz ansiehst,
wären dir falsche und irreführende Antworten lieber? Manchmal haben
Experten einen besseren Blick darauf, was Geschwätz ist und was Hinweis.
Du solltest mal versuchen, den Unterschied zwischen dem Pointer auf ein
Array-Element und dem Pointer auf ein ganzes Array zu erkennen.
Weil ich gute Laune habe:
Dein struct-member arr_a ist ein Pointer auf den Typ arr_t_a. Ein
arr_t_a ist ein Array mit MAX_AS=5 Eintraegen von Typ t_a. Also hat GCC
recht, denn du greifst mit &(ptr_b->arr_a[i]) auf das i-te Array arr_t_a
zu (du hast aber nur eins), und nicht auf das i-te Element von deinem
einen Array!
Ein Pointer auf ein Array ist etwas anderes als ein Pointer auf den
ersten Eintrag, du musst einmal öfter dereferenzieren
(*(ptr_b->arr_a))[i].
@  Tassilo H. (tassilo_h)
>ersten Eintrag,
Nein, das ist das gleiche.
int my_array[10];
int *pointer_to_array = &my_array;
my_array[i] = x;
pointer_to_array[i] = x;  // identisch
*(pointer_to_array+i) = x;  // identisch
Aber der Op hat einen Pointer auf einen Pointer.
Jo.
>>ersten Eintrag,
Ist es nicht. Auch wenn die beiden Pointer auf die selbe Speicherstelle
zeigen, haben sie unterschiedliche Typen. Und ein Array ist kein
Pointer...
Oliver
Ma H. schrieb:
> Dann mal so...
Nein, auch wenn du noch weitere 100 Zeilen hinzufügst, wird das nicht
besser und schon garnicht klarer. Auch nicht mit 3 Ausrufungszeichen.
Ich geb dir nen Rat: Lade dir mal Freepascal und lazarus herunter und
übe 1 Jahr lang mal ordentlich in Pascal zu programmieren. Entweder du
gewöhnst dir dabei an, sauberen und "biederen" Code zu schreiben, was du
dann im Anschluß auch in C tun könntest oder bei dir ist Hopfen&Malz
verloren.
Ich kann es partout nicht ausstehen, wenn Leute beim Codeschreiben
unbedingt irgendwelche grandiosen Husarenstücke vollbringen wollen. Man
kann wirklich ALLES auch auf einfache, eben biedere Art formulieren -
und das wird dann sowohl regelmäßig bedeutend lesbarer als auch von
Anfang an fehlerärmer sein als jede Quellcode-Kunststückchen, wie du sie
weiter oben zu vollführen versuchst.
Also mein wirklich GANZ ERNST gemeinter Rat: Verzichte auf
Kunststückchen und schreib deine Quellen auf einfache Art. Benutze ruhig
auch lokale Variablen zwecks klarerer Lesbarkeit. Dabei kannst du drauf
vertrauen, daß dies deine Firmware nicht verlangsamt, denn der Compiler
kann sowas besser optimieren als du selber.
W.S.
Beitrag #7414685 wurde von einem Moderator gelöscht.
Beitrag #7414943 wurde von einem Moderator gelöscht.
Beitrag #7416084 wurde von einem Moderator gelöscht.
Beitrag #7416135 wurde von einem Moderator gelöscht.
Beitrag #7416526 wurde von einem Moderator gelöscht.
Beitrag #7416774 wurde von einem Moderator gelöscht.
